    How to create a Mask in Layout
    layout
    42 Posts 9 Posters 5.8k Views 9 Watching
    • cwmunroC Offline
      cwmunro
      Hi everyone,
      Quick question here. I am designing a house with a "Walk Out Basement" (in other words it's built into the side of a hill). I would like to create my side elevations that do not show any construction below grade. Can anyone instruct me as to how to create a "mask" to put over the unwanted area? Is this something I need to do before I send it to Layout or can I do it inside of Layout?
      C W Munro
      Professional Building Designer
      http://www.thealaddincompany.com
        Charles, you could do this in LO if you wish. Simply draw a rectangle or a polygon in front of the SketchUp viewport. Set its color to match the paper or background and turn off Stroke so there's no visible border. I'd put the masking shape on a layer higher in the list than the model but it could be on the same layer and just arranged to the front.
        You might also consider setting up Layers in SketchUp so that the stuff you don't want to see is on a layer that is turned off for the particular scene. That way the basement won't be seen in the viewport at all. The benefit to this is that LO won't have to render stuff you wouldn't see anyway and this will speed up especially Vector and Hybrid renders.
        • cwmunroC Offline
          cwmunro
          Thanks for the advice!
          It would be difficult to set the layer (in SU) correctly because I have it shown on the site and the terrain is pretty severe (as it is set into the side of a hill). The Basement is below grade in the front of the house and above grade in the rear. It is currently on it's own layer now but, if I turned it off, it wouldn't show up in the rear and side elevations.
          I will try to draw the grade with a freehand line and then draw the rest of the lines (of the mask) with straight lines. I could possibly hide the side and bottom lines of the mask and fill the entire box with the same color as the background - as you described. The reason for only hiding the side and bottom lines would be so that the top (freehand) line would then serve as the grade line.
          Does this sound like a viable solution?
          C W Munro
            What you describe is absolutely viable. After you draw the shape for the mask you can separate the grade line form the others by clicking with the knife tool at its ends. You might also want to make the grade line heavier and you'll be able to edit it separately from the rest.
            • pbacotP Offline
              I just did this. I have sculpted sloping site and a section of the grade is ugly with all the underside of the terrain and footings etc. seen beyond. Be sure you like your elevation view. I traced a polygon in LO along the grade with bumps, retaining walls etc. and continued down in a rectangular fashion to make a filled shape covering up the terrain below. I duplicated that and trimmed everything but the ground line, and changed that to a thick unfilled line. I found I wanted to simplify it some afterwards from the shape I used in the mask. All sorts of variations are possible, unfortunately if you change the elevation in SU...
              • cwmunroC Offline
                cwmunro
                I wound up doing something similar but, with a minor change:
                1. Draw a poly to hide the stuff I wanted to hide. Top line was drawn to represent the grade and the bottom and side lines were just drawn straight (to complete the mask).
                2. Highlight the mask border line.
                3. In the Shape Style box: Select "Fill"
                4. In the Shape Style box: Deselect "Stroke" (to hide the mask border line.
                5. Draw a new (Heavy)line to represent the Grade - tracing the top of the mask.
                Voila!
                C W Munro
                  sonder
                  Charles - that is exactly how I do it. Works really well and super fast.
                    penumbra
                    Yup. That is how i go about it as well.
                    • bmikeB Offline
                      bmike
                      you can also draw a shape in sketchup, put it on a relevant layer, and place it in front of the geometry you want to hide.
                      i do this often with shop and production drawings, hiding things behind the section cut.
                      works well for elevations / etc.
                        I thought that's what I said, Mike. πŸ˜„ You said it better, though. πŸ˜‰
                        • bmikeB Offline
                          bmike
                          guess so. i thought you were suggesting hiding geometry with layers (which i do), but it can get tricky with foundations that might stick partially out of the ground. i usually just draw in a white shape, move it in front of the geometry i need to hide, and proceed to layout.
                          all good though!
                          lots of ways to work between the 2 programs!
                            Ah. We were talking about something different after all. I was talking about drawing the shape in LayOut instead of in SU. I have created masks in SketchUp, though. Awhile back I did an animation of a sewing machine making a lock stitch. There's a mask like a mat in front of the geometry which allows components to move out of view. Most of the components are drawn 2D at different distances from the camera and some actually mask others.
                            • bmikeB Offline
                              bmike
                              and yes, sometimes is just quicker to draw over your model in layout... πŸ˜„
                              really depends on views / etc.
                              • utilerU Offline
                                utiler
                                As do I, Charles. It is the easiest way to form ground planes in section / elevation....
                                Just Curious...
                                • porch_unpluggedP Offline
                                  porch_unplugged
                                  I've just done a masks for a model with a steep enough gradient. I took the ground surface and built down below ground to create a plinth. I set up my views (2D elevations for now) using section planes, then added a section cut face to the section planes to hide all the unwanted geometry. the section cut face colour can then be changed to match the background leaving only the thick section cut line as the ground line. It was very quick to set up the 'plinth' and it gives the freedom to add and change any view with minimal extra work.
                                  hope this makes sense.
                                    Pictures, man. Pictures. Or it didn't happen. πŸ˜‰ πŸ˜†
                                      porch_unplugged
                                      here you go Dave.
                                      i kept my section cut face dark as i reckoned it looked good, especially with a light text for the drawing description placed in the dark area of the plinth (did this in autocad, not using Layout anymore, just exporting jpegs from sketchup and importing into cad, and scaling up as appropriate).
                                      the bottom of the plinth can be moved down so you don't see the second heavy line, but i'm just clipping it with a viewport in cad.
                                      full plinth shown
                                      section plane turned on
                                      section cut face layer for that elevation turned on
                                      final elevation
                                        Ah, yes. I see.
                                        Why aren't you using LayOut?
                                          porch_unplugged
                                          @dave r said:
                                          Ah, yes. I see.
                                          i've been using sketchup (free) casually for years, but really ramping up my use this year. I saw Nick Sonders video, and decided to give Layout and pro a chance. Did a full project in it to get a feel for it, but found a few things a bit annoying, slowness mostly, getting proper dimensions on 2D views, and a few other things. So i just left the trial run out, and haven't purchased the pro version (money is a bit tight for me at the minute 😞 ).
                                          so since i was doing a lot in sketchup i needed someway to properly title drawings, so just decided to import jpegs into cad and use viewports like a normal cad drawing.
                                            I see.
                                            About 90% of the work I do in LayOut involves dimensions, lots of dimensions, and I don't have any trouble getting accurate dimensions. Maybe it's just me.
                                            • 3 / 3
