    How to modify texture color with code?
    6 Posts 4 Posters 388 Views 4 Watching
    • renderizaR
      renderiza
      Is there a way to modify a texture color with code?
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        Methods in https://developers.google.com/sketchup/docs/ourdoc/texture lets you find the material's texture's 'average_color' etc.
        Methods in https://developers.google.com/sketchup/docs/ourdoc/material lets you get/set a material's texture and also the material's color, opacity etc.
          Note that the API is missing methods to make a texture Colorized.
            You can tell if a material is colorized, via https://developers.google.com/sketchup/docs/ourdoc/material#materialType which returns 2 if the material is 'textured and colorized' [or 0 is untextured and 1 if textured], but as TT says there is no effective way to change a material's 'colorization; settings in the API.
            The 'average_color' is useful for representing the material's texture as its RGB color when the view-mode isn't showing textures.
            • renderizaR
              renderiza
              If I understood correctly it can't display the color changes while in texture mode. I hope one day the API will support such a task. Oh well I guess I need to use another method to achieve what I wanted which was to change the color of texturized clouds depending on the sun or moon is position.
              Thank you both
                Aerilius
                I think when setting a color to a textured material, the change becomes visible immediately, however the API does not differ between colorizing (checkbox in the materials browser) and color-shifting (pointer on the color wheel).
                Assuming you rotate the color wheel of a material A and get material B:
                We can then read the color value of B:
                ` material.materialType
                color = material.color
                Color(200, 147, 62, 255)then reset it to the texture image's original look: material.color = nil
                nilThis way we get A. material.materialType
                1then trying to set it again: material.color = color
                2`
                This time it is also colorized (C) and we have no control about it.
