    [plugin] Structural analysis - SketchStruct: 30 Oct 12: v201
    29 Posts 18 Posters 35.2k Views 18 Watching
    • T
      tak2hata
      Very Interesting. 😲
      by TAK2HATA
        Physical indeed! 😎
          Severe_dude
          awesome it's the future 😒
          • E
            errror404
            Sing me up!! If you guys can take it to the next level it could freaking awesome. BRB gotta try this thing!
              dejanfortuna
              Looks great keep up the good work.
                dejanfortuna
                Great tool, i hope you can finish what you have started.
                  mddc
                  it is so hard to make... congratulations!
                    sherwood11
                    Coool .. I'll check it out !
                    • G
                      glro
                      @target2427 said:
                      Changelog
                      v2.0.1 - Added confirmation when choosing materials, now using .rbz install method
                      Cheers
                      don't know why: version 2.0.0 is downloaded following the link
                      and when y try, the ruby box says
                      Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:815:in member_load'
                      C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:813:in each' C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:813:in member_load'
                      C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:858:in main' C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/main.rb:98 C:/PROGRA~2/Google/GOOGLE~3/Plugins/SketchStruct2.0.0/stiffness.rb:815:in call'
                      no outputs are shown, only inputs
                      apart from that, it is a nice idea, wish it comes through
                      • KrisidiousK
                        Krisidious
                        oh yeah... I'll be watching this one. 😍
                        By: Kristoff Rand
                        • T
                          target2427
                          Sorry about this, I did upload the file but for some reason sourceforge did not pick it up as the latest version. I have manually overridden this now and the newest version should be available for download.
                          https://sourceforge.net/projects/sketchstruct/files/latest/download
                          @glro said:
                          @target2427 said:
                          Changelog
                          Cheers
                          • G
                            glro
                            I tried again the link and yes, now it is the last version
                            I tried a few times and it worked as expected; sometimes it didn't though
                            once i got this error message:
                            "Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:231:in get_nodal_loads'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:230:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:230:in get_nodal_loads'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:11:in initialize' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/main.rb:66:in new'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:231:in `call'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/SketchStruct2/read.rb:231"
                            With another example, the program gave a result, but in the ruby box, it wrote
                            "no. joints: 4
                            no. bars: 3
                            no. restraints: 4
                            DOF: 8
                            Maxwell's number: 1
                            Errror, mechanism forming
                            no. degrees of freedom: 8"
                            Obviously, there is still a lot of work to do to make it a usable tool, but i like very much having it in the sketchup environment
                            sketchup trial
                            second trial
                            • T
                              target2427
                              Just a couple of questions about how you created the structure.
                              When I run your file I get the same error, however, when I redraw the structure, the program runs fine.
                              Did you first draw your structure with SketchStruct installed?
                              and
                              Did you draw the structure manually, line by line?
                              Tom
                              • G
                                glro
                                and
                                Yes to the first question
                                No to the second
                                I had it drawn automatically by another plugin i am working on, that makes a model of a scaffolding
                                From this model, i kept only the axis line and applied to it loads, supports, material and geometric values.
                                I didn't guess it would make a difference with a structure drawn from scratch
                                file 1
                                • T
                                  target2427
                                  Ok, it looks like the two plugins are incompatible at the moment. SketchStruct uses a couple of minor functions for numbering the edges, this is done as the lines are drawn by the user.
                                  This is a simple function which probably be included in your plugin to allow the two plugins to work together.
                                  If you want more info on how the numbering works, I will be happy to help.
                                  Tom
                                  • G
                                    glro
                                    Tom
                                    The plugin i am working on doesn't use any numbering for edges; it is probably done automatically by sketchup
                                    It seems to me that it would be an enhancement for your plugin to be able to number edges of an existing drawing; this way the user could store models and re-use them
                                    Anyway, this is how usual structural analysis softwares work
                                    Thank you for your answer
                                    • T
                                      target2427
                                      I did attempt to achieve this with the automatic Sketchup numbering, however, I had problems as Sketchup does not save these consistently. i.e. the IDs would change between sessions after saving and loading.
                                      Hopefully I can find a way to achieve this with the sketchup numbering. I will try to look for a way to include this in the next version.
                                      • jarynzlesaJ
                                        jarynzlesa
                                        it seems to be a very nice and useful pluging, but I can not set supports and load. don't know why. 😢
                                        http://www.vizualizaceschodiste.mypage.cz/
                                          Jim
                                          Tom, this plugin is interfering with normal behavior of SketchUp[1].
                                          I had a quick look at some of the code and there's a lot to go over. In the meantime, I recommend users of this plugin disable it in the Extensions dialog when not in use.
                                          [1] http://sketchucation.com/forums/viewtopic.php?f=180&t=49507
                                          • T
                                            target2427
                                            I am aware of this and will try to fix this for the next version. Sometimes errors pop up in the Ruby console when drawing lines indirectly (squares, arcs...).
                                            I apologise for the errors, but it is something being worked on
