    VRay won't stop
    renderpluginsextensions
    4 Posts 2 Posters 986 Views 2 Watching
    • V Offline
      valmach
      I am using VRay - 2011.. I have set paramaters suited to my model - issues is that "VRay" will not stop rendering.. worked fine (with customized parameters) until and hour ago.. now will not stop unless i use the default Render Settings.. System HP DV7 , 8mb Ram .. 1 yr old.. works fine.. T.I.A.
      Valentino
      • V Offline
        valerostudio
        Are you rendering from a visopt that you downloaded? Could be that the light cache and ir map settings are very high. The default renders quick because it was setup that way. Send us screenshots of your GI settings.
        • V Offline
          valmach
          Hi..
          thank you for the advice... I figured out that it was the "Add Scene" setting.. once i removed them it stopped.. which is kinda odd because i have had scenes b4 .. this time .. not sure.. but thank you..
          Valentino
          • V Offline
            valerostudio
            Not sure what setting you are referring to, but I am glad you figured it out.
