    Using win32ole on startup
    14 Posts 5 Posters 876 Views 5 Watching
      Does the same code work if you run it after SketchUp has started?
        Have you tried enclosing it and then waiting until things settle down?
        require 'sketchup.rb'
        require 'win32ole.so'
        module SR20VET
          def SR20VET.xls()
            model = Sketchup.active_model
            until model.entities
              model_dict = model.attribute_dictionary("thisIsADict")
              if model_dict
                xl = WIN32OLE.new('Excel.Application')
                ### rest of code ###
          end#def
        end#module
        SR20VET.xls()
          Won't that loop block the rest of SketchUp? Ruby doesn't let SketchUp "breathe" when it's working - that's why the UI white outs because not even the Windows messages are given any opportunity to be processed.
            But presumably it'll only pause briefly until model.entities in returned ?
            OR it could start a timer that'd run separately ?
                module SR20VET
                  def SR20VET.xls()
                    UI.start_timer(1,false){
                      if model_dict
                    }#end timer
                  end#def
                end#module
                SR20VET.xls()
              @tig said:
              But presumably it'll only pause briefly until model.entities in returned?
              Pretty sure it won't, because the rest of SU can't continue until the loop is complete. You might have created an infinite loop. SketchUp's doesn't run in parallel with the ruby engine. It's sequential processing.
                I think this'll work:
                        module SR20VET
                          def SR20VET.xls()
                            timer=UI.start_timer(0,false){
                              UI.stop_timer(timer)
                              until model.entities; end
                              if model_dict
                            }#end timer
                          end#def
                        end#module
                        SR20VET.xls()
                  For timer delay you should immediately stop the timer in it's block - because if a modal window appear within the block, like a messagebox or an error message (which you get when you start SU) will make the timer repeat until the modal window is closed.
                  <span class="syntaxdefault"><br />timer&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">){<br />&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">stop_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">timer</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;...<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
                    Added to last post for avoidance of confusion...
                    • Chris FullmerC Offline
                      Sorry to drag this off topic, but what does win32ole do? It looks like the code is interfacing with excel? Will win32ole read and write excel files? I'm looking around here:
                      Index of Classes & Methods in win32ole: Ruby Standard Library Documentation (Ruby 1.9.3)
                      (www.ruby-doc.org)
                      But I don't see an explanatiojn of what it does.
                        OLE is an interface for communicating with Objects. Excel has implemented this interface so you can communicate with Excel.
                        Win32OLE is a library that allows you to use OLE interfaces within Ruby.
                        Object Linking and Embedding - Wikipedia
                        (en.wikipedia.org)
                        • Dan RathbunD Offline
                          Dan Rathbun
                          [Plugin Library] Win32API and Win32OLE so files
                          Online reference rdocs for these 2 libraries:
                          • Win32API rdoc
                          • WIN32OLE rdoc
                          I'm not here much anymore.
                            SR20VET
                            <span class="syntaxdefault"><br />timer </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">){<br /></span><span class="syntaxdefault">  UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">stop_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">timer</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># ...<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
                            Hi Thom and TIG, that's exactly how ì solved it. Noticed the fact that a UI.messagebox in the block will make the timer repeat too.
                            Never used UI.start_timer before but I can think of some nice implementations of it.
