    Creating components from existing objects
    12 Posts 5 Posters 887 Views 5 Watching
      Are your script also generating the geometry you want to place in the component? If so, then you should just add it directly to the component definition.
      • sdmitchS
        sdmitch
        This seems to work.
        mod = Sketchup.active_model
        ent = mod.entities
        sel = mod.selection
        wgrp=ent.add_group ent.to_a #create a group containing all existing entities
        wcmp=wgrp.to_component #convert the group to a component/instance.
        wcmp.definition.name="World" #give it a name
        http://sdmitch.blogspot.com/
          ArunYoganandan
          Hi Tom,
          The geometries are generated by the users as they go along. I'm trying to make this a tool so as and when the user switches to the tool, all of the currently existing models (except certain objects) become part of the miniature view
            ArunYoganandan
            @sdmitch said:
            This seems to work.
            > ent = mod.entities
            > sel = mod.selection
            Ahhh! group to component! Thank you so much 😍
              ArunYoganandan
              Another question on a related note.
              Is there a way to set the Level Of Detail on the miniature component instance alone?
              It seems to be affecting performance with large models like castles and for the size at which I'm rendering the miniature, I couldn't care if its quality went down
              • sdmitchS
                sdmitch
                There is always a way but at what cost. The code would no doubt expand from 3 lines to 3000.
                  Beware... if ents is model.entities and that's not the current 'active_entities' context then ents.add_group(ents.to_a) or ents.add_group(model.selection.to_a) etc will Bugsplat!
                  So... always ensure that the ents=model.**active_**entities and the objects you are trying to add to the new group are in the same context - hence the recommendation for 'selection' because the user can't manually select things that are not in the current active context...
                    ArunYoganandan
                    TIG thanks. Will keep that in mind
                    • Dan RathbunD
                      Dan Rathbun
                      You might play with the Fog settings. Adjust the near and far clipping planes. (But this is really not LOD.)
                      I'm not here much anymore.
                        ArunYoganandan
                        Thanks Dan. Will give that a try
                          ArunYoganandan
                          I'm on a framerate sensitive medium, so anything I can do to improve frame rate would be useful. It would be great if you have any tips on how to set the LOD for the miniature.
