    Where to start?
    44 Posts 4 Posters 3.3k Views 4 Watching
      @rumcajs said:
      Well, helpful. I found one plugin in my folder, which is in global namespace.
      > if (e.typename=="Edge")
      Not only is it in global namespace - it uses typename to identity the type of entity (which many plugin does because the API docs sets a very poor example.) .typename is very very slow - avoid at all cost! More details: http://www.thomthom.net/thoughts/2011/12/never-ever-use-typename/
        rumcajs
        Exactly. I am reading it just in the first link (http://forums.sketchucation.com/viewtopic.php?f=180&t=10142) in the first response in this thread.
        • Dan RathbunD Offline
          Dan Rathbun
          Use puts statements in the code, to output to the Ruby Console.
          I'm not here much anymore.
            Dan Rathbun
            @rumcajs said:
            I would like to see what contains @iptemp.
            It is an Sketchup::InputPoint instance object. See the API dictionary.
              rumcajs
              What debug tools and methods can I use to debug method?
              Example, utilitiestool.rb
              class TrackMouseTool
              method onMouseMove
              @iptemp.pick view, x, y
              Is it possible to show dialog box or pause code?
                rumcajs
                If I change code of the plugin, will it be refreshed automatically or must I reload the plugin and how?
                  Reload it manually.
                  load 'myfile.rb'
                  Though I think Jim created a utility to autoreload after changes where detected. Never used it though as I prefer the manual control.
                    rumcajs
                    OK. Works. So I tried:
                    puts @iptemp
                    #Sketchup::InputPoint:0xd0fe6fc
                    So the input point is in hexadecimal format? If I would want to read it, I would need to add method to convert to decimal, right? I tried:
                    puts @iptemp.hex
                    returns error
                      No - the hex number you see there is the hexadecimal version of the object id. Ruby convention.
                      Refer to the API manual and you find InputPoint.position
                      https://developers.google.com/sketchup/docs/ourdoc/inputpoint#position
                        rumcajs
                        Ah, now it works.
                        puts @iptemp.position
                        Something I miss in the reference manual. From different languages I am used to see above every method a list of similar or related methods/links.... Is here some similar page which gives such kind of information / organized in different way? Or is this the only source?
                          rumcajs
                          What does mean $ is it global variable? I thought it is array, but now I see they use it in different way.
                          This:
                          results = inputbox prompts, values, $exStrings.GetString("Cost Estimate")
                          What is inputbox, does not look like method of global scope
                            Each class list all its methods.
                            List of classes:
                            https://developers.google.com/sketchup/docs/classes
                            List of methods:
                            https://developers.google.com/sketchup/docs/methods
                            Object Diagram:
                            https://developers.google.com/sketchup/docs/diagram
                              This:
                              $ is global variables, yes. Avoid them.
                              inputbox is an alias for UI.inputbox defined in sketchup.rb which comes with SketchUp. (I use UI.inputbox simply because of potential problems of relying on the methods in the global namespace.)
                                rumcajs
                                Hm. I see. Sketchup.rb is short, so it will not be problem to remember it. And where is definited UI?
                                  That's from the API - defined in C++.
                                  Look to the documentation: https://developers.google.com/sketchup/docs/ourdoc/ui
                                  • 2 / 3
