    Simple country barn
    45 Posts 21 Posters 4.4k Views 21 Watching
    • renderizaR
      renderiza
      This blows my mind how you were able to set this up...Beautiful Indeed!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • srxS
        srx
        πŸ˜„ Video.
        www.saurus.rs
        • leedeeteeL
          leedeetee
          Thanks Solo, it's a great explanation. πŸ˜„
          Can the proxies be used in SU in general, or, is it a Thea specific tool?
            PDF over video every time, much less obfuscation in a pdf.
            • boofredlayB
              boofredlay
              @solo said:
              I think doing a video tutorial will be better as typing this and reading it confused me, I make more sense just saying and showing, once you get past my accent.
              πŸ˜† My point exactly. I just finished a tutorial for Catchup that took many hours to complete. Had I done it with a video it would have been about 10 min. long. Then maybe 30 min. of editing the video with tool tips.
              • daleD
                dale
                Pete, I don't care which you choose, I'm just looking forward to it.
                • pbacotP
                  I'm with the monkey!
                  • soloS
                    Thanks guys.
                    I need to wait until Tomasz (the author) releases his final beta version with any new changes, feature or UI improvements before starting, there is no point doing a tutorial if my version is different to the released version, so as soon as I get that i'll get going with it.
                    I like the idea of doing it in short sessions, covering topics like Interface, using proxy's, making proxy's, render settings, animation, lighting, crf's, DOF, etc, that way you can watch the parts you need without having to sit through hours to find the bits you need.
                    • StinkieS
                      Stinkie
                      That would work for me. πŸ‘
                        jpalm32
                        Solo,
                        Do you have problems with precise alignment with the proxy. Do you find yourself going back & forth after quick renders to correct?
                        As example: A tree or bush placement next to another item.
                        Or are proxy best for general palcement?
                        • soloS
                          @jpalm32 said:
                          Solo,
                          The only adjustments I did in image was the tree behind camera in order to get correct shadow cast, remember in Thea4SU you have all render option so you can use interactive rendering (realtime) to see how it is while you are doing it. πŸ˜„
                            jpalm32
                            That's right, it's interactive.
                            That has to help! Nice render!
                            • smarqueS
                              smarque
                              I prefer pdf over video as I feel that written material is good for referring to later especially in this subject where I have a steep learning curve to master. I just feel that I can take it in slower in pdf form?
                              • tridemT
                                tridem
                                Agree with smarque. Moreover, for people not speaking english, watching a video with spoken explanations could be very hard, while a text can be translated quite easily.
                                That said, thanks for whatsoever you'll do πŸ‘
                                • C
                                  cadmunkey
                                  Would prefer video tutorials, I have found that sometimes in pdfs, minor details have been missed out that doesnt enable new users to follow exactly what was intended.
                                  As a side note, have Thea not considered using the same system for generating grass in sketchup that Maxwell have recently launched? Saves having to have a ton of proxies just to build a field? Looking forward to getting a play with this when released.
                                    john.warburton
                                    Forced to choose between video and PDF, I would prefer video. But both have advantages, and I'd like to have both!
                                    Life's a reach, and then you gybe.
                                    • N
                                      notareal
                                      Hair/fur system and ecosystem are on the roadmap. No date when these will be available.
                                      • C
                                        cadmunkey
                                        Sounds great! πŸ˜„
                                        • marked001M
                                          marked001
                                          I'm with Dale. And I'm very excited for this!
                                          http://www.revision21vis.com
                                          instagram: revi21on
                                          • Bryan KB
                                            @marked001 said:
                                            Same here. Yours and others work here are what I strive for and keeps me motivated. Any chance to learn is welcome.
                                            • 2 / 3
