    Using win32ole on startup
    14 Posts 5 Posters 712 Views 5 Watching
      SR20VET
      Hello,
      I have some difficulties on starting a WIN32OLE.new('Excel.Application') on startup of SketchUp... code I have is simple in test.rb:
      require 'sketchup.rb'
      require 'win32ole.so'
      model_dict = Sketchup.active_model.attribute_dictionary "thisIsADict"
      xl = WIN32OLE.new('Excel.Application') if model_dict
      The Error i get is:
      uninitialized constant WIN32OLE
      I think this has something to do with me trying to start an ole connection directly on start-up. If I assign the code to a command, there is no problem...
      But, the code needs to be executed directly when a specific .skp (with "thisIsADict" library) is opened...
      Any ideas how to solve this would be great.
      Cheers!
        You shouldn't be adding the extension. require 'win32ole' is the convention.
        Not sure if that's the source of your issues though.
        But you might have other problems: trying to access Sketchup.active_model on startup. Not sure if everything is available when the Ruby engine is initialized. You might want to check that.
          Does the same code work if you run it after SketchUp has started?
            Have you tried enclosing it and then waiting until things settle down?
            module SR20VET
              def SR20VET.xls()
                model = Sketchup.active_model
                until model.entities
                  model_dict = model.attribute_dictionary("thisIsADict")
                  if model_dict
                    ### rest of code ###
              end#def
            end#module
            SR20VET.xls()
              Won't that loop block the rest of SketchUp? Ruby doesn't let SketchUp "breathe" when it's working - that's why the UI white outs because not even the Windows messages are given any opportunity to be processed.
                But presumably it'll only pause briefly until model.entities in returned ?
                OR it could start a timer that'd run separately ?
                    module SR20VET
                      def SR20VET.xls()
                        UI.start_timer(1,false){
                          if model_dict
                        }#end timer
                      end#def
                    end#module
                    SR20VET.xls()
                  @tig said:
                  But presumably it'll only pause briefly until model.entities in returned?
                  Pretty sure it won't, because the rest of SU can't continue until the loop is complete. You might have created an infinite loop. SketchUp's doesn't run in parallel with the ruby engine. It's sequential processing.
                    I think this'll work:
                            module SR20VET
                              def SR20VET.xls()
                                timer=UI.start_timer(0,false){
                                  UI.stop_timer(timer)
                                  until model.entities; end
                                  if model_dict
                                }#end timer
                              end#def
                            end#module
                            SR20VET.xls()
                      For timer delay you should immediately stop the timer in it's block - because if a modal window appear within the block, like a messagebox or an error message (which you get when you start SU) will make the timer repeat until the modal window is closed.
                      <span class="syntaxdefault"><br />timer&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">){<br />&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">stop_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">timer</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;...<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
                        Added to last post for avoidance of confusion...
                        • Chris FullmerC Offline
                          Sorry to drag this off topic, but what does win32ole do? It looks like the code is interfacing with excel? Will win32ole read and write excel files? I'm looking around here:
                          Index of Classes & Methods in win32ole: Ruby Standard Library Documentation (Ruby 1.9.3)
                          (www.ruby-doc.org)
                          But I don't see an explanatiojn of what it does.
                            OLE is an interface for communicating with Objects. Excel has implemented this interface so you can communicate with Excel.
                            Win32OLE is a library that allows you to use OLE interfaces within Ruby.
                            Object Linking and Embedding - Wikipedia
                            (en.wikipedia.org)
                            • Dan RathbunD Offline
                              Dan Rathbun
                              [Plugin Library] Win32API and Win32OLE so files
                              Online reference rdocs for these 2 libraries:
                              • Win32API rdoc
                              • WIN32OLE rdoc
                              I'm not here much anymore.
                                SR20VET
                                <span class="syntaxdefault"><br />timer </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">){<br /></span><span class="syntaxdefault">  UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">stop_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">timer</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># ...<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
                                Hi Thom and TIG, that's exactly how ì solved it. Noticed the fact that a UI.messagebox in the block will make the timer repeat too.
                                Never used UI.start_timer before but I can think of some nice implementations of it.
