    Fog Obscuring Ground
    13 Posts 5 Posters 611 Views 5 Watching
    • JoelM3DMJ Offline
      JoelM3DM
      I have a problem with fog hiding the ground plane in animations. This does not happen in the skp model, but only when I export avi animation. The ground vanishes and all that shows is the sky color. And to make it even more confusing, this only happens sometimes!
      Has anyone else come across this? Is there a workaround?
      || Joel Metzger 3D Modeling
      || story-shorts.net - Animation with SU
      • mitcorbM Offline
        mitcorb
        Now that you have an image, it occurred to me to ask:
        Are you using any "atmospheric" effects, such as fog in your model?
        I notice some lines in the image are faded, such as on the projected marquee. Could this be in any way related to the graphic card, and does this affect how the frames are rendered?
        Does the ground plane have a texture, and perhaps a transparency level that is not picked up?
        • JoelM3DMJ Offline
          JoelM3DM
          Yes, I am using Fog. The fog is set so it does not affect things within ~200'
          There is no texture on the ground, which is solid black. No transparency.
          • mitcorbM Offline
            mitcorb
            Ok, I was just hoping a few amateur questions might rattle loose a possible solution. 😄
              Tim, those lines on the marquee that disappear look to me as if they aren't actually drawn on the surface. That seems to be common in the models I've seen that Joel has made. Perhaps it's part of his working style. You know, the look he's trying to achieve.
              Joel, do you just have ground turned on and its color set to black? Try setting the Transparency slider all the way to the left. That will probably help some. You'll also need to play with the fog sliders.
                No, this really looks like a bug. I have turned on ground in my style, turned on fog under the view menu and the ground plane disappeared completely.
                  http://farm9.staticflickr.com/8041/7955823096_a61986f8b0.jpg
                  Fog off
                  http://farm9.staticflickr.com/8313/7955823354_cfbdc321a3.jpg
                  Fog on
                  the fog does cover the ground a little bit but it doesn't eliminate it. I did as I said above and set Transparency to the left.
                    Yeah, with transparency to the left, it displays. 👍
                      Which is what I wrote before. 😉
                        Yes, I know. Just misunderstood the thing. 😛
                          Language barrier. 😛
                          • JoelM3DMJ Offline
                            JoelM3DM
                            Oops, I'm wrong. It has nothing to do with the animation export. JPG export gets the same weird result. It depends on whether fog is turned on.
                            The ground vanishes when I export the image (whether jpg or avi). The exported image is different than what I see on screen.
                            This is what I see in the model. The exported image (avi or jpg) with fog off looks the same. With fog on, the street vanishes.
                            So I still have a question. Why is the exported image very different than the model I see? I guess this is a bug?
                            WHAT I SEE IN THE MODEL
                            • kachuppK Offline
                              kachupp
                              😲 I can't get FOG dialog box to display 😞
                              Ignore found an answer in another thread by TIG thanks for the insight ... snappyfogdlg registry x was on the moon
