    Lost plugin
    8 Posts 3 Posters 361 Views 3 Watching
      disturbed13
      i remember a plugin that when you moved your model it quickly changed all of the complex geometry into squares so you could easily navigate a high poly count modle
      does anyone know what its called?
      also i have an issue
      im working on designing my dream home in SU
      and i have redrawn my front porch and the roof for it
      my file size went from 32.4 to 57.5
      i have drawn each part so i can see how they all piece together
      and easily make changes like im trying
      but now when i try to import it into the file
      it just sits there
      any suggestions?
      thanks
        driven
        'ghost comp' by Fredo maybe
          SketchUp is designed to do that on its own when you navigate around the model space.
          As to your dream home, you say the file size went from 32.4 to 57.5. I assume that's Mb? Your issue is pretty difficult to solve based on the very little bit of information you've given.
          What does "it just sits there" really mean?
          Have you been making components? Have you been purging unused components? Have you been painting on materials as you go? Have you been purging unused materials? Are you displaying materials while you're trying to draw and navigate? Have you tried working in Monochrome or Hidden Line face styles? Are you drawing your model with a lot of excess geometry? Are you using high segment counts for arcs and circles? What kind of computer are you using? What graphics? How much Graphics RAM do you have? Why don't you fill out your profile instead of leaving us to guess? Are you using efficient modeling methods? Do you have shadows turned on? What do you have for OpenGL settings? Have you tried other OpenGL settings?
          So many questions but there's so much you haven't told us. πŸ˜‰
            disturbed13
            it just thinks
            im using Windows Vista 64-bit 4 GB ram 2.66 GHz Quad Core CPU GTX275 GPU and a 8800GT and 2 22" LCD
            i live by components, so yes
            purging unused components....... ummmm no. how do i do that?
            no real materials besides grass, so no materials
            no unused materials to deal with, and its all monochrome until i get the design completed
            excess geometry........ prolly. 50 to 100 sides in my circles and arc's depending on the size of it
            no shadows unless i want to see what it looks like
            and im useing OpenGL at default settings
            and when i mean that its not doing anything it has that annyoing thinking wheel and says that its not responding 😠
              Click on the Details arrow in the Components browser and choose Purge Unused.
              If 50 is the smallest number you're using, I'll bet you've gone overboard on many of the arcs and circles in your model. Hard to tell for sure without seeing it or at least some pictures. Even on large radius curves in my models I rarely go even as high as 50 sides for full circles and they are plenty smooth.
              Try purging unused components and look to see where you can clean up the model.
                disturbed13
                it took me a while but i was able to purge unused components
                so now i have to go and do the same on my other 50+ parts for my house
                some of which im still useing
                oh well
                ill try to attach a PDF of my new front porch
                front porch mk2.pdf
                  Clean modeling as you go will pay off in the long run and you'll pay for sloppy modeling eventually. I really can't tell much from your PDF but I do see what look like some exposed back faces to the side of the arch and they should be addressed. I'd bet that arch has way more segments than it needs. I can't tell if its some artifact in the PDF but if the poch roof has a bit of a dome shape to it, it looks like there are many more segments in those arcs than you need.
                    disturbed13
                    thank you for all of your help
                    i went back and purged the components on everything and reloaded all of my components
                    and now it works
                    i was able to get it on the model and now i can see how its supposed to loook
                    thank you again
