    [plugin] Structural analysis - SketchStruct: 30 Oct 12: v201
    29 Posts 18 Posters 34.9k Views 18 Watching
      Physical indeed! 😎
        Severe_dude
        awesome it's the future 😒
        • E Offline
          errror404
          Sing me up!! If you guys can take it to the next level it could freaking awesome. BRB gotta try this thing!
            dejanfortuna
            Looks great keep up the good work.
              dejanfortuna
              Great tool, i hope you can finish what you have started.
                mddc
                it is so hard to make... congratulations!
                  sherwood11
                  Coool .. I'll check it out !
                    glro
                    @target2427 said:
                    Changelog
                    v2.0.1 - Added confirmation when choosing materials, now using .rbz install method
                    Cheers
                    don't know why: version 2.0.0 is downloaded following the link
                    and when y try, the ruby box says
                    Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:815:in member_load'
                    C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:813:in each' C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:813:in member_load'
                    C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:858:in main' C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/main.rb:98 C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:815:in call'
                    no outputs are shown, only inputs
                    apart from that, it is a nice idea, wish it comes through
                    • KrisidiousK Offline
                      Krisidious
                      oh yeah... I'll be watching this one. 😍
                      By: Kristoff Rand
                        target2427
                        Sorry about this, I did upload the file but for some reason sourceforge did not pick it up as the latest version. I have manually overridden this now and the newest version should be available for download.
                        https://sourceforge.net/projects/sketchstruct/files/latest/download
                        @glro said:
                        @target2427 said:
                        Changelog
                        Cheers
                          glro
                          I tried again the link and yes, now it is the last version
                          I tried a few times and it worked as expected; sometimes it didn't though
                          once i got this error message:
                          "Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:231:in get_nodal_loads'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:230:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:230:in get_nodal_loads'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:11:in initialize' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/main.rb:66:in new'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:231:in `call'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:231"
                          With another example, the program gave a result, but in the ruby box, it wrote
                          "no. joints: 4
                          no. bars: 3
                          no. restraints: 4
                          DOF: 8
                          Maxwell's number: 1
                          Errror, mechanism forming
                          no. degrees of freedom: 8"
                          Obviously, there is still a lot of work to do to make it a usable tool, but i like very much having it in the sketchup environment
                          sketchup trial
                          second trial
                            target2427
                            Just a couple of questions about how you created the structure.
                            When I run your file I get the same error, however, when I redraw the structure, the program runs fine.
                            Did you first draw your structure with SketchStruct installed?
                            and
                            Did you draw the structure manually, line by line?
                            Tom
                              glro
                              and
                              Yes to the first question
                              No to the second
                              I had it drawn automatically by another plugin i am working on, that makes a model of a scaffolding
                              From this model, i kept only the axis line and applied to it loads, supports, material and geometric values.
                              I didn't guess it would make a difference with a structure drawn from scratch
                              file 1
                                target2427
                                Ok, it looks like the two plugins are incompatible at the moment. SketchStruct uses a couple of minor functions for numbering the edges, this is done as the lines are drawn by the user.
                                This is a simple function which probably be included in your plugin to allow the two plugins to work together.
                                If you want more info on how the numbering works, I will be happy to help.
                                Tom
                                  glro
                                  Tom
                                  The plugin i am working on doesn't use any numbering for edges; it is probably done automatically by sketchup
                                  It seems to me that it would be an enhancement for your plugin to be able to number edges of an existing drawing; this way the user could store models and re-use them
                                  Anyway, this is how usual structural analysis softwares work
                                  Thank you for your answer
                                    target2427
                                    I did attempt to achieve this with the automatic Sketchup numbering, however, I had problems as Sketchup does not save these consistently. i.e. the IDs would change between sessions after saving and loading.
                                    Hopefully I can find a way to achieve this with the sketchup numbering. I will try to look for a way to include this in the next version.
                                    • jarynzlesaJ Offline
                                      jarynzlesa
                                      it seems to be a very nice and useful pluging, but I can not set supports and load. don't know why. 😢
                                      http://www.vizualizaceschodiste.mypage.cz/
                                        Jim
                                        Tom, this plugin is interfering with normal behavior of SketchUp[1].
                                        I had a quick look at some of the code and there's a lot to go over. In the meantime, I recommend users of this plugin disable it in the Extensions dialog when not in use.
                                        [1] http://sketchucation.com/forums/viewtopic.php?f=180&t=49507
                                          target2427
                                          I am aware of this and will try to fix this for the next version. Sometimes errors pop up in the Ruby console when drawing lines indirectly (squares, arcs...).
                                          I apologise for the errors, but it is something being worked on
                                          • irwanwrI Offline
                                            irwanwr
                                            This plugin should be awesome. And may become another very good reason to tell my brother to learn SketchUp and not just CAD 😄
                                            I hope all bugs could be fixed and works as it should be.
