    Black spots all around white materials
    renderpluginsextensions
    8 Posts 3 Posters 1.7k Views 3 Watching
      ccs1987
      Good morning everyone, i have a problem here which i hardly figure out which place went wrong or where should i check it.
      i have rendering using a 3D model done by someone else but i m getting this kind of patches around doors and windows.
      any idea.
      Sketchup 8 pro
      Vray
      Intel Xeon W3520 2.67Ghz
      12Gb Ram
      Nvdia Quadro FX 1800
      • mitcorbM Offline
        mitcorb
        Possibly hidden artifacts in the original model, that Vray sees?
        EDIT: On second thought, maybe that is not the issue. Perhaps you could post an image of the problem?
          ccs1987
          eh ? i thought i uploaded an attachment. oh filex size is too big
          i have uploaded elsewhere, here is it.
          i tried to colour around the frame of the window and doors to ensure that even if there's hidden surface or intersected surface then it will still be rendered out white colour. but it seems like that is not the problem.
          http://img854.imageshack.us/img854/223/444w.png
          Sketchup 8 pro
          Vray
          12Gb Ram
          • mitcorbM Offline
            mitcorb
            I have only one more guess: Duplicate overlapping faces that did not get textured. Well, maybe one more guess: unpainted back faces.
            Check the model by changing to default materials, I think. Maybe the reversed faces will show?
            Seems I have read about this before, and I am just repeating that.
            • andybotA Offline
              andybot
              I would guess you have a low setting for your GI solution (irradiance map and light cache.) irrmap especially can be tricky, you could try turning on detail enhancement. I don't recall the exact settings, but there are some tutorials on that I believe. (see the sticky post for where to find those.)
                ccs1987
                guys i think there's a hint already. i hereby overlay my material with one colour only by the option under vray
                http://img521.imageshack.us/img521/2706/complainb.jpg
                the black spot still exist where i think it should be problem of irr map or model problem, but if it's irr map, which value is too low or too high that i should look into
                Sketchup 8 pro
                Vray
                12Gb Ram
                • andybotA Offline
                  andybot
                  can you post a screenshot of your irrmap settings?
                    ccs1987
                    http://img560.imageshack.us/img560/3762/complain2.jpg
                    Sketchup 8 pro
                    Vray
                    12Gb Ram
