    PushPull question
    12 Posts 7 Posters 4.9k Views 7 Watching
      JuanV.Soler
      I want to pushpull all these faces of a contoured terrain at an exact z-distance of 1.05m in between them.
      The total height is 105m.
      Doing it one by one is too much.
      I was wondering if there is a plugin that might do that.
      I saw the random pushpull from TIGand thought maybe it could be done.
      Or already exists and I am unawared of.
      Thanks for listening.
      • sdmitchS Offline
        sdmitch
        Doubtful, since it would be difficult if not imposible to identify the order of the contours/faces. At best, an interactive plugin, that would accept a starting elevation and increment, could do the pushpull as you click on each successive face.
        http://sdmitch.blogspot.com/
          JuanV.Soler
          ...mmm...thanks sdmitch
            How can a script 'know' which faces want which heights?
            This is a part manual method that avoids having to write an entire Tool where you pick by incrementing values.
            It minimizes the picking etc needed...
            Select all of the faces to be processed.
            Copy then Paste the one-liner [below] into the Ruby Console + <enter>
            ALL selected faces are Pushpulled by 1.05.m.
            Selection tool [spacebar], hold Ctrl+Shift and click the face[s] that are now at the desired height, so they are removed from the selection.
            Repeat the Paste with the same one-liner into the Ruby Console + <enter>
            Currently selected faces are Pushpulled by another 1.05.m.
            Repeat till done...
            This must be done ~100 times in all !
            d=1.05.m;m=Sketchup.active_model;m.start_operation('p');s=m.selection;z=0;s.each{|e|(z=e.bounds.center.z+d;e.pushpull(d))if e.is_a?(Sketchup;;Face)};m.active_entities.each{|e|s.add(e)if e.is_a?(Sketchup;;Face)&& e.bounds.center.z==z};m.commit_operation
            It is one step undo-able...
            You could make a toolbar button or a menu item from it and a shortcut key to avoid having to paste into the Console...
              JuanV.Soler
              no idea TIG
              I just thought that if you could make a random push for a lot of faces it could be possible to change the random and establish the exact distance to push.
              but,..., so far so good.
              Thanks for answering.
              • F Offline
                flyashy
                One of the things I do when I have to do a lot of these stepped pushpulls is to make a visual reference (lines, points or anything that is stacked vertically).
                That saves me the hassle of typing the values each time and just keep push pulling one by one. Just a method.
                Cheers!
                  Of course you don't have to type a PushPull value every time. a double click on a face while in PushPull will repeat the last used distance, but I accept that when the steps get more than a few multiple clicking can become tedious, so the idea of making some vertically spaced lines/guides can help a lot...
                  • W Offline
                    wyatt
                    Juan, do you have a CAD program? It might be easier to set the elevations in CAD, export back to SU, and use the Sandbox tools. Unless of course, you actually want the stepped geometry.
                    TIG, would it be possible for a script to run based on the order of the selection. For example, the script would start by asking for a contour interval, n. Then the user would select the lines, and the script would apply n1, n2, etc. based on the order that the lines were selected. There would be a problem if multiple lines needed the same elevation so the user may need to run the script more than once for a given set of contours.
                    As an alternative, is there a way to create a dialog box where the z could be user defined, similar to CAD? Ideally, this should be integrated into the entity info box by the Trimble SketchUp team.
                      JuanV.Soler
                      Cheers!
                      Yes I have been doing that too .
                      Juan,... Unless of course, you actually want the stepped geometry.
                      Yes I do sometimes šŸ˜‰
                      @sdmitch said:
                      Doubtful, since it would be difficult if not imposible to identify the order of the contours/faces. ** At best, an interactive plugin, that would accept a starting elevation and increment, could do the pushpull as you click on each successive face.**
                      sdmitch kindly sent me a script that does it and it is a time_saver Ā”
                      I do hope he posts it public
                      Cheers
                        JuanV.Soler
                        Ok thanks rami_lpm
                        getting easier to achieve the stepped geometry I am looking for .
                          @rami_lpm said:
                          Here's a plugin (another?) that does what you asked.
                          Please posts plugins in their own separate thread - they otherwise get lost when burried deep into thread like this.
                          • rami_lpmR Offline
                            rami_lpm
                            Moved the plugin Stepped Extrude to it's own post.
                            http://sketchucation.com/forums/viewtopic.php?f=323&t=48812
                            With your input, this post could be even better šŸ’—
