Animation movement during render
Hi All..
using SK8 Pro.. with VRAY and Indigo.. issue I am having.. when i try to render with Vray.. the SU Animation engages autonomously. I have uninstalled/reinstalled everything.. removed Indigo.. Removed VRAY.. still no joy.. please advise. Running Win7 64.. never had this issue..
Not sure what you are asking here. I think you may have you animation button ticked on in your settings under output.
@valmach said:
Hi All..
Not a big issue,go to best settings of animation in vray,if you have other render engines as plugin in Sketchup,just go to Window > Preferences > Extensions and untick all other render engines accept the one you want to render.And one think, i didn't understand your question 100% but i tried to help you guy,may this will be helpful to you.!!!
