    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.3k Views 107 Watching
    • beginnerB Offline
      beginner
      Hi Guys,
      I would like to draw your attention to the 'shapes' in tak2hata's plugin - look at the Class SHAPE and the profiles defined as *.SKP files.
      You can draw any complex shape as long is contained within single face - sample below.
      Regards, SU 'beginner'
      • sumasterS Offline
        sumaster
        @tak2hata said:
        Hi,Sumaster.
        Adding toolbar like previous version has not done well yet.
        I gave priority to correction of a bug and update.
        wait while.
        Hi Tak2hata,
        wow nice update . . . . πŸ‘
        Extend to Face tool is working perfectly . . . . but
        Extend to Structure is not working properly . . .
        CHK
        I add some items in plugin menu . . . πŸ˜‰
        please add all previous item in plugin menu
        tst_main_menu = UI.menu("Plugins").add_submenu("#{langconv( 'BS Tool - 1.0' )}")
        tst_main_menu.add_item("#{langconv('>> Extend to Face')}") { Sketchup.active_model.select_tool TST1_class_extend_face.new( false ) }
        tst_main_menu.add_item("#{langconv('>> Extend to Structure')}") { Sketchup.active_model.select_tool TST1_class_extend_str.new }
        tst_main_menu.add_item("#{langconv('>> Growup to Face')}") { Sketchup.active_model.select_tool TST1_class_grow_face.new( false ) }
        tst_main_menu.add_item("#{langconv('>> Combine Each')}") { Sketchup.active_model.select_tool TST1_class_chamfer.new }
        tst_main_menu.add_separator
        And thank you so much for this plugin . . . . πŸ˜„
        i use your plugin daily . . . .
        its save my basic modeling time . . . too good . . . .
        Thank you,
        SUmaster
        • V Offline
          victor hugo
          Does anyone know where to find more RC_WALL options for the BST, when I installed it (which is very useful BTW) it only shows 4 options?
          Thanks.
            CTMan
            @tak2hata said:
            Hi,CTman.
            You are welcome!
            If you upload the PFC profile file here , I will create link to your post in top of thread.
            Your PFC profile file will help users of BST!
            Hello Tak2hata - please find attached csv file for British Steel Beams and Columns
            Hi,Sumaster.
            I also checked the bug.
            I will fix the problem within several days.
            And I will update here.
            Thanks.
              tak2hata
              Hi,CTMan.
              I add link to your reply in the top of thread.
              Thanks a lot for uploading your profile list of UK STEEL.
              Channel([) have tapered flanges when the schema is like "[-100x50x5x7.5x8x4"
              Channel([) have not tapered flanges when the schema is like "[-100x50x5x7.5"
              So If you want to not tapered flange Channel,the schema is like "[-AxBxCxD".
              Hi,sumaster.
              "Extend to structure" tool works extending the structure to the other structure.not to face.
              extending to structure.
              Using "Extending to Face" to extend like this picture takes time and effort.
              So "Extend to Structure" exists for that purpose.
              I see the "undo" problem.
              I will fix it few days.
              Thanks.
              by TAK2HATA
              • sumasterS Offline
                sumaster
                @tak2hata said:
                Hi,CTMan.
                Hi,sumaster.
                [attachment=0:165mbbk2]<!-- ia0 -->extending_to_structure.JPG<!-- ia0 -->[/attachment:165mbbk2]
                Thanks.
                yes
                and another problem facing here . . .
                i upgrade your new version but when i OPEN my OLD version file means (i was working your old BS tool) and exend to face and other 3 tools are not working good . . .
                Pleas CHK
                Thank you,
                SUmaster
                  tak2hata
                  @sumaster said:
                  yes
                  Pleas CHK
                  Hi,Please upload your data include problems.
                  The part to limit the problem entities.
                  by TAK2HATA
                  • sumasterS Offline
                    sumaster
                    @tak2hata said:
                    @sumaster said:
                    yes
                    Pleas CHK
                    Yes . . .
                    Please CHK the Compound wall . .
                    Sept11 2012 _3 (For Tak2hata) .skp
                    Thank you,
                    SUmaster
                      tak2hata
                      Hi,All.
                      I update to version1.2. in Sep17,2012.
                      v1.2:2012.09.17:
                      Bugs? fixed.and Improves.
                      #Fix:Undo when Multi(Extend/Chamfer/Grow).
                      #Fix:Undo when change properties of many entities.
                      #Fix:(Extend/Chamfer/Grow) Structure entity which have devided side by user.
                      #Improve about create slab.
                      Hi,Sumaster.
                      In your file ,there was no compound wall.
                      But the wall's edge was cutted by your manipulation.It do not good for "Extend tool" in previous version.
                      It was improved in this ver.
                      Thanks.
                      by TAK2HATA
                      • sumasterS Offline
                        sumaster
                        @tak2hata said:
                        Hi,All.
                        v1.2:2012.09.17:
                        Thanks.
                        Hi Tak2hata
                        Thanks you πŸ‘ πŸ˜‰
                        And I'm CHKing Now
                        @tak2hata said:
                        Hi,Sumaster.
                        Thanks.
                        Oh. . . .
                        and here the new tool get random color
                        how i fix the color means ( Walls get White, Steel Member get Medium Red, . . etc )
                        Thank you,
                        SUmaster
                          tak2hata
                          Hi,all.
                          I attach CTMan's UK Steel pflist file on top of this thread.
                          It will helps Building structure tool users.
                          Thanks.
                          by TAK2HATA
                            SUFractal
                            I just upgraded to the latest version, but am no longer able to access "steel columns" in the North American List? Other elements appear to work fine.
                              tak2hata
                              Hi,Sufractal.
                              In my enviroment,"Steel Column" shown from "North American pflist" no problem.
                              Check the line include "##" in the csv file, If you edited it.
                              "##STEEL_COLUMN" is needed.
                              so, send to me your profile list or upload here it.
                              and I will look it.
                              Thanks.
                              by TAK2HATA
                              • sumasterS Offline
                                sumaster
                                HI ,
                                How i fix the color of BST wall . . . ?
                                now its get random color . . .
                                Thank you,
                                SUmaster
                                  SUFractal
                                  @tak2hata said:
                                  Hi,Sufractal.
                                  and I will look it.
                                  Thanks.
                                  i believe I used the correct text in the file?
                                    tak2hata
                                    @sufractal said:
                                    @tak2hata said:
                                    Hi,Sufractal.
                                    and I will look it.
                                    Thanks.
                                    I tested it working fine.
                                    Steel Column shown fine.
                                    I judge that it is fine by looking only that picture.
                                    The last advice I say is "Change Profile list path" and select it again.
                                    The information about this problem is too small.
                                    Is there anyone had same problem?
                                    and please reply here.
                                    Thanks.
                                    by TAK2HATA
                                    • H Offline
                                      hygicell
                                      excellent tool, but not (yet) working for me:
                                      I cannot find an installation manual
                                      nor a user manual
                                      and where do I put the .csv files?
                                      please help
                                      Frank
                                      • MasterhandM Offline
                                        Masterhand
                                        Excellent tool. I worked great.
                                        Does anyone know if there is a plugin that allows easily verify whether a modulation structure, or structure, if feasible or still standing?.
                                        To just have a quick overview or a quick sample of what model can work it without having to do the entire calculation of the structure (which will be done later).
                                        So, I mean, for example: look, without calculating it yet, I can show that it may be feasible or holds
                                          tak2hata
                                          nor a user manual
                                          please help
                                          Frank
                                          Hi, hygicell.
                                          Please puts ".csv"file to folder you like.but windows special folder is not recommended.
                                          The windows special folder is like "C:\program files" "C:\Windows".
                                          Mac user do not mind this.
                                          After puts it,You must "Change profile list path" from plugins menu.
                                          and select the file.
                                          Hi,Mastarhand.
                                          Me,too.
                                          Hi,all.
                                          I will update this script after few days.
                                          Thanks.
                                          by TAK2HATA
                                            tak2hata
                                            I update to version 1.4beta.
                                            I add usefull function "Table Editor".
                                            and improves.
                                            enjoy. πŸ˜„
                                            by TAK2HATA
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
