    [Plugin] ComponentReporter+.rb
    44 Posts 11 Posters 29.8k Views 11 Watching
      Have you saved the model before trying to do this ?
      It should use the model's path as the folder for the CSV file...
      ":/component test-Component+Report.csv"
      Doesn't seem right to me ???
      I doubt you have unfettered access-rights to the root-directory ?
      If you open this SKP and copy+paste + <enter> this into the Ruby Console what do you get ?
      m=Sketchup.active_model;p m.title;p File.dirname(m.path);
      It should be
      "component test"
      then a full path to the folder that contains the SKP ?
      This should also used for the CSV file's folder-path...
      Do you have full-rights to that folder?
      Can you also put these two lines into the Ruby Console separately and post the paths...
      Sketchup.find_support_file('plugins')
      and then
      Sketchup.find_support_file('ocean_extension.rb', 'plugins')
      Also this to check where Sketchup is actually installed...
      Sketchup.find_support_file('.')
      and then this
      Dir.pwd
      πŸ˜•
        MustangSK
        Result of the first:
        "component test"
        "/Applications/Google SketchUp 8/Models"
        nil
        Result of the second:
        /Library/Application Support/Google SketchUp 8/SketchUp/plugins
        Result of the third:
        /Library/Application Support/Google SketchUp 8/SketchUp/plugins/ocean_extension.rb
        Result of the fourth:
        /Users/briancurry/Library/Application Support/Google SketchUp 8/SketchUp/.
        Result of the fifth:
        Dir.pwd
        Hope this help. Appreciate all the help.
          πŸ˜•
          Next one into the Ruby Console:
          $LOAD_PATH
          exactly as written...
            Brian, where is the SKP file you're trying to run the component report on? It appears it is in the Applications folder. What happens if you try running it on a model that is saved in Documents? I did that on my Mac and it works just fine. Perhaps the plugin can't write to the folder where the Component Test file is.
            FWIW, I use a plugin specifically designed for woodworking for this. Still, you should be able to get this to work.
            Edit: I was in a rush getting ready for work when I tested this. I didn't look as closely as I should have at where the files ended up. They ended up in the wrong location and on Mountain Lion I expect the location is not accessible by the plugin.
            Curious.
              Thanks Dave...
              I was going to suggest something else like 'CutLister' etc and get you involved...
              BUT we do need to sort out his setup and usage first...
              If anything the model SKP files ought to be in subfolders inside the Models folder...
              Most users would have them in that file path at all ???
                On my Mac most of the SKP files I create are stored in the Documents folder. The only ones that end up in applications are local component files for the Components browser. Those are saved there by dragging from In Model to the local collection in the Components browser. I'm guessing that with Mountain Lion, that directory is not accessible in the way it needs to be for Component Reporter to write to it. We see this all the time with the Plugins folder. It seems to need permissions changed from Read Only to Read & Write.
                Brian, if you are keeping your models in the Applications folder, I would suggest you don't do that.
                  This tool is 7 years old - I only just noted that you aren't trying the current version...
                  As noted in earlier posts in this thread there is now ComponentReporter++.rb.
                  This '+' tool had issues with MACs and was effectively replaced by the '++' version.
                  However, here is a '+' version [v1.7] that is MAC friendly !
                  PayPalButton
                    TIG, this version now puts the CSV files in the same location as the SKP file. πŸ‘ πŸ‘
                    Excellent work. Thank you sir.
                      MustangSK
                      Results:
                      $LOAD_PATH
                      ["/Library/Application Support/Google SketchUp 8/SketchUp/Plugins", "/Library/Application Support/Google SketchUp 8/SketchUp/Tools"]
                      The version I had downloaded was the "++" version. I was trying different locations for the file in case it was a location issue (really just shooting in the dark). I tried locating the file in the "documents" folder, same result.
                      I removed the "++" version and replaced with the "+" version, located the model file in the "documents" folder -- everything worked fine. CSV files were placed in the same folder as the model file.
                      A couple of dumb questions: SKP file is a sketchup model file? And SKP is the same as a model file?
                      A little embarrassing -- I'm very new to a Mac (1 month). I've been a Windows user for forever and work with some high end modeling software on a daily basis (ProEngineer, CATIA). I'm still trying to get a handle on file locations, permissions, read/write, etc. with the Mac. I was looking for a way to create components (pieces, part), create assemblies from them and generate a bill of material (BOM) of the parts (components). I think the cutlist would take the additional step of fitting the models to boards or sheet goods (?) -- which may be my next step.
                      Anyway, I'll give it a go. Very appreciative for all the help.
                        Brian, it sounds like you now have TIGs latest version working which is good.
                        As to your question about the SKP file, yes, SKP is used to refer to the SketchUp model file. That's because the file extension is .skp.
                        The CutList plugin I was referring to will generate a BOM and can sort into wood, sheet materials and parts when the model is properly set up. Take a look at this link for some details. The plugin will also generate files to be imported into CutList Plus which can do sheet goods optimization.
                          I've checked and both of the + and ++ versions now work fine on PC & MAC...
                            MustangSK
                            Guys, thanks again for the help. Dave -- will CutList work on the free version of SketchUP?
                              Yes. It will work on the free version.
                                MustangSK
                                Question for Dave -- I've looked into the Cut List program, works well. Is there any way to create or edit for custom board sizes, say over 12'? Thanks.
                                  At the moment, no. The author has it planned to add that feature into a future version, though. Since he has a day job and a life ( I wonder what that's like. 🀣 ) we'll likely have to wait a little bit.
                                  • 2 / 3
