    Problems moving along various axes
    12 Posts 7 Posters 17.9k Views 7 Watching
    • grizzlerG Offline
      grizzler
      Hello again oh Sages of SketchUp.
      A simple question for you if I may. How come sometimes SU only allows me to move items along one axis? I see to frequently encounter problems moving things up and down the Blue Axis more than any other. The problem still occures when I try to follow a line that I've drawn that is on that axis, it just doesn't wove at all.
        Is it possible the "thing" you're trying to move is a component with gluing characteristics? Or perhaps the thing is part of some other geometry that won't deform?
        • cottyC Offline
          cotty
          You can check this by pressing the alt key while moving (which forces the autofold function).
          my SketchUp gallery
          • grizzlerG Offline
            grizzler
            I'm not sure about the "gluing", it's certainly not something I've intentionally done as I just draw the equipment and "make group" when I've finished an item - nothing more. In the case just today I was trying to lower several "groups" in one go within a room that remained where it was, but it would only let me move along the red axis. I ended up having to raise the building instead! ๐Ÿ˜ณ
            • mitcorbM Offline
              mitcorb
              Can you select then use the up down left right arrow keys?
                @grizzler said:
                @dave r said:
                Is it possible the "thing" you're trying to move is a component with gluing characteristics? ...
                I'm not sure about the "gluing", it's certainly not something I've intentionally done as I just draw the equipment and "make group" when I've finished an item - nothing more...
                Still can be. Example: draw a bigger rectangle and then a smaller inside the bigger. Now double click on this smaller and make a group. Now try to move it up. ๐Ÿ˜‰
                No way; it's glued to the plane you drew it on. Right click and if "Unglue" is available in the context menu, select it. Try to move it up now.
                • grizzlerG Offline
                  grizzler
                  I've never tried that method before, it seems to lock the axis but the flippin item still won't move. I'm afraid I can't share the drawing as it's one from work.
                  I've managed to get round it, but I wish I knew why this happens from time to time.
                  Thanks for your input gents.
                    Next time it happens, turn on Hidden Geometry and see if there's anything connected to the geometry you're trying to move.
                    You never said, is the "thing" you're trying to move a group, component or loose geometry?
                    • grizzlerG Offline
                      grizzler
                      There were two components, a handful of groups and various loose geometry. However, when I returned to work today, the problem had somehow disappeared and I was free to move everything however I wanted ๐Ÿ˜•
                        Well, save the next file it happens on and either post it or send it in a PM so we ca see what is going on. It might help you and someone else avoid problems in the future.
                        • dukejazzD Offline
                          dukejazz
                          Here is a aid that may help you to understand
                          by useing Windows - styles - edit - background and then checking sky and ground to on
                          Now view, when you see mostly the sky background then SU locks on orgin blue axes hieght,
                          also when you view, mostly ground background then SU locks on orgin width and depth axes.
                          use the draw tool to see this
                          but you say its the move tool
                          its simular
                          When a move is being done
                          it can be directed by moving or draging on axes but sometime the control seem to get lost
                          due to this background view
                          to fix this click on axes (0) frist then do your move on axes
                          Also type of alinement can be found here
                          by useing Windows - model info - file - alinement - glue to
                            Trogluddite
                            ๐Ÿ˜ฎ - Doh! I must be getting old, I was convinced it was just me making inappropriate glue settings while "sleep-drawing"! Shame there isn't e.g. a different colour selection highlight etc. to indicate glued items - or at least it could show up in the entity info dialogue.
