    Fill for walls in plan
    8 Posts 4 Posters 898 Views 4 Watching
      schaferron1
      In section some of my walls do not fill. Am I building these walls wrong?
      Thanks,
      • pbacotP Offline
        Probably not. Try posting a file and pictures of a good result, and a bad one. Maybe someone will have an idea what's up.
          schaferron1
          the blue are filled walls the areas clouded in red should be filled with blue
          Thanks,
          • pbacotP Offline
            This is in Sketchup then, not Layout. How did you make the section "fill"? with a plugin? The Section tool itself does not create a fill. I am guessing (without a file to look at) that you are seeing some blue back faces in some areas and not in others. It is not necessarily a wrong way in making the walls, but somehow some of your walls are on carpet textured faces and some sit over blue faces.
            Try TIG'S "Section cut face" plugin for a section fill. It gives you more control.
            Or, if you like the way you are doing it. Intersect the faces under the wall (or whatever it takes to create a separate face there) and make a blue back face.
            • cottyC Offline
              cotty
              I would bet that pbacot is right. I think I saw this as a solution for faking filled section cuts some time ago. See picture...
              my SketchUp gallery
                Ron, there seems to be some confusion. Is this a question about using LayOut or SketchUp?
                If it is a SketchUp thing I'll move it to SketchUp Discussions.
                In SketchUp, when I use section cuts I use TIG's Add Section Cut Face plugin.
                  schaferron1
                  Thanks for all the input! I will get TIG's plugin. I think pbacot is right I am seeing the inside of the wall.
                  Dave, yes, this is a SU issue.
                  thanks,
                  Ron
                    Yes, you are seeing inside the walls. I thought that was abundantly clear.
                    I'll move this post to SketchUp Discussions but I would ask you to edit the title since it has nothing to do with LayOut 3. ๐Ÿ˜’
