    Started with plugin issues, now SU's crashing
    3 Posts 3 Posters 120 Views 3 Watching
      t449s159
      I have a Mac running OS X V.10.5.8, with a 2.4 GHz intel core 2 duo processor, and I have been downloading SU 8
      Ok well I have been using sketchup the past few weeks with no problem. As I got a better grasp of the program I found out about plugin's and found one that I was interested in using (SoapSkinBubble Rel 1.0.13) and when I could not get that to work I tried (Curviloft 1.2d+Libfredo6-v4.7a). With both of these I put all the files in the plugin folder of SU and they did not appear in the program. I then looked under the toolbar menu, and then at the extensions to see if I needed to check them as I have read sometimes needs to be done, but they did not appear there. The strange thing is that when I went to "Get Info" for the SU app, they were listed under the "Plug-in's:" as if they were installed.
      I tried uninstalling and reinstalling both SU as well as the plugins at least 4 or 5 times, along with other attempts to fix these issues to no avail. I then decided to try a different plugin (Free version of Maxwell Render) which has its own installation manager. After proceeding through the manager I opened SU to see if it worked and I continued to have the same issue, I could not find it. Shortly after that SU crashed without drawing anything. When I went to open it again, it crashed. I uninstalled everything, restarted my computer, and then downloaded SU again, and it continues to crash every time I open it right after choosing a template.
      I have spent about 6hrs trying to figure all this out and I still literally have no idea what could be causing these issues. Considering that I am trying to model some things for my college courses final project that is due this coming Monday, I need to get this figured out. At this point I just want SU to run, even if I can not use plugins. I would like to thank the sketchUcation community for all of the information that you all have provided about SU through this website. Any help would be greatly appreciated, and thanks in advance!
        JuanV.Soler
        The only thing I can think of is to uninstall Sketchup again . Then go to program files and manually delete the Google SketchUp folder .
        Then make a registry clean .
        And then install the programm again.
        Good luck ¡
        • TIGT Online
          I suspect that you might have installed them in the wrong 'plugins' folder.
          Please post the full-path to the 'plugins' folder.
          It should be the one at the root 'HD' location: NOT the similar 'user' one.
          Copy/paste this line of code +<enter> into the Ruby Console and see the path it returns:
          Sketchup.find_support_file("plugins")
          and then
          Sketchup.find_support_file("Plugins")
          If the second version fails you might have a 'case-sensitive' system setup on your MAC which can cause all sorts of issues with Ruby because things like 'Sketchup.rb' and 'sketchup.rb' are seen as two different files !
          Please also type this $LOAD_PATH - it should include the path to the HD 'plugins' folder you found above...
          Also note that SoapSkinBubble's installation-notes ill-advisedly tell you to install it and its subfolder etc into the 'Tools' folder. This is bad practice. I have it auto-loading from 'Plugins' and it loads just fine.
          Also check that you have FULL [read.write] security permissions [set for 'all'] to the main 'plugins' folder and also its contents, because having less will compromise installations and/or the running of some tools too...
          Thomthom has a Simple-Plugins-Installer [search Plugins Index via menu item above], once you have installed that from its RBZ file [via v8 Preferences > Extensions > Installer button] it appears in the Plugins menu and lets you install RBZ and ZIP archives for complex tools and also RB/RBS more simple one file scripts... I suggest you use it once you have confirmed your MAC settings etc...
