    A special selection function
    12 Posts 6 Posters 347 Views 6 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi skp-experts,
      i am looking for a really special function.
      please imagine a mesh , even turned in 3d-somehow, where you switch off all softening and can see the mesh as a grid of lines in 3d. with the selector one can delete the planes, so only a line grid remains....
      now, i would like to pick up ONE line going from 1 end of the mesh grid to the other.
      my mesh is 500 m high, a spiral and it is absolutely impossible to do that by hand.
      so, is there a ruby, which is able to pick up one "string" of a mesh from start to end?
      this would help a lot...
      thanx stan
      • sdmitchS Offline
        sdmitch
        Could you supply a model with a sample of the spiral mesh for testing?
        http://sdmitch.blogspot.com/
          Depending how are your segments of spiral
          if then don't touch any other a simple double click is sufficient ๐Ÿ˜‰
          Else look at Selection Toys by Thomthom
          if each segment of the spiral is similar take look at
          select line by length by Chris Fullmer
            artmusicstudio
            YES, of course, thank you very much......
            i prepaired an example , so let 's try...
            regards stan
            testfile for spiral-string-copying
              artmusicstudio
              thank you, i will check this. for my job the plugin must be a sort of intelligent to be able to decide, which direction the string goes, it's rather tricky. because of the geometry of a spiral a simple selection by rectangle or anything else does not work.
              regards stan
                Thomthom's "QuadFaceTools" [see the Plugins Index...] lets you pick connected 'loops' like your spiraling paths.
                I just tested it on your faced version [it needs the faces!] and I selected the spiraling edges quite easily...
                • cottyC Offline
                  cotty
                  If you own the plugin SketchUV (Whaat), you can doubleclick on one line with the path select tool:
                  my SketchUp gallery
                  • mitcorbM Offline
                    mitcorb
                    Hey, Pilou:
                    Exactly who/what popped into my mind when he mentioned spiral mesh.
                      Maybe you will be interested by this method for make a spiral and its selection ๐Ÿ˜‰
                      [flash=560,315:2lcm8c4v]http://www.youtube.com/v/pNTetL3Udkc[/flash:2lcm8c4v]
                        That is a very good method and very versatile โ˜€
                        Just use the scale tool after and you will obtain an infinity varieties of spirales! ๐Ÿ˜Ž
                          artmusicstudio
                          hi tig, YEEEAAHHHHHH! that's it, wonderful. works perfect.
                          thanx stan
                          ps: i will also check all other tips from the other guys, thanx forhelping to all of you....
                            artmusicstudio
                            hi, yes , the thomthom - tool in quadfacetool does exactly , what i needen now.
                            the next search is an intelligent "follow-path" tool, i will start another topic for that
                            thank you very much!
                            stan
