    [Plugin] TIG-Cut_to_plane v1.1 20130107
    32 Posts 19 Posters 47.8k Views 19 Watching
      jorge2011
      tig excellent, very good tool.
      a question.
      you can think of a tool that splits into two parts to a group or component solid?
        a question.
        Another tool could first duplicate the selected object and run the 'subtract' cut twice the second time reversing the direction; thus the selected object would be split into two parts...
        I'll think about it... πŸ˜’
          jorge2011
          thank you very much.
          one question. how the tool works in the code, creates another solid and subtract?
            This tool 'Cut_to_plane' now has a sibling - 'Split_to_plane' - available here - http://sketchucation.com/forums/viewtopic.php?p=433732#p433732
            It's very similar in operation BUT it leaves both 'split' parts [A and B] in place, rather than keeping just the one...
              @jorge2011 said:
              ...one question. how the tool works in the code, creates another solid and subtract?
              Yes you define the plane, a large new group containing a circular face is made centered on the first point you picked [its size based on that point and its distance from the selected object's bound center], the face's normal vector is set from the cross of the vectors to the other two points you picked. The face is then pushpulled into a large 3d solid and then that group is subtracted from the original selected object. The new group is given the properties of the original. In the 'split' version the selected object is duplicated in place and the pushpull reversed for the second 'cut' on the duplicate - leaving the original selected object appearing to have been split along the selected plane...
              • Dan RathbunD Offline
                Dan Rathbun
                Nice job!
                I'm not here much anymore.
                • erikBE Offline
                  erikB
                  thanks TIG, very handy!
                  erikB
                  • V Offline
                    veerlexyz
                    Thanks! Almost perfect...
                    Can you make it work with a combination of groups or/and components instead of ONE solid group?
                      smicha
                      You are the man, TIG. This is amazing as all of your works. I found a link to the video presentation to your plugins.
                      It is on p. 20 of CatchUp Edition 15 - SketchUcation 2.0
                      (issuu.com)
                      • kingsiK Offline
                        kingsi
                        Many Thanks TIG
                        Noobtastic
                        • dermotcollD Offline
                          dermotcoll
                          Thanks TIG. Looks like a very useful tool for woodworking and machining worksurfaces with a CNC.
                          When you burn your arse - you gotta sit on the blisters!!
                            penumbra
                            Many thanks TIG. Is there a way to make this work on a non solid group? Or nested groups? zorro does something like what i need but is view dependent, you have to view your group from an orthogonal view if you want a "straight" cut.
                              No.
                              This tool works on solids only.
                              Zorro2 will work by slicing along a Section Plane.
                              Place one where you want and use that Zorro2 option.
                              I haven't tried nesting the plane inside the group/instance so that the cur only applies to the active entities - try it and report back...
                                penumbra
                                @TIG
                                Yes indeed, Zorro2 will cut through nested entities. There is a bit of clean up needed afterwards as some surfaces may need to be healed depending on how the section cut cuts through the objects.
                                Slicing nested groups with zorro2
                                  shri
                                  great addition to the plugins list..thanks alot..can't wait playing with it
                                  πŸŽ‰ πŸŽ‰ πŸŽ‰
                                    rv1974
                                    Thank you TIG!
                                    I wish this tool could:
                                    1. work with non-solids (I won't miss section faces anyway)
                                    2. I guess the fourth click to manually choose the side to be cut off would be even more user-friendly. No pop-ups, just a hint in status bar.
                                      penumbra
                                      @ rv1974
                                      For your #1 above you could use section tool in combination with zorro2.
                                        rv1974
                                        @penumbra
                                        Maybe the things got better, but Zorro was kinda minefield- too much crashes,- I stopped using it. And besides, 3 clicks to define the cutting plane is the nicest way to cut.
                                        • bmikeB Offline
                                          bmike
                                          Wonderful TIG!!!!
                                          • bmikeB Offline
                                            bmike
                                            how does one get this into the right click menu? would love to see it right under 'solid solver'...
                                            and, is there a way to customize my rubies so i can better order my right click menu?
                                            • 2 / 2
