    A brand new home for SketchUcation
    87 Posts 35 Posters 14.3k Views 35 Watching
    • cottyC
      cotty
      @broomstick said:
      Also, where can I inquire how to sell some of my models?
      No hints for this?
      my SketchUp gallery
      • iichiversiiI
        iichiversii
        @cotty said:
        No hints for this?
        @Cotty
        You will find your answer to this here, view topic http://sketchucation.com/forums/viewtopic.php?f=179&t=46087&start=60
        Bring on the Rain...
        • bazB
          baz
          I'm happy with the new look, but pages seem to load pretty slowly.
          Also I'm seeing 'All our ads are sketchup related, you are missing relevant content'
          Are these 'popups' or something else? I have popups blocked generally.
          Baz
          • GaieusG
            Are you using some AdBlock, Baz?
            These are no popups. We also hate popups. These are just the placeholders for the ads you are probably blocking.
            Slowness is a serious issue however. Most of the time, the pages load nicely and fast for me but occasionally, they indeed load slowly. While on the old forums, once two "gues" users (from two IP's of the same block) made so many parallel queries (i.e. scraping the site brutally) that the whole server went down. Well, we banned those IP's but this can happen any time.
              Seems there was a little problem with copy direct link of images
              between French part to English part : "link broken"
              So I upload again images on the English part πŸ˜„
              French Part
              • GaieusG
                Pilou, the French forum (and every other subforums down there actually) is "permission based" (you need to sign up to the usergroup). No wonder an attachment there cannot be seen outside that particular forum.
                Maybe we should abandon this permission system - but then all foreign language post will appear in every other member's "new posts" list (this is why we keep them permission based). I will look into some other solutions.
                • bazB
                  baz
                  Thanks Gaieus, will check my settings.
                  Baz
                  • GaieusG
                    Don't misunderstand me, Baz, I am not ranting with you for using AdBlock (I myself use it most of the times, too). πŸ˜‰
                      yes but the curious thing is that i was abble to see it when I had made the past one adress to the another one! 😲
                      So maybe some numerous another copy / past are orfan! πŸ˜’
                      I will see se if the word "broken" works in the internal seach engine πŸ˜„
                      (works but hoppefully seems there are not ofan links images in my other posts πŸ˜‰
                      Maybe this is arriving during the migration ? What was the date ?
                      • GaieusG
                        Yes, Pilou, you could see it because you are a member of the French UG and your permissions allow you to see the images included from there. πŸ˜‰
                          Ok thanks! Now I will publish images on the 2 parts! πŸ˜’
                          Not very ecologic but avoid problem! πŸ˜‰
                          And bravo for the solver of the enigma! β˜€
                          http://www.actualitte.com/images/actualites/Sherlock_Holmes_2.jpg
                          • cottyC
                            cotty
                            Is there a way to subscribe to new entries in Gallery, Shop, Tutorials,... ?
                            my SketchUp gallery
                              The rss feed in the footer
                              • cottyC
                                cotty
                                Thank you. I think I have never scrolled down until the end 😳 .
                                It worked for the shop and the tutorials, but there is no RSS icon at the gallery?
                                my SketchUp gallery
                                  No, but we will look into it.
                                  Thanks for pointing it out πŸ‘
                                  • GaieusG
                                    True that the Gallery entries are not "articles" - i.e. no RSS feed for them. I guess we should post articles about each gallery entry anyway so there should be also rss entry for them. Needs a bit of poking around but I think it's solvable.
                                    • 5 / 5
