    [Plugin] Xref Manager
    98 Posts 43 Posters 95.3k Views 43 Watching
      This tool is now very 'old in the tooth' and it needs a major revamp.
      For example, lot of its 'ole work can now be done using built-in importers etc...
      A toolbar and webdialog interfaces would also be on the agenda...
      It is on the list of things to do BUT it's near the bottom of a long list !
      πŸ˜’
        davecoopstl
        TIG,
        I agree with you. This tool would benifit from an update. We use it EVERY day, to assemble and manage large models. It's really useful for that purpose.
        Any updates you make, when you actually have time to make them, would be greatly appreciated.
        Thanks for all your scripting work!
        Dave.
        • Bob JamesB Offline
          Bob James
          I missed out on the original post for this plugin that describes what it does. Can you repost the description?
            My 'Xref Manager' allows you to link external SKPs [and DWG/DWG [at the moment for PC only]] into a 'master' SKP model.
            Of course you can already do that but inserting 'component' SKPs, but there is no 'reminder'...
            With the tool you can then automatically check if an external 'xref' file has be changed since it was last loaded in this Model and then choose to reload it.
            The dialog list all such files... a new web-dialog would improve this a lot !
            Currently [on PC only] you can also set an option to auto-check the xrefs' 'currency' as the master-SKP opens.
            There are other tools to make a component into an 'xref', bind them in so they are no longer 'linked' externally, and so on...
            It's somewhat like AutoCAD's Xref-tools... but unfortunately the inserted files are 'full' versions... not 'place-holders'- as this isn't supported in the SKP format...
            It's long overdue an up date... "watch this space"... but don't wait up πŸ˜‰
              Bob James
              This has great potential for the kind of work I do: A main standard set of components with added customer-peculiar components. It should be very useful to assure, for the next set of customer-peculiar components, that the standard set is up to date.
              So...I'll be watching with interest πŸ˜„
                ravinhuxley
                I am having problems importing DWGs for xref purposes with TIGs XREF Manager. When I import the drawing, I get the error shown below. This happens on two machines, both running the same setup.
                What is odd is the -++ at the end of the .dwg extension. Its almost if the script is adding additional characters to the file path.
                Using Sketchup 8.0.15158
                Windows 7 Home Premium
                Importing 2004 DWG
                Ruby console reports:
                Error: #<NoMethodError: undefined method definition' for nil:NilClass> C:/PROGRA~2/Google/GOOGLE~1/Plugins/XrefManager.rb:566:in add_dwg_attrib'
                C:/PROGRA~2/Google/GOOGLE~1/Plugins/XrefManager.rb:542:in add_dwg' C:/PROGRA~2/Google/GOOGLE~1/Plugins/XrefManager.rb:566:in call'
                Any suggestions?
                  I've moved this recent post into the tool's main thread, where it belongs.
                  The final errors appear because the DWG isn't auto-loaded and so it has no definition to use when it tries to add 'xref' attributes to it.
                  The file-name/path getting '-++' added onto the end is clearly what's breaking it.
                  The tool uses +/- key presses to navigate the dialog [this will be avoided in a future version...]
                  The -++ pattern shows that you have 'chosen' options:
                  No to merge
                  Yes to orient
                  Yes to use origin [this is fixed 'on']
                  Because you obscured the earlier path it's unclear... does the path look right otherwise -e.g. does it have a drive letter like 'C:...' ?
                  Is suspect that something is happening with the 'key-stroke' mimicker... I find that I can break it so the drive letter is missed off ! Then it reports the file can't be found and the thing fails as the keys then write in the file-name panel incorrectly...
                  This tool needs a major overhaul - it's two versions [or more] behind...
                  I'll look at replacing parts of the code that need key-stroke mimicking [as an interim fix] and get back to you soonest... πŸ˜•
                    Here's v6.0 http://forums.sketchucation.com/viewtopic.php?p=46367#p46367
                    It's not the full update that is still in the very long pipe-line [web-dialogs etc], but it is issued to address reported problems with using PC DWG/DXF xrefs... AND now it allows these on MAC too... πŸ˜„
                    • ElibjrE Offline
                      Elibjr
                      Wow! Thank you TIG! You are awesome! I will try this later! Thanks !!!
                      • EarthMoverE Offline
                        EarthMover
                        πŸ‘ Thanks TIG! Not sure how I missed this. Really could've used this on my latest project. Can't wait for the revamp.
                        Content Creator at Skapeup
                          ravinhuxley
                          TIG-
                          I neglected to come back and let you know that you are awesome. Thanks for the updated plugin!
                            Mohsin_Mazhar
                            Can any one please tell me about how to install it in google sketchup 8 pro? I have copied the XrefManager.rb to my google sketchup plugin folder. But i am unable so see Xref tools while i open my plugin menu in Google Sketchup.
                              This tool is the simplest sort you will come across - a single .rb file that you place in the Plugins folder. There is no unzipping, extraction, subfolders of helper files, Libs, other files that you need [the one additional .so file for PC users was discontinued some years ago] etc. Once installed, after a restart of SketchUp, it should add a submenu to the Plugins menu, with sub-items relating to the tool; this is the only slightly complex matter, as some even simpler tools might add their item directly into the Plugins menu itself. Also it is not an Extension, so it doesn't need activating and it has not got a toolbar to activate either...
                              I assume you are not getting any error messages as SketchUp starts...
                              So, assuming that it appears to you that you have installed the .rb file in the Plugins folder and you are not seeing the menu items then I suspect you have not got your security permissions set properly...
                              Look at the Plugins folder in Windows Explorer - is there a link/button in one of the top-bars saying something like 'Compatibility Files...' - this is indicative of this. If you click on it you should find that the .rb file [and perhaps other things too] have been put into a 'Virtual Store' with a path that mimics the Sketchup..Plugins folder structure. This is 'Windows' protecting you from yourself, over zealously. SketchUp cannot auto-load files from this folder, although they can be seen in the main folder's list they are actually elsewhere !
                              Being an Admin is not sufficient to allow you to add files to 'program files' subfolders, without issues...
                              So to fix this... as an Admin, select the Plugins folder's icon and right-click context-menu > Properties > Security > Edit... Set the access-rights to that folder to 'FULL' [all ticked] for 'yourself' and then OK to save the changes...
                              From now on when you add a file to the Plugins folder, then that's where it goes...
                              So they should all work as expected...
                              You might wish to tidy up the 'Compatibility Files...' - either by deleting them after you reinstall things, or Edit/Cut+Paste back into the proper Plugins folder otherwise...
                              Incidentally you should set the permissions for the Components, Materials and Styles folder to FULL too as from time to time you will want to add files to those as well...
                              Please confirm if this was the issue and it's fixed: it might help others having similar problems...
                                Mohsin_Mazhar
                                Thank you so much for helping me, i have followed all steps you have written for me. but the problem is not fixed yet.
                                  Have you checked everything as I said ?
                                  How about 'security permissions' ??
                                  'Compatibility Files...' ???
                                  Can you take a screen-shot of your Plugins folder showing the whole window, and the files [especially the xrefmanager.rb one].
                                  Also a screen-shot of the Plugins folder's Properties > Security > Edit dialog might help...
                                    Backstyler
                                    Hi. Thanks for the great plugin.
                                    "Pick Type of XREF Checking On Opening: Open XREF Manager if needed" is selected, but the dialog does not show up when opening a file. What's wrong?
                                      What is your OS?
                                      This is a "PC only" [experimental] feature to auto-check for a needed update of any xrefs when you open a SKP.
                                      You can easily use the tool 'manually'... πŸ˜•
                                        Backstyler
                                        What is your OS?
                                        Windows 7
                                          I suggest you 'switch it off', pending an update... πŸ˜‰
                                            Backstyler
                                            Ok.
                                            A few more feature requests:
                                            • The definition name of the "outer" XREF component seems to be derived from the "source" file's name. Could this component name please refresh as well when I re-bind a file and the file name has changed? (maybe as an option in the XREF settings)
                                            • When I insert the same source object twice (e.g. by an oversight), your plugin makes two different components with different definition names (#xx). In the manager they are listed as separate components.
                                              There could be an option in the settings what to do if an object is already in the project:
                                            • create a separate component
                                            • copy the former one
                                            • ask again
                                              (if that's not possible, there could be at least an popup message saying that this object was already inserted)
                                            Thanks for the great work,
                                            Best regards
                                            Felix
                                            • 3 / 5
