    [plugin] Structural analysis - SketchStruct: 30 Oct 12: v201
    29 Posts 18 Posters 34.3k Views 18 Watching
      glro
      @target2427 said:
      Changelog
      v2.0.1 - Added confirmation when choosing materials, now using .rbz install method
      Cheers
      don't know why: version 2.0.0 is downloaded following the link
      and when y try, the ruby box says
      Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:815:in member_load'
      C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:813:in each' C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:813:in member_load'
      C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:858:in main' C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/main.rb:98 C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:815:in call'
      no outputs are shown, only inputs
      apart from that, it is a nice idea, wish it comes through
      • KrisidiousK Offline
        Krisidious
        oh yeah... I'll be watching this one. 😍
        By: Kristoff Rand
          target2427
          Sorry about this, I did upload the file but for some reason sourceforge did not pick it up as the latest version. I have manually overridden this now and the newest version should be available for download.
          https://sourceforge.net/projects/sketchstruct/files/latest/download
          @glro said:
          @target2427 said:
          Changelog
          Cheers
            glro
            I tried again the link and yes, now it is the last version
            I tried a few times and it worked as expected; sometimes it didn't though
            once i got this error message:
            "Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:231:in get_nodal_loads'
            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:230:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:230:in get_nodal_loads'
            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:11:in initialize' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/main.rb:66:in new'
            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:231:in `call'
            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:231"
            With another example, the program gave a result, but in the ruby box, it wrote
            "no. joints: 4
            no. bars: 3
            no. restraints: 4
            DOF: 8
            Maxwell's number: 1
            Errror, mechanism forming
            no. degrees of freedom: 8"
            Obviously, there is still a lot of work to do to make it a usable tool, but i like very much having it in the sketchup environment
            sketchup trial
            second trial
              target2427
              Just a couple of questions about how you created the structure.
              When I run your file I get the same error, however, when I redraw the structure, the program runs fine.
              Did you first draw your structure with SketchStruct installed?
              and
              Did you draw the structure manually, line by line?
              Tom
                glro
                and
                Yes to the first question
                No to the second
                I had it drawn automatically by another plugin i am working on, that makes a model of a scaffolding
                From this model, i kept only the axis line and applied to it loads, supports, material and geometric values.
                I didn't guess it would make a difference with a structure drawn from scratch
                file 1
                  target2427
                  Ok, it looks like the two plugins are incompatible at the moment. SketchStruct uses a couple of minor functions for numbering the edges, this is done as the lines are drawn by the user.
                  This is a simple function which probably be included in your plugin to allow the two plugins to work together.
                  If you want more info on how the numbering works, I will be happy to help.
                  Tom
                    glro
                    Tom
                    The plugin i am working on doesn't use any numbering for edges; it is probably done automatically by sketchup
                    It seems to me that it would be an enhancement for your plugin to be able to number edges of an existing drawing; this way the user could store models and re-use them
                    Anyway, this is how usual structural analysis softwares work
                    Thank you for your answer
                      target2427
                      I did attempt to achieve this with the automatic Sketchup numbering, however, I had problems as Sketchup does not save these consistently. i.e. the IDs would change between sessions after saving and loading.
                      Hopefully I can find a way to achieve this with the sketchup numbering. I will try to look for a way to include this in the next version.
                      • jarynzlesaJ Offline
                        jarynzlesa
                        it seems to be a very nice and useful pluging, but I can not set supports and load. don't know why. 😢
                        http://www.vizualizaceschodiste.mypage.cz/
                          Jim
                          Tom, this plugin is interfering with normal behavior of SketchUp[1].
                          I had a quick look at some of the code and there's a lot to go over. In the meantime, I recommend users of this plugin disable it in the Extensions dialog when not in use.
                          [1] http://sketchucation.com/forums/viewtopic.php?f=180&t=49507
                            target2427
                            I am aware of this and will try to fix this for the next version. Sometimes errors pop up in the Ruby console when drawing lines indirectly (squares, arcs...).
                            I apologise for the errors, but it is something being worked on
                            • irwanwrI Offline
                              irwanwr
                              This plugin should be awesome. And may become another very good reason to tell my brother to learn SketchUp and not just CAD 😄
                              I hope all bugs could be fixed and works as it should be.
                                target2427
                                Hi all
                                Just thought I should give you an update on the current progress. At the moment I am working on a Mesh analysis plugin (2d currently). The analysis itself is working fine, however when using very refined meshes (i.e. 100 elements), Sketchup pretty much crashes on my computer. To resolve this, I am also working on a Sparse Matrix library for Ruby. The idea of this is to reduce the time of calculations by only storing non-zero entities. On this, I have got matrix multiplication and addition working, however the more complex task of solving sets of simultaneous equations is not yet complete. I will not be releasing this plugin until I can get this working effectively.
                                My next semester at uni is now starting, so progress may be slow on this.
                                Cheers
                                Tom
                                  markitekt
                                  Great Plugin. Any chance for English units in the future?
                                    target2427
                                    I do plan to implement American Imperial units in the future, however it is not a high priority so may be a while before you see this. For now, you should be able to enter everything any units as long as they are consistent (ignoring the suggested units).
                                    For example, if you enter a beam 140" long, you could enter Youngs modulus, E as 29 (10^6) psi, as long as you enter your loads in pound force.
                                    Just remember to use consistent units everywhere.
                                    • N Offline
                                      neo83_gr
                                      _
                                      • 2 / 2
