    Where to start?
    44 Posts 4 Posters 4.3k Views 4 Watching
      rumcajs
      OK. So summary.
      Objects can keep properties (@name...) and methods.
      Arrays [] are only non-associative.
      Hashes {} are associative arrays, not ordered.
      Can you print function or method just like in JS? I know more scripting languages not just JS. Last one is AHK.
        rumcajs
        I tried this (interactive guide):
        ratings = Hash.­new(0)
        Success!
        > books.valu­es.each { |rate­| ratin­gs[rate] += 1 }
        => [;splendid, ;quite_good, ;mediocre, ;quite_not_good, ;abysmal]
        > ratings
        => {;splendid=>1, ;quite_good=>1, ;mediocre=>1, ;quite_not_good=>1, ;abysmal=>1}
        And it is not clear to me, hoq the value 1 is assigned to the values. I guess that first command created new hash ratings. Then I go through each value of the hash and set the ratings... But how is it possible, that ratings hash overwrite the book.values? As I know this is problem in PHP. If you know something like
        foreach(books->valu­es as $val){
        ; this will not work;
        val="new value";
        It will not overwrite the for values of "values" property. Maybe the relation between ratings and books.valu­es was already defined somewhere in a class, which is not visible to me?
        This command does not work to me as expected:
        .. File.Open(­"/Home/com­ics.txt", "a") do |f|
        .... jjj
        .. ss
        I can write in the file but how to close it and to keep data in it? There should be some other stuff in the file when I write File.Open(­"/Home/com­ics.txt", "a") . Once I succeeded there were some links and they say, that is should add some data in file...
        • Dan RathbunD
          Dan Rathbun
          > Success!
          > > ratings
          And it is not clear to me, how the value 1 is assigned to the values.
          Because the Ruby interpreter changes the shorthand a += b, to a = a + b
          So your statement:
          is actually executed as:
          books.valu­es.each { |rate­| ratin­gs[rate]= ratin­gs[rate] + 1 }
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            Method names begin with a lower case character (by convention.)
            So it is:
            ` File.open("path/to/file","w") do |f|
            end`
            The block form of IO::open with automatically close the file handle.
              rumcajs
              Something else confused me. But i think I had overlooked something. The ratings are not saved in values, but in ratings...
              Things are going bad, I cannot move on.
              #<SyntaxError; Invalid char "\xC2" in expression. near line 1; "\xADread(\"/Hom\xC2\xADe/comics.t\xC2\xADxt\")">
              > print File.­­read("/co­mics.t­xt"­)
              #<SyntaxError; Invalid char "\xC2" in expression. near line 1; "\xADread(\"/comics.t\xC2\xADxt\")">
              > print File.­read("comi­cs.txt")
              #<Errno;;ENOENT; No such file or directory - comics.txt>
              > Dir["/*"]
              Open up a new BlogEntry class, pretty pretty please.
              How can I print what is in /home/comics.txt and /comics.txt and if they exists and why this error happens...
                rumcajs
                Whatever i write it jumps into input mode:
                comics.is_­a
                .. end
                > comics.is_­a?
                Damn, that's not 15 minutes tutorial, but 15 hours (I'm in half but cannot move on).
                > Popup.make­ do
                .... h1 "Header"
                .... list do
                ...... comics.eac­h do |name­, url|
                ........ link name,­ url
                ........ end
                ...... end
                .... end
                Should generate web page, but nothing popups. And I cannot check if the array exists, what is in array, what is in directory or if the file exist... Look like not realy ruby console (running in browser). 👎
                • Dan RathbunD
                  Dan Rathbun
                  defined?(comics)
                  tests for existance
                  comics.is_a?(Array)
                  or
                  comics.instance_of?(Array)
                  or
                  comics.class==(Array)
                  tests the class of the comics object
                  • Dan RathbunD
                    Dan Rathbun
                    You cannot assume that the current working directory is what you wish it to be (because another plugin may have changed it.)
                    Be sure a HOME environment var is defined on PC (it is always defined on Unix-like systems, such as OSX.)
                    unless RUBY_PLATFORM =~ /(darwin)/i
                      ENV["HOME"]= ENV["USERPROFILE"] unless ENV["HOME"]
                    oldDir = Dir.getwd()
                    Dir.chdir(ENV["HOME"])
                    if File.exist?('comics.txt')
                      lines = IO.readlines('comics.txt')
                      puts(lines)
                    else
                      puts("'comics.txt' could not be found.")
                    Dir.chdir(oldDir)
                    or use the **~** shortcut (if you KNOW that a HOME environment var is defined.)
                    filepath = File.expand_path('~/comics.txt')
                    if File.exist?(filepath)
                      lines = IO.readlines(filepath)
                      puts(lines)
                    else
                      puts("'#{File.basename(filepath)}' could not be found in dir;\n#{File.dirname(filepath)}.")
                    • Dan RathbunD
                      Dan Rathbun
                      Because you NEED to read "Programming Ruby: The Pragmatic Programmer's Guide"
                      You need to take a WEEK OR MORE getting comfortable with Standard Ruby, before attempting to learn to use the SketchUp API.
                      I wrote the "Ruby Newbie's Guide to Getting Started" to help you and others avoid the frustration you are experiencing.
                      Follow the guide and you will be much happier.
                        When it comes to the Ruby API I have a few articles on my blog - don't think they are liked in the sticky threads.
                        I recommend new plugin developers to read this one first: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
                          rumcajs
                          I run this "Ruby" in Browser, this is not in SU. It is tutorial - interactive online guide which is called "15 minutes tutorial"
                          http://tryruby.org/levels/1/challenges/0#levels/8/challenges/3
                          So I am not sure if the ruby runs there or it is just simulation of Ruby in Javascript or Flash. So as they say, the path is preconfigurated, and I checked before that the path and files were there. Now I am on next lesson.
                           blog = [entr­y, entry­2]
                          => [#<BlogEntry;0x72e8e4f7 @fulltext="I can't believe Mt. Hood was stolen! I am speechless! It was stolen by a giraffe who drove away in his Cadillac Seville very nonchalant!!", @time=2012-09-16 15;55;25 +0000, @title="Today Mt. Hood Was Stolen!", @mood=;sick>, #<BlogEntry;0x18104f11 @fulltext="I am
                            never going back to that mountain and I hope a giraffe steals it.", @time=2012-09-16 15;55;25 +0000, @title="I Left my Hoodie on the Mountain!", @mood=;confused>]
                          Success!
                          > next
                          > blog.sort_­by { |entr­y| entry­.time}.rev­erse
                          [#<BlogEntry;0x263b3097 @title="I Left my Hoodie on the Mountain!", @time=2012-09-16 15;57;13 +0000, @fulltext="I am\
                            never going back to that mountain and I hope a giraffe steals it.", @mood=;confused>, #<BlogEntry;0x77f31d1c @title="Today Mt. Hood Was Stolen!", @time=2012-09-16 15;57;13 +0000, @fulltext="I can't believe Mt. Hood was stolen! I am speechless! It was stolen by a giraffe who drove away in his Cadillac Seville very nonchalant!!", @mood=;sick>]
                          Success!
                          > back
                          > blog.find_­all {|ent­ry| entry­.fulltext.­match(/cad­illac/i)}
                          [#<BlogEntry;0x68f04725 @title="Today Mt. Hood Was Stolen!", @time=2012-09-16 15;58;56 +0000, @fulltext="I can't believe Mt. Hood was stolen! I am speechless! It was stolen by a giraffe who drove away in his Cadillac Seville very nonchalant!!", @mood=;sick>]
                          Success!
                          > blog.find_­all {|ent­ry| entry­.fulltext.­match(/Mt.­{2,10}/i)}­
                          => [#<BlogEntry;0x5ac78f1f @fulltext="I can't believe Mt. Hood was stolen! I am speechless! It was stolen by a giraffe who drove away in his Cadillac Seville very nonchalant!!", @time=2012-09-16 15;59;49 +0000, @title="Today Mt. Hood Was Stolen!", @mood=;sick>]
                          Success!
                          > back
                          > blog.map { |entr­y| entry­.mood}
                          [;sick, ;confused]
                          Success!
                          So want to ask what is the entry in pipelines? |entr­y|
                          I defined entry and entry2 as instance of my little blog class. Blog is array containning entry and entry2, but I ask about what is meanning for |..| in these methods. It looks like it is name of class.
                            rumcajs
                            @dan rathbun said:
                            The frustration is from the Interactive guide, because it didn't work in the fully meaning of ruby console. SO I could not check what I did. But I closed the window, and moved.
                              rumcajs
                              Well, helpful. I found one plugin in my folder, which is in global namespace.
                              #this part is taken (after a little modification) directly from the script Skin by Darrel Belvin so all credit is his (hope he doesn't mind me posting this)
                              def clean_up
                              	Sketchup.active_model.start_operation "Clean-up"
                              	ss = Sketchup.active_model.selection.collect
                              	erasee = []
                              	ss.each {|e|
                              		if (e.typename=="Edge")
                              			if((e.faces.length==0)|| (e.faces.length==2 && e.faces[0].material==e.faces[1].material && e.faces[0].normal.parallel?(e.faces[1].normal)))
                              				erasee.push e
                              	erasee.each {|e|
                              		e.erase! if(e.deleted? == false)
                              	Sketchup.active_model.commit_operation
                              	return
                              if not (file_loaded? "cleanup.rb")
                              	clean = UI.menu("Plugins")
                              	clean.add_item("Clean-up") {clean_up}
                                rumcajs
                                I go through SU examples.
                                So Utilities - Create Faces ... utilitiestools.rb
                                # Get an Array of all of the selected Edges
                                edges = ss.find_all { |e| e.kind_of?(Sketchup;;Edge) }
                                So here the "e" means output of the find_all method, so what the loop produces in the moment of its cycle. I thought that it is definition of the input or some argument for input! But recalled that I asked on it on previous page. It seems to me that it is like loop, similar like .each { |e| e.some.action.here}
                                • Dan RathbunD
                                  Dan Rathbun
                                  edges holds the output of the find_all method, which is a new Array of the items that were found.
                                  |e| is the block parameter list, which is passed into the block by the Ruby keyword yield.
                                  The number of block parameters can vary from one block method to another.
                                  This is an example of what the find_all method would look like, if it was written in Ruby (but it is actually written in C.)
                                  class MyArray
                                    def find_all
                                      raise(ArgumentError,"no block given!",caller) unless block_given?
                                      found = []
                                      self.each {|item|
                                        # call the block using yield, passing in item
                                        # if the block returns true via yield,
                                        # push the item into the found array.
                                        found << item if yield(item)
                                      return found
                                    Not only is it in global namespace - it uses typename to identity the type of entity (which many plugin does because the API docs sets a very poor example.) .typename is very very slow - avoid at all cost! More details: http://www.thomthom.net/thoughts/2011/12/never-ever-use-typename/
                                      rumcajs
                                      Exactly. I am reading it just in the first link (http://forums.sketchucation.com/viewtopic.php?f=180&t=10142) in the first response in this thread.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Use puts statements in the code, to output to the Ruby Console.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          @rumcajs said:
                                          I would like to see what contains @iptemp.
                                          It is an Sketchup::InputPoint instance object. See the API dictionary.
                                            rumcajs
                                            What debug tools and methods can I use to debug method?
                                            Example, utilitiestool.rb
                                            class TrackMouseTool
                                            method onMouseMove
                                            @iptemp.pick view, x, y
                                            Is it possible to show dialog box or pause code?
                                            • 2 / 3
