    Fill the area with 3d pattern like texture, possible?
    8 Posts 2 Posters 617 Views 2 Watching
    • tibetT Offline
      tibet
      hi,
      i wonder, if there is any suitable plugin to fill the chosen area with 3d pattern like with texture ( for later editing too )
      thanks in advance for any tip or advice:-)
      http://i47.tinypic.com/slny47.jpg
      http://i52.tinypic.com/zujcp1.jpg
      SU 2015 Pro on Win10 x64
        So just applying the material to the surface isn't what you want? Are you talking about resizing the material image to fit the rectangle?
        • tibetT Offline
          tibet
          hi,
          thanks for quick reply.
          i´d like to apply 3d group of objects ( diamond plate in this case ) for chosen area, with size of pattern to stay unchanged
          cheers!
            Oh. I see. I thought it was just a texture you're applying.
            So all you need to do is make an array using Move/Copy and then trim the edges. Not a difficult thing to do.
              True.
              So here's an option for you.
              Draw the footprint and extrude it through the tiles. Do an Intersect Faces and trim off the waste.
              • tibetT Offline
                tibet
                hi dave,
                i really appreciated your valuable tutorials, you´re a true jewel
                http://www.gifandgif.eu/animated_gif/Precious_Jewels/Animated Gif Jewels_Precious (14).gif
                on this forum:-)
                but, emm, how to fix this with limited experiences ?
                thanks !
                http://www.geekalerts.com/u/Diamond-Plate-Mug.jpg
                • tibetT Offline
                  tibet
                  hi,
                  you´right, thanks.
                  but when i meet something more complicated, a smart plugin would be handy 😄
                  http://ak.buy.com/PI/0/500/235458632.jpg
                  http://www.etrailer.com/merchant2/graphics/00000001/pics/C/E/CE17960ATB_2_1000.jpg
                    That's a little more of a challenge. For that mug I think I would use Shape Bender. On the other hand, is there a good reason for using 3D geometry for drawing the mug over using a material?
