    Where to start?
    44 Posts 4 Posters 4.3k Views 4 Watching
      rumcajs
      Something else confused me. But i think I had overlooked something. The ratings are not saved in values, but in ratings...
      Things are going bad, I cannot move on.
      #<SyntaxError; Invalid char "\xC2" in expression. near line 1; "\xADread(\"/Hom\xC2\xADe/comics.t\xC2\xADxt\")">
      > print File.­­read("/co­mics.t­xt"­)
      #<SyntaxError; Invalid char "\xC2" in expression. near line 1; "\xADread(\"/comics.t\xC2\xADxt\")">
      > print File.­read("comi­cs.txt")
      #<Errno;;ENOENT; No such file or directory - comics.txt>
      > Dir["/*"]
      Open up a new BlogEntry class, pretty pretty please.
      How can I print what is in /home/comics.txt and /comics.txt and if they exists and why this error happens...
        rumcajs
        Whatever i write it jumps into input mode:
        comics.is_­a
        .. end
        > comics.is_­a?
        Damn, that's not 15 minutes tutorial, but 15 hours (I'm in half but cannot move on).
        > Popup.make­ do
        .... h1 "Header"
        .... list do
        ...... comics.eac­h do |name­, url|
        ........ link name,­ url
        ........ end
        ...... end
        .... end
        Should generate web page, but nothing popups. And I cannot check if the array exists, what is in array, what is in directory or if the file exist... Look like not realy ruby console (running in browser). 👎
        • Dan RathbunD
          Dan Rathbun
          defined?(comics)
          tests for existance
          comics.is_a?(Array)
          or
          comics.instance_of?(Array)
          or
          comics.class==(Array)
          tests the class of the comics object
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            You cannot assume that the current working directory is what you wish it to be (because another plugin may have changed it.)
            Be sure a HOME environment var is defined on PC (it is always defined on Unix-like systems, such as OSX.)
            unless RUBY_PLATFORM =~ /(darwin)/i
              ENV["HOME"]= ENV["USERPROFILE"] unless ENV["HOME"]
            oldDir = Dir.getwd()
            Dir.chdir(ENV["HOME"])
            if File.exist?('comics.txt')
              lines = IO.readlines('comics.txt')
              puts(lines)
            else
              puts("'comics.txt' could not be found.")
            Dir.chdir(oldDir)
            or use the **~** shortcut (if you KNOW that a HOME environment var is defined.)
            filepath = File.expand_path('~/comics.txt')
            if File.exist?(filepath)
              lines = IO.readlines(filepath)
              puts(lines)
            else
              puts("'#{File.basename(filepath)}' could not be found in dir;\n#{File.dirname(filepath)}.")
            • Dan RathbunD
              Dan Rathbun
              Because you NEED to read "Programming Ruby: The Pragmatic Programmer's Guide"
              You need to take a WEEK OR MORE getting comfortable with Standard Ruby, before attempting to learn to use the SketchUp API.
              I wrote the "Ruby Newbie's Guide to Getting Started" to help you and others avoid the frustration you are experiencing.
              Follow the guide and you will be much happier.
                When it comes to the Ruby API I have a few articles on my blog - don't think they are liked in the sticky threads.
                I recommend new plugin developers to read this one first: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
                  rumcajs
                  I run this "Ruby" in Browser, this is not in SU. It is tutorial - interactive online guide which is called "15 minutes tutorial"
                  http://tryruby.org/levels/1/challenges/0#levels/8/challenges/3
                  So I am not sure if the ruby runs there or it is just simulation of Ruby in Javascript or Flash. So as they say, the path is preconfigurated, and I checked before that the path and files were there. Now I am on next lesson.
                   blog = [entr­y, entry­2]
                  => [#<BlogEntry;0x72e8e4f7 @fulltext="I can't believe Mt. Hood was stolen! I am speechless! It was stolen by a giraffe who drove away in his Cadillac Seville very nonchalant!!", @time=2012-09-16 15;55;25 +0000, @title="Today Mt. Hood Was Stolen!", @mood=;sick>, #<BlogEntry;0x18104f11 @fulltext="I am
                    never going back to that mountain and I hope a giraffe steals it.", @time=2012-09-16 15;55;25 +0000, @title="I Left my Hoodie on the Mountain!", @mood=;confused>]
                  Success!
                  > next
                  > blog.sort_­by { |entr­y| entry­.time}.rev­erse
                  [#<BlogEntry;0x263b3097 @title="I Left my Hoodie on the Mountain!", @time=2012-09-16 15;57;13 +0000, @fulltext="I am\
                    never going back to that mountain and I hope a giraffe steals it.", @mood=;confused>, #<BlogEntry;0x77f31d1c @title="Today Mt. Hood Was Stolen!", @time=2012-09-16 15;57;13 +0000, @fulltext="I can't believe Mt. Hood was stolen! I am speechless! It was stolen by a giraffe who drove away in his Cadillac Seville very nonchalant!!", @mood=;sick>]
                  Success!
                  > back
                  > blog.find_­all {|ent­ry| entry­.fulltext.­match(/cad­illac/i)}
                  [#<BlogEntry;0x68f04725 @title="Today Mt. Hood Was Stolen!", @time=2012-09-16 15;58;56 +0000, @fulltext="I can't believe Mt. Hood was stolen! I am speechless! It was stolen by a giraffe who drove away in his Cadillac Seville very nonchalant!!", @mood=;sick>]
                  Success!
                  > blog.find_­all {|ent­ry| entry­.fulltext.­match(/Mt.­{2,10}/i)}­
                  => [#<BlogEntry;0x5ac78f1f @fulltext="I can't believe Mt. Hood was stolen! I am speechless! It was stolen by a giraffe who drove away in his Cadillac Seville very nonchalant!!", @time=2012-09-16 15;59;49 +0000, @title="Today Mt. Hood Was Stolen!", @mood=;sick>]
                  Success!
                  > back
                  > blog.map { |entr­y| entry­.mood}
                  [;sick, ;confused]
                  Success!
                  So want to ask what is the entry in pipelines? |entr­y|
                  I defined entry and entry2 as instance of my little blog class. Blog is array containning entry and entry2, but I ask about what is meanning for |..| in these methods. It looks like it is name of class.
                    rumcajs
                    @dan rathbun said:
                    The frustration is from the Interactive guide, because it didn't work in the fully meaning of ruby console. SO I could not check what I did. But I closed the window, and moved.
                      rumcajs
                      Well, helpful. I found one plugin in my folder, which is in global namespace.
                      #this part is taken (after a little modification) directly from the script Skin by Darrel Belvin so all credit is his (hope he doesn't mind me posting this)
                      def clean_up
                      	Sketchup.active_model.start_operation "Clean-up"
                      	ss = Sketchup.active_model.selection.collect
                      	erasee = []
                      	ss.each {|e|
                      		if (e.typename=="Edge")
                      			if((e.faces.length==0)|| (e.faces.length==2 && e.faces[0].material==e.faces[1].material && e.faces[0].normal.parallel?(e.faces[1].normal)))
                      				erasee.push e
                      	erasee.each {|e|
                      		e.erase! if(e.deleted? == false)
                      	Sketchup.active_model.commit_operation
                      	return
                      if not (file_loaded? "cleanup.rb")
                      	clean = UI.menu("Plugins")
                      	clean.add_item("Clean-up") {clean_up}
                        rumcajs
                        I go through SU examples.
                        So Utilities - Create Faces ... utilitiestools.rb
                        # Get an Array of all of the selected Edges
                        edges = ss.find_all { |e| e.kind_of?(Sketchup;;Edge) }
                        So here the "e" means output of the find_all method, so what the loop produces in the moment of its cycle. I thought that it is definition of the input or some argument for input! But recalled that I asked on it on previous page. It seems to me that it is like loop, similar like .each { |e| e.some.action.here}
                        • Dan RathbunD
                          Dan Rathbun
                          edges holds the output of the find_all method, which is a new Array of the items that were found.
                          |e| is the block parameter list, which is passed into the block by the Ruby keyword yield.
                          The number of block parameters can vary from one block method to another.
                          This is an example of what the find_all method would look like, if it was written in Ruby (but it is actually written in C.)
                          class MyArray
                            def find_all
                              raise(ArgumentError,"no block given!",caller) unless block_given?
                              found = []
                              self.each {|item|
                                # call the block using yield, passing in item
                                # if the block returns true via yield,
                                # push the item into the found array.
                                found << item if yield(item)
                              return found
                            Not only is it in global namespace - it uses typename to identity the type of entity (which many plugin does because the API docs sets a very poor example.) .typename is very very slow - avoid at all cost! More details: http://www.thomthom.net/thoughts/2011/12/never-ever-use-typename/
                              rumcajs
                              Exactly. I am reading it just in the first link (http://forums.sketchucation.com/viewtopic.php?f=180&t=10142) in the first response in this thread.
                              • Dan RathbunD
                                Dan Rathbun
                                Use puts statements in the code, to output to the Ruby Console.
                                • Dan RathbunD
                                  Dan Rathbun
                                  @rumcajs said:
                                  I would like to see what contains @iptemp.
                                  It is an Sketchup::InputPoint instance object. See the API dictionary.
                                    rumcajs
                                    What debug tools and methods can I use to debug method?
                                    Example, utilitiestool.rb
                                    class TrackMouseTool
                                    method onMouseMove
                                    @iptemp.pick view, x, y
                                    Is it possible to show dialog box or pause code?
                                      rumcajs
                                      If I change code of the plugin, will it be refreshed automatically or must I reload the plugin and how?
                                        Reload it manually.
                                        load 'myfile.rb'
                                        Though I think Jim created a utility to autoreload after changes where detected. Never used it though as I prefer the manual control.
                                          rumcajs
                                          OK. Works. So I tried:
                                          puts @iptemp
                                          #Sketchup::InputPoint:0xd0fe6fc
                                          So the input point is in hexadecimal format? If I would want to read it, I would need to add method to convert to decimal, right? I tried:
                                          puts @iptemp.hex
                                          returns error
                                            No - the hex number you see there is the hexadecimal version of the object id. Ruby convention.
                                            Refer to the API manual and you find InputPoint.position
                                            https://developers.google.com/sketchup/docs/ourdoc/inputpoint#position
                                            • 2 / 3
