    [Plugin] Add Height from Datum
    46 Posts 20 Posters 68.7k Views 20 Watching
      Here's v1.2
      http://forums.sketchucation.com/viewtopic.php?p=193238#p193238
      It now shows existing datum in the dialog, has a modified leader etc.
      Note the added 'Tip' on relocating the height-text...
      Next big change... is to make it 'dynamic' so that it always shows the height it is at... so if you do move it in the Z it changes it's value to suit...
      • JClementsJ
        JClements
        Dynamic leader text. WOW!
        Thank you, TIG
          Here's v1.3
          The main change is that the height-text is 'dynamic' and updates to show the current arrowhead Z-level above datum if the text is relocated. There's also a conversion tool to update any earlier height-text etc... read notes with the download page...
          • JClementsJ
            JClements
            Pretty neat and I never knew you could use the text tool to move leaders (how long have I been using SU?).
            Probably not a bug, but the dynamic leader doesn't update if inside a group.
              It doesn't update because the height-text hasn't been changed/moved ifthe group has been been moved - this is because the group's origin is where it was before and the height-text refers to that.
              However, a piece of height-text should update if it's moved inside the group whilst the group is being edited: therefore to update all edit the moved group and 'select all' and Move the selection by 0 to kick it into an update...
              However, I'll look at a tweak to see if I can get it to work better within groups etc...
              • kenK
                ken
                Thanks for the very useful plugin. I do a illustrations of underwater structures. Would it be possible to “right-click” to set the baseline to the last measurement, such that all further measurement use the new baseline as the “0 ft reference”.
                Again, thank you
                Ken
                • T
                  tranbathao
                  thanks TIG, really useful
                  • P
                    Phil Rader AIA
                    Wow this is JUST what I need and you guys are always years ahead of me developing things I cant even imagine I need right now....but I will need it in the future.
                    http://www.philrader.com
                    • P
                      Phil Rader AIA
                      TIG I've been having some bug splats when I move the text in the datum text using the text command. I'll try to narrow down a repeatable crash and let you know.
                      • pbacotP
                        This is very handy. Been using it lately. Thanks!
                        I notice the text seems to "show through" other objects. If you have it inside a house you can see it from outside. Is that special feature? Unusual.
                          It's plain Text - it does that - try it with some 'ordinary' Text and you'll see how that does it too...
                            OK, that's the first report like this - I can't replicate it.
                            If you move it with 'Move' rather than using the 'Text' relocation facilities [needed to 'lock' the arrow-head onto an object - because this can't be done easily in the API]... is it then OK ?
                            Let me know what you find...
                            • U
                              unclex
                              could add a datum symbol?
                              such as a component skp file, can defined by user
                              • W
                                Woodarc
                                How do I load this plugin please?
                                  There is a .rb file in the first post in this tool's thread. Download that file.
                                  Move it into the Sketchup Plugins folder and restart Sketchup...
                                  It then auto-loads and adds two items to the Plugins Menu '>>Add Height above Datum' and '>>Set Datum'.
                                  Read the tool's instructions on the download page, and others' useful advice in this thread too...
                                  NOTE: that since you on a PC you must ensure that you have FULL access rights to the main Plugins folder.
                                  To check/fix this - select its icon in Windows Explorer, context-menu > Properties > Security > Edit...
                                  Being an Admin is NOT enough to ensure things go smoothly.
                                  A file might look to you that it's got put into the Plugins folder, but if you have limited access-rights then Windows may have put it into a VirtualStore - a 'Compatibility Files...' [or similar] button/link in the folder's Windows Explorer top bars is a sure sign of problems...
                                  Also have the same FULL rights set for the Components, Materials and Styles folders, since you will also want to write files to these from time to time...
                                  • C
                                    caronte01
                                    I really like this one. Very useful.
                                    Tig, thanks a lot!!!
                                    Santiago
                                    • JClementsJ
                                      JClements
                                      Hi TIG,
                                      Would it be possible to have the Eye Height function of the Look Around tool respect the Datum set by this script? So, for instance, if I set the datum of the origin at 236' 7 1/2", I could input 336' 7 1/2" for eight Eye Height and the camera would rise to 100' above the origin.
                                        Sorry John - no easily 😞
                                          Here's v2.0
                                          http://sketchucation.com/pluginstore?pln=heighttool_datum
                                          It has been updated [after 8 years !]
                                          It's now in a module, avoids global variables etc.
                                          It's also signed for v2016/2017 compatibility in all Loading Policies...
                                          The tool now sets up a submenu in the Plugins|Extensions Menu, its item
                                          'Height Above Datum > Add Height Above Datum' is the main tool.
                                          On selecting it this will become the active tool.
                                          Hovering on a point shows its height above datum (default z=0=ground plane).
                                          Clicking the left mouse button adds a text label with that height
                                          Selecting another tool will stop this being the active tool
                                          Change the tool's Datum using 'Height Above Datum > Set Datum' submenu item
                                          This datum is remembered with each Model as an Attribute.
                                          Any preexisting labels are updated to reflect the new datum.
                                          Convert selected text into height labels using the submenu item
                                          'Height Above Datum > Make Selected Text Dynamic'
                                          Moving a height label vertically changes the height shown in it.
                                          Height labels have an observer attached which auto-updates them.
                                          The observers now properly attach to models/tags irrespective of the way way they are [re]opened...
                                          • JClementsJ
                                            JClements
                                            TIG, first of all, thank you!
                                            Three suggestions for an update:
                                            1- Would it be possible to add to the submenu, an option to specify a new (or existing) layer the leader text would automatically be assigned too?
                                            After using the plugin, a lot for all these years, I find that the text can get in the way at times but is still is required. So being able to turn it off for certain scenes via the Layer Manager is the answer ... but I often forget to change layers before using the plugin.
                                            2- Ability to add prefix-text to a leader's text with descriptors such as "TOS" (top of slab) or "Pipe Invert" . That text would remain even if attached to geometry that is moved but could later be edited manually by the user.
                                            3- Instead of creating the leader with a mouse-click, have it created via click-and-drag. With the current version, many times I have to adjust the leader's position with the text tool immediately after placing it with the mouse-click.
                                            • 1 / 3
