    Where to start?
    44 Posts 4 Posters 3.5k Views 4 Watching
      rumcajs
      I go through SU examples.
      So Utilities - Create Faces ... utilitiestools.rb
      ss = Sketchup.active_model.selection
      # Get an Array of all of the selected Edges
      edges = ss.find_all { |e| e.kind_of?(Sketchup;;Edge) }
      So here the "e" means output of the find_all method, so what the loop produces in the moment of its cycle. I thought that it is definition of the input or some argument for input! But recalled that I asked on it on previous page. It seems to me that it is like loop, similar like .each { |e| e.some.action.here}
      • Dan RathbunD
        Dan Rathbun
        edges holds the output of the find_all method, which is a new Array of the items that were found.
        |e| is the block parameter list, which is passed into the block by the Ruby keyword yield.
        The number of block parameters can vary from one block method to another.
        This is an example of what the find_all method would look like, if it was written in Ruby (but it is actually written in C.)
        class MyArray
          def find_all
            raise(ArgumentError,"no block given!",caller) unless block_given?
            found = []
            self.each {|item|
              # call the block using yield, passing in item
              # if the block returns true via yield,
              # push the item into the found array.
              found << item if yield(item)
            return found
        I'm not here much anymore.
          @rumcajs said:
          Well, helpful. I found one plugin in my folder, which is in global namespace.
          > if (e.typename=="Edge")
          Not only is it in global namespace - it uses typename to identity the type of entity (which many plugin does because the API docs sets a very poor example.) .typename is very very slow - avoid at all cost! More details: http://www.thomthom.net/thoughts/2011/12/never-ever-use-typename/
            rumcajs
            Exactly. I am reading it just in the first link (http://forums.sketchucation.com/viewtopic.php?f=180&t=10142) in the first response in this thread.
            • Dan RathbunD
              Dan Rathbun
              Use puts statements in the code, to output to the Ruby Console.
              • Dan RathbunD
                Dan Rathbun
                @rumcajs said:
                I would like to see what contains @iptemp.
                It is an Sketchup::InputPoint instance object. See the API dictionary.
                  rumcajs
                  What debug tools and methods can I use to debug method?
                  Example, utilitiestool.rb
                  class TrackMouseTool
                  method onMouseMove
                  @iptemp.pick view, x, y
                  Is it possible to show dialog box or pause code?
                    rumcajs
                    If I change code of the plugin, will it be refreshed automatically or must I reload the plugin and how?
                      Reload it manually.
                      load 'myfile.rb'
                      Though I think Jim created a utility to autoreload after changes where detected. Never used it though as I prefer the manual control.
                        rumcajs
                        OK. Works. So I tried:
                        puts @iptemp
                        #Sketchup::InputPoint:0xd0fe6fc
                        So the input point is in hexadecimal format? If I would want to read it, I would need to add method to convert to decimal, right? I tried:
                        puts @iptemp.hex
                        returns error
                          No - the hex number you see there is the hexadecimal version of the object id. Ruby convention.
                          Refer to the API manual and you find InputPoint.position
                          https://developers.google.com/sketchup/docs/ourdoc/inputpoint#position
                            rumcajs
                            Ah, now it works.
                            puts @iptemp.position
                            Something I miss in the reference manual. From different languages I am used to see above every method a list of similar or related methods/links.... Is here some similar page which gives such kind of information / organized in different way? Or is this the only source?
                              rumcajs
                              What does mean $ is it global variable? I thought it is array, but now I see they use it in different way.
                              This:
                              results = inputbox prompts, values, $exStrings.GetString("Cost Estimate")
                              What is inputbox, does not look like method of global scope
                                Each class list all its methods.
                                List of classes:
                                https://developers.google.com/sketchup/docs/classes
                                List of methods:
                                https://developers.google.com/sketchup/docs/methods
                                Object Diagram:
                                https://developers.google.com/sketchup/docs/diagram
                                  This:
                                  $ is global variables, yes. Avoid them.
                                  inputbox is an alias for UI.inputbox defined in sketchup.rb which comes with SketchUp. (I use UI.inputbox simply because of potential problems of relying on the methods in the global namespace.)
                                    rumcajs
                                    Hm. I see. Sketchup.rb is short, so it will not be problem to remember it. And where is definited UI?
                                      That's from the API - defined in C++.
                                      Look to the documentation: https://developers.google.com/sketchup/docs/ourdoc/ui
                                      • 2 / 3
