[Plugin] Default Layer | Tag Geometry
Wow, cool. Thanks, TIG.
I was really in need of that plugin.
I sometimes group/ungroup/explode my geometries and some will go into another layer rather than the layer 0. I loss some of the geometries due to being in a hidden layer after deleting a group.
This plugin will be quite useful.
Thanks again for your time and great plugins.
Best,
_KN
εεοΌold one
Thanks again TIG, this is still one of my favorite plugins!
Very useful for cleaning up CAD imports. Thanks!
Just had to bump this up and thank you for the great plugin! I'd started a personal project years ago to try to learn SketchUp and was recently running into issues with pieces disappearing in renders unexpectedly. And then I figured out it was cause the raw geometry was on some other layer, that I had hidden, than the group itself. At first I was frustrated and puzzled as to why SketchUp's layers would operate like this, but when I looked into the issue and read some topics on the frame of mind you should have regarding layers and groups and components it all started to make more sense.
But then, sense or no sense, I was horrified at the prospect of trying to correct everything by hand, digging through every group and placing its lines on Layer0. It's just a silly, personal project, but I've put a lot of time into it and want to make it as properly and smartly as I can. So this plugin was an absolute lifesaver, saved me many hours of work and a good chunk of my sanity.
This is a fabulous script indeed, but why is it not listed on Didier's Ruby Depot? Default All Layers , IS listed but not this one "Default Layer Geometry".
Is it still working ? I ask because I use it one of my classes and a MAC user could not get it to do anything. It works fine on my PC but not on this fellow's MAC. Is that why it is no longer listed on Didier's site?
Thanks TIG
Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=47033#p47033
I've updated it to increase its speed slightly on large selections and recoded it a bit better - after 4 years of practice...
It's a simple script that should run on all SUp versions and all OSs...
Thank you very much TIG. I will send it to my MAC friend.
I really appreciate your response.
Thank you sir,
its very interesting ......
i have material tool which was apply material inside / out-side face one time .....
and thank for this tool .......
GOOD ONE .....
I can use this to fix a colleagues messy model. This will be very handy in the future.
Here's v2.0 http://sketchucation.com/pluginstore?pln=default_layer_geometry It's been updated to optimize its processing.
Either on a Selection [including any nested geometry within selected 'containers'] OR the Whole Model [if nothing is preselected].
It's also signed for v2016 compatibility in all Policies. -
Thanks again and also for your grand work to bring SketchUp to that level!
Great! Thanks!
Here's v2.1 http://sketchucation.com/pluginstore?pln=default_layer_geometry It is further optimized by correcting a stupid typo
Hi TIG,
when I try to use the script the following error appears in console (see below). I am using SU2018, and I note you have not listed it as supported.I believe line 88 should be
self.zero( e.entities )rather than
self.zero( e )Error: #<NoMethodError: undefined method
each' for #<Sketchup::Group:0x0002850e51d778>> C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:inzero'
C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:88:inblock in zero' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:ineach'
C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:inzero' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:84:inblock in zero'
C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:ineach' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:inzero'
C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:48:innew' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:35:inblock in module:DefaultLayerGeometry'
SketchUp:1:in `call' -
I think you are correct.
Try changing that line as you indicated - it should then work with selected Groups...There are other newer and more compatible plugins, like my LayerWatcher, which do similar things and more besides...
I've made v3.0 which is pretty much unchanged, except that in newer SketchUp versions it uses the word 'Tag' instead of 'Layer'...
https://sketchucation.com/pluginstore?pln=default_layer_geometry -
Great plugin! Any way to also untag nested groups and components? So that only the "outer most" group/component has a tag? I think you mentioned that your LayerWatcher script did something similar but that seems to also explode those entities? Thanks!
Why not edit the container and select-all, then run the tool to untag the selected contents.
The outermost container's tag should be unchanged by this...
