    Guidelines
    27 Posts 6 Posters 2.4k Views 6 Watching
      rumcajs
      I believed that I have to select it and use move tool, but I was not succesfull to select it. I think the problem is that it was a part of group or what? I triple click to object to open it and edit... then. OK, done. Thanks.
        rumcajs
        @tig said:
        To relocate a guideline...
        OR probably even easier... delete the misplaced guideline and make a new one in the desired location...
        It's not black-magic... πŸ˜’
        Hm, that is what I was not successful to do. It is harder to describe without image
        http://i48.tinypic.com/307rtz6.png
        (The side side of the castle is not parallel to green x axis. And I could not to do it like in the post,
        massimo on Fri Aug 31, 2012 1:56 pm
        coz the guide would be not be parallel to green axis (it would intersect the green axis and then go to the point = not parallel).
          Why don't you put the castle on the ground plane? πŸ˜’
            rumcajs
            I guess that I did not see that in video tutorial πŸ˜’
              rumcajs
              One more problem with that guidelines. Now I tried to hide the castle and I realize that when I change to different layer to hide the layer 0, so the guides, which I created will disappear πŸ˜„ So I need to clone the guide lines from layer 0 to active layer... Is that possible?
                Go back to the help files and learn about layers.
                And you don't need to use Layers to hide guidelines.
                  rumcajs
                  OK, I learned how to move them to different layer and how to hide them in Entity info box. I had seen in video, that the guy used hidding of objects very quickly in scenes video, but did not explain it how he did it.
                    rumcajs
                    Next problem... It looks that I will never finished the insert of the plan under castle...
                    http://i46.tinypic.com/2rm0dhs.png
                    I try to add guidline using tape (click and drag from red axis)
                    but it disappears in the moment when I release the mouse button.
                    http://i45.tinypic.com/4gbgi.jpg
                    • GaieusG
                      Press the Ctrl button. It toggles simple measuring and guide creation. Press it a couple of times and see if a small + signs appears/disappears. When it is there, it should create a guide line.
                        rumcajs
                        Yes, that is that what I tried few times. I succeed to create one guide line, but only one, not much success. I must train.
                        • 2 / 2
