    FREE Maxwell Render for Sketchup (free version).
    extensions
    256 Posts 43 Posters 162.3k Views 43 Watching
    • C
      Cubcrafter
      Thanks,
      I know just enough now to be dangerous so I'm going to watch those 8 videos on the web site again and go thru the manual. They will have more meaning to me now.
      Thanks,
      Larry
      • utilerU
        utiler
        I have a question. I have edited the GE aerial image I bought into my model as well as applying transparency to my trees but when I run Maxwell, I can't work out how to show these textures / colours other than a highly polished highly reflective material!!!! 😲
        Is it something to do with my transparency?
        πŸ‘
        Just Curious...
        • jason_marantoJ
          jason_maranto
          SketchUp (SKM) material opacity lower than 100% is interpreted by the Maxwell plugin as becoming more and more "AGS" (A simple material made to mimic glass reflections) as it reduces opacity. The solution to create these type of "false transparent" materials in SketchUp to Maxwell is to use images in PNG format that contain transparency data (as an alpha channel) for creating your SketchUp objects -- the Maxwell plugin will render these PNG based "SKM" materials as normal diffuse-type materials while respecting the transparency data in the images alpha channel.
          Best,
          Jason.
          • utilerU
            utiler
            Thanks Jason, I'll give it a whirl!
            Just Curious...
            • utilerU
              utiler
              Got it, Jason!!
              Another thing; with the latest release I notice that when you click the Fire render button it starts rendering straight away... can that be changed? I recall the previous versions would allow you to edit the parameters of the render before firing up!!
              Just Curious...
              • pbacotP
                Just open the scene editor without hitting the Fire button... but I haven't upgraded yet. Doesn't that still work?
                • jason_marantoJ
                  jason_maranto
                  In the Maxwell Scene Manager>"Options" tab>"General" subsection you should see a "Start Maxwell Fire" option, which you will want to set to "Manually".
                  Best.
                  Jason.
                  • utilerU
                    utiler
                    That's what I needed, thanks Jason!!
                    Just Curious...
                    • pbacotP
                      Is the requirement for Silverlight 4 with Fire going to end soon? I now have the choice to watch movies or run Maxwell... πŸ˜• Whereas it's so slow I would like to do both at once πŸ˜„
                      • jason_marantoJ
                        jason_maranto
                        Silverlight is being phased out -- the Grass palette is a preview of this, as per this post: http://www.maxwellrender.com/forum/viewtopic.php?p=357436#p357436
                        Best,
                        Jason.
                        • pbacotP
                          Thanks Jason! That's interesting and good to hear. Peter
                          • utilerU
                            utiler
                            Am I right in saying that Maxwell doesn't recognize section cuts and hence won't render floor plans?
                            Just Curious...
                            • jason_marantoJ
                              jason_maranto
                              Maxwell does not currently recognize section cuts (because they are not real geometry) -- Maxwell has something similar called Z-Clipping, which can be used for floor plans... however it's worth noting that Maxwell also has some issues with non-perspective based camera views. So a true floor plan would be tricky (though if you are willing to accept a slight fudge factor it can be done).
                              Best,
                              Jason.
                              • utilerU
                                utiler
                                Thanks Jason,
                                Are you talking about the full Maxwell Suite or Maxwell for SketchUp?
                                As for non perspective based views I guess I could wind out the FOV to near 0 and render..? πŸ‘
                                Just Curious...
                                • jason_marantoJ
                                  jason_maranto
                                  Both. Maxwell cameras always operate in 3-point perspective, so orthographic and 2-point perspectives are "approximate" matches... which is often close enough. The plugin should automatically make the adjustments for you.
                                  To be clear about what I said before: you can setup section cuts using SketchUp, but you would have to "bake" them into the geometry, either manually or via a plugin.
                                  Best,
                                  Jason.
                                  • utilerU
                                    utiler
                                    Thanks Jason, you're da Maxwell Man!!!!!
                                    Just Curious...
                                    • peterboodtsP
                                      peterboodts
                                      Small (dumb?) question.
                                      When I add a picture to an object in sketchup and render using Maxwell for Sketchup then the image doesn't render.
                                      Do I do something wrong ? or do I need to set some settings to make it work ?
                                      Peter
                                      • jason_marantoJ
                                        jason_maranto
                                        Could you clarify exactly how you are adding the picture?
                                        Best,
                                        Jason.
                                        • utilerU
                                          utiler
                                          Hi Jason, Is there a way to view the mxm files from the Insert dialog box? [See attached screenshot]
                                          Would be nice to know what the materials look like rather than relying in names...
                                          πŸ‘
                                          Just Curious...
                                          • jason_marantoJ
                                            jason_maranto
                                            The full render suite installs a thumbnail viewer so that you can view the material previews like you would any other program thumbnail... however I'm pretty sure the stand-alone plugin does not have this due to the lack of MXED.
                                            I really feel like the lack of MXED is crippling to the stand alone version and I hope this is resolved somehow in future updates... as a user of the stand alone plugin my number one request would be to either improve the material editing controls in the plugin itself or include MXED in the package and I would make those requests directly here:
                                            http://www.maxwellrender.com/forum/viewforum.php?f=127
                                            If enough users make the request I'm sure something would happen.
                                            Best,
                                            Jason.
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
