    How do you create multi line text leaders???
    layout
    7 Posts 5 Posters 4.1k Views 5 Watching
      dwaynewilson
      how do you create multi line text leaders???
        Do you mean multiple leaders to the same text box? For that I create the text with the first leader. Then I select the leader and hold Ctrl (Option on Mac) and drag away a copy of the leader. That leader can be opened for editing by double clicking on it and the end points moved as needed.
          ArCAD-UK
          You might like to read this thread for further ideas...
          404 Not Found
          (sketchucation.com)
            Thanks Trevor. I suppose that's what the OP was after. I was thinking multiple arrows.
              MilfCNY
              Multiple Arrows!
              I found this thread because the IS what I want to do. If I have a label that points to one of several identical elements (like windows of a certain size, or plants on a planting plan) I'd like to use the label tool to then click on the next element and bring the line up to the existing text box. If I try that, the new arrow wants to make its own text.
              Is there a way to do that?
              -brian
                Well, you don't have to put any text in the box. Just put a space in there. I find it's just easier to copy the first leader and adjust it to point at the other object.
                • pbacotP Offline
                  Looking at this. The first idea, a leader with more than one segment, is now natively possible. (Don't recall when that change was made).
                  MifCNY method is what I have always done in CAD but that may be because the CAD tool works differently and copying out the arrow was more hassle than drawing another.
