    Simple country barn
    45 Posts 21 Posters 4.4k Views 21 Watching
    • StinkieS
      Stinkie
      That would work for me. πŸ‘
        jpalm32
        Solo,
        Do you have problems with precise alignment with the proxy. Do you find yourself going back & forth after quick renders to correct?
        As example: A tree or bush placement next to another item.
        Or are proxy best for general palcement?
        • soloS
          @jpalm32 said:
          Solo,
          The only adjustments I did in image was the tree behind camera in order to get correct shadow cast, remember in Thea4SU you have all render option so you can use interactive rendering (realtime) to see how it is while you are doing it. πŸ˜„
            jpalm32
            That's right, it's interactive.
            That has to help! Nice render!
            • smarqueS
              smarque
              I prefer pdf over video as I feel that written material is good for referring to later especially in this subject where I have a steep learning curve to master. I just feel that I can take it in slower in pdf form?
              • tridemT
                tridem
                Agree with smarque. Moreover, for people not speaking english, watching a video with spoken explanations could be very hard, while a text can be translated quite easily.
                That said, thanks for whatsoever you'll do πŸ‘
                • C
                  cadmunkey
                  Would prefer video tutorials, I have found that sometimes in pdfs, minor details have been missed out that doesnt enable new users to follow exactly what was intended.
                  As a side note, have Thea not considered using the same system for generating grass in sketchup that Maxwell have recently launched? Saves having to have a ton of proxies just to build a field? Looking forward to getting a play with this when released.
                    john.warburton
                    Forced to choose between video and PDF, I would prefer video. But both have advantages, and I'd like to have both!
                    Life's a reach, and then you gybe.
                    • N
                      notareal
                      Hair/fur system and ecosystem are on the roadmap. No date when these will be available.
                      • C
                        cadmunkey
                        Sounds great! πŸ˜„
                        • marked001M
                          marked001
                          @dale said:
                          Pete, I don't care which you choose, I'm just looking forward to it.
                          I'm with Dale. And I'm very excited for this!
                          http://www.revision21vis.com
                          instagram: revi21on
                          • Bryan KB
                            @marked001 said:
                            Same here. Yours and others work here are what I strive for and keeps me motivated. Any chance to learn is welcome.
                            • soloS
                              More images, playing with materials.
                              • daleD
                                dale
                                😲 Is that a Hillman?
                                • soloS
                                  Indeed it is, 1973.
                                  • daleD
                                    dale
                                    I used to have a Hillman Californian, about that vintage, and you matched the paint job perfectly.
                                    You must be just smiling testing this out!
                                    • marked001M
                                      marked001
                                      Anyone willing to create a good material building tutorial? or know of any good ones??
                                      This is one (of many) areas that I am horrible with.. .
                                      instagram: revi21on
                                      • soloS
                                        Here is a start, there are other pdf based ones, I'll see if I can find them.
                                        • N
                                          notareal
                                          Fyi... Thea pdf tutorial for material lab is almost ready, it will be found under Thea Render resources at PDF Tutorials, like other new pdf tutorials.
                                          • StinkieS
                                            Stinkie
                                            Great! πŸ‘
                                            • 2 / 3
