    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 57.7k Views 12 Watching
    • simon le bonS Offline
      simon le bon
      Dear Aerilius,
      Thank you so much and "bravo" for this wonderful plugin that I'm sure people are going to use intensively 👍 👍 👍 😍
      The start of the discussion begins here:
      [Request]Snapshot With File Name button
      As this above thread is now closed, may I post here the last post I had made !
      @simon le bon said:
      @glro said:
      i don't understand the meaning of "save the name-1" and "save the name "+1"..
      That means that you can take not only one but a series of snapshots of the same model. They take the same file name + an incrementation. Basically you are going to use "save the name "+1"
      Aerilius_Snapshot.skp is then accompanied with
      The "save the name-1" is less evident. Previously I thought it was adding at the end of the file name a decrementation -1 -2 -3 etc..
      This was very foxy, using it with an already incremental set of skp
      if this was the skp set,
      Aerilius_Snapshot1.skp
      Aerilius_Snapshot2.skp
      Aerilius_Snapshot3.skp
      The Snapshots set was
      etc...
      But "save the name-1" don't work this way. It decrements an existing incrementation. And when there is no digit at the end of the file:
      Aerilius_Snapshot.skp gives
      Aerilius_Snapshot-1.png and after "save the name-1" overwrite this picture.. ❓ 😒
      About incrementation, there is the classic method and a better foxy one, developed here into the forums, but impossible to me to find it back (I was sure I had bookmarked it 😞 )
      *>The Classic one consists to save your WIP model with an incrementation. The most up to date one takes the higher number.
      Basically it is the set I was using above
      Aerilius_Snapshot001.skp
      Aerilius_Snapshot002.skp
      Aerilius_Snapshot003.skp
      disadvantages are: you can never be sure what really is the last file. Perhaps you worked in the office and at home, perhaps you have some files stored in another folder, perhaps a collaborator has worked on a new version, etc. ..
      *>The foxy method works with the file option " Save a copy as "
      This option offers to save the file you are working on with an incrementation but without updating the name of your model on screen.
      Using this option, the last and most updated model can be always the first one ❗ ❗ 💚 🤓
      Aerilius_Snapshot_00.skp is saved and also a "Save a copy as" is saved
      Aerilius_Snapshot_001.skp
      At the next step of the drawing, as you are always working on the "00" one, another "Save a copy as" is saved:
      Aerilius_Snapshot_002.skp
      etc..
      Very clever indeed no ?
      @Aerilius
      What I can regret is that this "Save a copy as" doesn't generates a Snapshot when Autosave is checked.
      😄 simon
        Aerilius
        It now works also in SketchUp 7 (there was a very small error that prevented that completely). The toolbars can only be changed when SketchUp is opened again (we cannot do anything about that).
        @glro said:
        An extension to the plugin might be a button that would open a specific file browser (like Xnview) and by looking through the thumbnails, would open the sketchup model by clicking on the thumbnail
        That would require to know from a thumbnail's name where the skp file is located, but it's difficult if all thumbnails are in the same folder. Better would be to integrate the large thumbnails in the operating system's thumbnail system (but I don't know how to do that on Windows, as far as I understand it would require C programming).
        Sorry, I had understood it would decrease the number (to redo older images). So instead of a minus button, you would prefer something like "increase primary version number" and "secondary version number"?
        That would be good! Unfortunately the SketchUp Ruby API tells us only what model is saved, not where. So I can get the location of the working model, not of "Save as". Good request for a next SketchUp version!
        Tell me when you find out more about the "The foxy method"...
          driven
          Works on mac,
          to attach to the skp file...
          Take your picture,
          then >> right-click on the SU title >> select the containing folder >> select the new png >> right-click >> services >> create icon and preview [need GraphicConverter installed] >> click on same_name.skp >> right click >> more info >> drag the same_name.png icon onto the more info box icon [top left] >> close more info.
          enjoy in coverflow.
            glro
            thumbnails must all be in the same folder, to create a data base from which the user can search for a skp file
            C, or java programming would be needed, yes; to create a special file browser hat would add a meta data (the link to the skp file)
            Xnview can add meta dat, but the link tothe file is not active
            meta data xnview
              glro
              maybe just a shortcut to the skp file, created by the pluging when the picture is taken, and stored in the same folder
              is it possible to create a shortcut to a file using ruby?
                Aerilius
                @driven said:
                Works on mac
                Great! I think there was once a discussion about integrate better thumbnails on OS X, as far as I remember that would require XCode and Objective C (?). I couldn't do it and can't test it.
                If GraphicsConverter has a command line interface, that would make it much easier!
                That would be almost reinventing the wheel 😉 . I would prefer using the system's thumbnailing (Windows Vista+ uses a thumbnail folder and a database). We would need to register a thumbnail to the database. As far as I know, there are only APIs for C(++, # ...) and I have not enough experience. I will see if someone else can help me, or if we can get equivalent improvements into SketchUp.
                That might be a the easiest solution! I'll try it!
                • kenK Offline
                  ken
                  Aerilius
                  Would it be possible to make the selection to save, such that I can save in a "custom folder" and the "same Folder as skp" at the same time. This way I would have the master png's in my custom folder and work related png's at the skp's folder.
                  If I know the work related folder, I would just browse at that location, if I wasn't sure or was looking for something that I haven't worked on for some time, I could go to the custom folder.
                  Also, I could print out a contact sheet for the custom folder for a hard copy.
                  So this morning, I have been opening and saving skp files to get my master folder up to date.
                  Thank you for this very helpful plugin.
                  Ken
                    driven
                    It does, and it's free[if your scint], you can also use it to extract the SU thumbnails from the .skp, but it's a bit random when Sketchup saves that, unless you want the silly 'styled' frame you get with 'save thumbnail'
                    I'll dig out the command line flags. an applescript wrapper might swap the icons...
                    • bagateloB Offline
                      bagatelo
                      There should be an option to enter the date and time automatically in the file name.
                      Thanks for this great tool.
                        glro
                        @aerilius said:
                        @driven said:
                        Works on mac
                        There is a simple way: creating a batch file, for example:
                        "@ECHO OFF
                        call F:\000_experience.sauvb\programmation\ruby\essai_plateforme.skp
                        end"
                        this opens the console
                        to avoid opening the console, write a second file
                        "var WindowStyle_Hidden = 0
                        var objShell = WScript.CreateObject("WScript.Shell")
                        var result = objShell.Run("cmd.exe /c shortcut.bat", WindowStyle_Hidden)"
                        both are text files, easy to write in ruby...
                          simon le bon
                          That's great 👍 👍
                          It seems to me that "save the name+1" already "increase secondary version number" 😒
                          nameFile_000.skp
                          when it is saved gives: (autosave checked)
                          "save the name+1" become:
                          nameFile_001.skp
                          & "save the name+1" become:
                          That's not bad to consider snapshots incrementation.
                          Redo older image is not (IMO) a very necessary option. And in facts don't work pretty good.
                          If you have a png set made with "save the name+1"
                          Then you want to redo basically the last one: nameFile_0003.png , if you use "save the name-1" It is nameFile_0002.png that is overwrited !!
                          May be only one button would be necessary which would make a clear proper incrementation:
                          nameFile_001.skp
                          when saved gives:
                          & "save the name + increment"
                          Just idea (as Jean Lemire always says 😉 )
                          Simon
                          PS:
                          _ Sorry that "save a copy as" can't autosave a snapshot. We can take few seconds to save the snapshot name manually after all.
                          _ "The foxy method" is lost for me. I have tried with the search engine in vain. May be Gaieus knows something about it! 😉
                            glro
                            @aerilius said:
                            i added some code to yours at the end of "self.save_as(filepath)" method
                            filepath2 = (filepath.split("/")[0..-2]).join("/")
                            nom_model = m.title
                            # name of the text file to put the shortcut in
                            nom_bat = filepath2 + "/" + nom_model + ".bat"
                            #open this file
                            aFile = File.new(nom_bat,"w")
                            pathmodel = m.path
                            #write the file shortcut
                            aFile.puts("call "+pathmodel)
                            aFile.puts("end")
                            aFile.close
                            a black cmd window is opened... must be closed manually, unless you embed the .bat file in a .js file...
                            it is basic but it works...
                              simon le bon
                              Sorry to disturb the coding discussion 😕
                              Ae_Snapshot tested with Su7 : love this plug 👍 👍
                              (Png transparent background option still don't work - - )
                              simonlebon
                                Aerilius
                                I forgot to mention: the transparent png option has only been added to SketchUp 8.
                                I'm working on a new version!
                                  glro
                                  > nom_model = m.title
                                  > #open this file
                                  > pathmodel = m.path
                                  > aFile.puts("end")
                                  > aFile.close
                                  Doesn't work if there is a white space in the file address
                                  additional code is needed
                                  nom_bat2 = nom_bat.to_s
                                  if nom_bat2.count(nom_bat2, " ") != 0
                                  UI.messagebox("no white space in the file address")
                                  fail
                                    Aerilius
                                    I updated the plugin. I think it will now fit all your needs because you can now make your own buttons 😉
                                    @glro, can you test if the shortcuts work as expected?
                                      glro
                                      i tested, but there might be a problem
                                      no box is opened on my scree when i check "ae snapshot" in the menu
                                      it might come from the html file
                                      in the pop up windows you show in the first message of this thread, i read "create a shortcut"
                                      but when i click on the html file in "ae_snapshot" folder, i don't see the same things
                                      html settings differences
                                        Aerilius
                                        I first thought it might have to do with upgrading the settings (because the previous version is much different). But I just tested it from 0.1.1 to 0.3.0 and it works for me.
                                        You mean the settings dialog does not appear when you click the gear icon on the toolbar (there is no ae snapshot menu). Can you open the Ruby Console, click the gear button and give me the error messages if there are any.
                                        Then copy&paste " AE::Snapshot.options={}" into the console and press the gear button again. Does it then work?
                                          glro
                                          yes, the setting dialog does not appear;
                                          the gear icon does'nt appear either...
                                          just a small reactangle where i cannot click ...
                                          how do you explain the differences between the setting dialog window i get when i double click directly on the file "settings_dialog.htm" and the one you pasted in you message?
                                          my guess is that it is linked to the problem
                                          snapshot icon
                                          • srxS Offline
                                            srx
                                            Very useful! Thank you very much.
                                            www.saurus.rs
                                            • 1 / 4
