Time lapse - image recorder
Is beside this plugin: http://rhin.crai.archi.fr/rld/plugin_details.php?id=325
a camera recorder available, which exports images continously (e.g. every second) to a folder? It would be nice having the option to set the framerate.Kurt
I found this in the Resources dropdown link at the top of the page under Plugins and did a Windows Edit>Find for camera. This is by Chris Fullmer.
I'm not sure if my plugin lets you set a framerate. It might. If not, I could probably whip up a version that does let you set a framerate.
Does that do what you want? If not, I have another plugin in development I could let you beta test for me that is more of a true timelapse camera recorder. But it has a lot of work to do on it still.
Recommend you try 'Fraps', it allows you to modify the 'fps'. Also if you like making camera & objects animations easier I recommend you take a look at 'SimFonIA Animation Tools' because you can easily achieve more organic movements and it has a video exporter were you can also set the 'fps'.
Cheers
