    [Plugin] PipeAlongPath
    122 Posts 58 Posters 168.0k Views 57 Watching
    • K
      kostas_designer
      @tig said:
      @kostas_designer said:
      I wonder if it would be possible for this very useful plugin to choose whether to erase all those construction points inside the tube structure.
      You get allot of them when you have a complex pipe path..
      No, they are there as snap-points for making connections, but there are several tools available to clear cpoints: or you could simply Delete Guides off the Menu will clear them + any clines.
      For example, use my DeleteConPointsOnly.rb or TT's SelectionToy[GuidePoints]+delete_key can do this for you...
      Personally, I have three shortcut keys that clear Cpoints, Clines and Cgeometry...
      Just to say that i discovered a nice trick:
      After finishing the command, i turn back a step by ctrl+z (or modify-undo pip's points) et voila! all control points vanished!
      Am i genius or you guys already known that 1000 years ago? πŸ’š
        One undo removes the cpoints, another undo undoes the pipe itself.
        This is OK if you have one or two to do, but if you've made lots already made then other tools are more useful to remove the cpoints later...
        • I
          inasia
          @tig said:
          After years someone (Dirk HERNALSTEEN (Hotmail)) has spotted a glitch - if you picked a forking path initially it wouldn't work again for that session... BUT it only took seconds to fix.
          Here v1.6 (zipped)
          Hi TIG,
          Many thanks for the plug in i have download, and found it useful.
          Thank you for your kind generosity. deeply appreciated,
          Cheers, have a good day
          inasia
          • C
            cedrickface
            does anyone know how/where to download the plug ins, from extention index, and how to install it to my sketchup
              Here's where the plugin is located, most plugins are located in the first post of their respective thread.
              To install you'll have to unzip to where ever you want, i'd choose your desktop. Now you'll have a folder containing the necessary files, moves these file(s) to Program Files/Google/Google SketchUp 7/Plugins
              If you've SketchUp open you'll have to close and start it again and it will be found in your Plugins Menu
              Not all plugin here are zipped, some are files ending in the .rb extension which can be placed in the directory mentioned above.
              Hope this helps
                mozzie
                Thanks. This is one of my all time most used rubies.
                Small note - when I open it in Win 7, this file is dated 12 May 2007.
                This means a "copy older over newer?" message. Or have I done something Win Weird(TM)?
                  as4m4df
                  THANKYOU SO MUCH!
                  • G
                    gunman2
                    Thank you,it is better than the same tool from Chinese Sketchup website for SU pro version 8.0 1.4346 and no problems fund.
                    • thum8sT
                      thum8s
                      Very handy tool, thx a lot, save a lot of my time πŸ˜„
                        Here's v1.7 http://sketchucation.com/forums/viewtopic.php?p=7547#p7547
                        It's completely rehashed to modern Ruby scripting standards.
                        It also has additional dialog based options to add cpoints at the nodes,
                        put the selected path onto a specified layer and move the path inside the pipe-group.
                        Enjoy...
                          raineysky
                          πŸ‘ Thank You TIG
                          • guanjinG
                            guanjin
                            Enjoy...
                            Can not be completed cross the line generated pipe
                              Guanjin
                              This is not an error! πŸ˜’
                              Please read the instructions carefully.
                              It makes simple extruded 'pipes' - NOT tubular structures: there are other tools to convert 'lines to cylinders'
                              It extrudes along a single path.
                              If you choose a path with multiple lines that 'fork' then how is it to know where to go? πŸ˜•
                              It simple uses one available path and ignores other unusable edges. 😞
                              If you want to 'pipe' the shape you show then do it in steps - the outer loop, then each 'cross' pipe.
                              You then need to form any T or X junctions manually with Intersect and Erase/Delete to tidy up. 😐
                              • guanjinG
                                guanjin
                                @tig said:
                                Guanjin
                                Thank you, TIG, I understand.
                                If able to complete the cross into a tube like,It would be nice!! 😍
                                  Arrowheadman
                                  PipeAlongPath...Very Cool!
                                  I may have missed it, but will this work on a Mac?
                                    Yes. Most scripts will work on a MAC as well as a PC - if they don't they almost always say so in their notes...
                                    • LanaL
                                      Lana
                                      Very...very, thanks. 😍
                                      • G
                                        geertpeeters
                                        I downloaded the script, unzipped it into my sketchup 8 plugins folder, but can't seem to find it in my plugins folder which I activated via the preferences. Is this not compatible with scketchup 8? I need to design a tube welded luggage carrier for a vintage motorcycle, and I'm eager to use the plugin for this.
                                          It has no issues with v8 - it's a simple tool using basic API calls and works in most available versions, and should continue on with any yet to be born...
                                          I don't understand you - the file is not 'zipped' - so needs no 'unzipping' - , it's a simple .rb file that is put into the Plugins, folder... when Sketchup restarts it's auto-loaded and appears in the Plugins menu: also when you say, '...find it in my plugins folder when I activated it via the preferences...'
                                          You just said that it's in your Plugins folder, you put it there - what path did you use ? The same as you get when you type $LOAD+PATH in the Ruby Console ? Like "C:/Program Files/Google/Google SketchUp 8/Plugins" ?
                                          You do not need to activate it in Preferences, like many simple/older tools it appears in the Plugins menu automatically - is this your confusion ?
                                          It can be a false assumption to expect a file to be where the 'explorer window' says it is - especially with Windows, because if you have restricted security permissions to the Plugins folder, it actually resides in a 'VirtualStore' - so it doesn't auto-load as it should ! Is Linux similar ?
                                          Assuming it's a simple thing to get it working for you... a bike-rack is likely to have small diameter tubes with some tight bends, this can cause issues with tools like followme when used manually, so the equivalent inside Ruby can also have issues. There are warning messages. If you get these messages, or the pipe fails, the fix is to scale up the path x10, making due allowance in the diameters too, then extrude the pipe and scale down to the original size x0.1.
                                          If you are 'joining' tubes use 'intersection' - again best during the scaled-up phase...
                                          Very tiny edges and facets [<~0.1mm] fail to be made by Sketchup/OpenGL because of tolerance issues returning two almost identical points as being the same point, and therefore no edge [and related face] gets made... Such tiny edges/facets can exist [e.g. after they are scaled down], but they can't be made.
                                          Let us know how you get on...
                                            Here's v1.8 http://sketchucation.com/forums/viewtopic.php?p=7547#p7547
                                            A code-typo glitch, that only manifested itself with a half-baked pipe group, when the selected path was a single vertical line drawn in a downward direction, is now sorted...
                                            • 2 / 7
