    SU 9 Wishlist
    436 Posts 99 Posters 67.9k Views 99 Watching
    • PixeroP Offline
      Pixero
      @thomthom said:
      Explode is terrible slow - agree. But I've never seen it crash due to that.
      I have, on numerous occasions, had crashes when exploding heavy geometry like imported high quality furniture.
      For the VR apartment I posted a while ago I had to separate the apartment into ten different SU models with up the four models/ scenes per room.
      Another strangeness often seem to appear when having heavy models in SU is that upon save or sometimes just by closing a group it often unsmoothes random parts of the model.
      Memory issues?
      I'm not wishing for a 64 bit version to gain speed. I just want SU to be able to handle bigger/heavier scenes.
      • pbacotP Offline
        "Last tool / menu item" command.
        One key zoom out increment (jump back ) command (not Extents, not scrolling).
          a_iverson
          There are no cylinder, cube, pyramid, sphere exc. I try to draw them but it gets my time. All the 3d programs have them. If sketchup means easy draw then have to be in Sketchup.
          And the interface must be changed. Because when i open the program it looks like a child program. It must be like proffesional.
          And the other wishes: Curve and
          I want to move the vertex easily. I don't want to need the plugin for it.
            @pixero said:
            Memory issues?
            Only way to tell is monitor the memory usage when it crashes. It could a number of other reasons.
              ArCAD-UK
              Save yourself some time and add the ones you made to your own library. The reason you may not find them included is the way SU works with curves, or rather lack of, as everything is created with straight lines. Not a problem if you accept the limitations but the resolution of a curve can have a big impact on model size and processing speed.
              I quite like the icons for their clarity of function, but you never know, under Trimble they MAY be refreshed soon.
              • cottyC Offline
                cotty
                I would find it helpful if the language can be changed on the fly...
                (I normally use the german version and if I want to answer a question in the forum, I have to search the right english description)
                my SketchUp gallery
                  rv1974
                  Actions!
                  I'd like to see Photoshop-like actions to cut down some boring\tedious\time consuming procedures.
                  • mitcorbM Offline
                    mitcorb
                    @a_iverson:
                    If you have a copy of version7, you can copy the Component folder and place it in Version 8. This assumes that Sketchup 8 does not have these primitives? The only primitive not available is apparently Cylinder. In my copy of V8 in Draw menu is a command called Box, but it is inserted at a preset size as a group. EditGroup measure an edge, see size in VCB, input new value, and the box is resized independent of other stuff.
                    • pbacotP Offline
                      Preference / Extensions:
                      I never heard or understood what the Preference / Extensions is there for. We need to use it to activate some plugins but not others. The window is ridiculously tiny (on Mac) requiring scrolling and you cannot view at glance what is ON or OFF. And as for a lot of SU, 'alphanumeric" is a lost art.
                      The addition of .rbz installation is good; but placed as it is here, I am sure it is confusing to many people.
                      Maybe someone can explain that.
                      I wish this were made more robust, or eliminated altogether. Why do we have to load some plugins and not others? For that manner a proper (full screen-able) plugin browser where all plugins could be loaded, or unloaded, check for update, show icons (if applicable), show location in menu (like the Help function), show in folder etc. would be best. (Would improve over the "View / Tool Palette" drop down as well.)
                      And some way of requiring that all plugins have icons / bars, that can be hidden while loaded 😡 would be great. I know that isn't big for Windows, but the mess icons make on a Mac would be helped.
                        What do you mean by unresizable windows?
                        • john2J Offline
                          john2
                          detection of section planes for sectional rendering in rendering plugins like vray, so we don't have to do any demolition with zorro 😄
                          Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                            Aerilius
                            The Preferences → Extensions list was a start of something good, that hasn't been consequently completed yet.
                            At the beginning plugins were loose scripts. For us humans every file looked like one "plugin" but for SketchUp their contents were undistinguishable, all in the same soup. The SketchUp team has then later added a way to register plugins with metadata (and only those are called "extensions"). The aim of the extensions list is not that plugins need to be enabled, but can be disabled/enabled depending on whether you need them. SU8M2 pushed that further to allow us packaging extensions as rbz which simplifies the installation. I agree absolutely that this caused even more confusion because we now have 3 different ways to install loose scripts (*.rb), zipped plugins and *.rbz extensions.
                            I whish for SketchUp 9 that installation will be more streamlined and the extension format more refined. Either it should be made obvious to users what is understood as plugin/extension or the install button should accept all legacy formats. And maybe we should just get rid of legacy plugins 😆
                            I also whish that the UI will be overhauled. Technically and visually it isn't state-of-the-art, but more important are lots of usability issues, unresizable windows (edit: Preferences & Co.), to narrow lists, suboptimally chosen widgets for a certain task etc.
                              smitty_lynch
                              Wondering if sketchup will ever be a 64-bit program...64bit programs have been out for how long now? and SU is still behind the times
                              • cottyC Offline
                                cotty
                                Here you will find a discussion about this: http://sketchucation.com/forums/viewtopic.php?f=15&t=33788&start=0#p297079
                                my SketchUp gallery
                                  Roger
                                  Ability to open much larger meshes via an obj file importer plug in.
                                  http://www.azcreative.com
                                  • john2J Offline
                                    john2
                                    tried 2 years back to import a fountain from Revit architecture 2009 exported as perhaps an fbx or something, sketchup imported it with lotsa triangles. are you referring to the same thing? SU crashes when importing such biggies if i'm not wrong?
                                    • chriC Offline
                                      chri
                                      hi
                                      About Sketchup 9 - wishlist
                                      CIRCLES
                                      Are there plans to change the way of thinking circles.
                                      • Currently, circles and radius are a series of lines.
                                      • Could there be replaced by a single curve with center point?
                                      ANGLE QUOTATION
                                      • This function is surprisingly absent!
                                      LINEAR DIMENSION
                                      • Can we hope to have reverse arrows for odds ?
                                      KINEMATICS
                                      • Can we add , joints, linear movements , ..., to model mechanisms.
                                      TOOLBARS
                                      • Can we hope to be able to create our own toolbar easily ?
                                      PLUGINS
                                      • The organization of the plugins in the menu or the context menu is difficult .
                                      • is there some news ?
                                      chri
                                      • DesertRavenD Offline
                                        DesertRaven
                                        @arcad-uk said:
                                        mi wish: That SU doesn't become bloatware because some people don't get it's lean efficiency. If I wanted it to perform like AutoBad, ArchiCAD, Solidworks or 3D Studio that is what I would have bought not come here b*tchin about it not doing the same job. ☀
                                        Well then who would oppose to sketchup becoming more powerful? Really?
                                        Would you rather have it stay the shitty tool it is with huge a potential just because some minor glitches can't be taken care of?
                                        I'll tell you, I like the ease of use and the clean interface that Sketchup offers, but I would really appreciate if they put some more precision and muscle into it.
                                        I'd even pay 1000 bucks or more.
                                        And just FYI, Autocad and all the other CAD software out there aren't flawless either, overpriced and overloaded to say the least.
                                        SU has the chance to become a working lean asset. I hope they keep it open for Rubi plug- ins, but they should realize it can't rely on those for ever.
                                        simplicity is the ultimate sophistication
                                          ArCAD-UK
                                          Looks like you wasted your money buying the pro version... 😒
                                          With regards to its huge potential, have you read the DUH thread? What that demonstrates is even with a simple interface there are tips and tricks which can dramatically simplify the drawing process even for experienced users. People are becoming increasingly lazy, they expect the computer to do everything for them with one click because they can't be bothered to learn to use the basic tools. Result is we end up with a screen full of buttons, which inevitably becomes counter productive as you try to find the right one and then remember the usage process.
                                          Yes SU can improve but it needs to be the core functionallity and bug fixing rather than adding an overload of toolbars for the creatively challenged. True arcs would be prime example of a step forward and it could be done without adding a new tool. ☀
                                            Cocko7
                                            Export volumes and units in the units the template that being used in genertaed reports, rather than cu inches, etc. eg metres in cu meters etc.
                                            • 21
                                            • 22
                                            • 2 / 22
