    Creating components from existing objects
    12 Posts 5 Posters 485 Views 5 Watching
      ArunYoganandan
      Hello,
      I'm trying to do a world-in-miniature kind of concept, whereby I'm taking all existing entities in the world and make it into a component. At a later point, the plan is to make an instance of it.
      The part I'm having trouble is adding existing entities into the component definition. My components are showing up empty irrespective of how I add the existing entities. Any help would be greatly appreciated.
      Here is my trial code
      list = Sketchup.active_model.definitions
      world_def = list.add "World"
      world_def.description = "This is all of the world."
      ents = world_def.entities
      Sketchup.active_model.entities.each{
      |x|
      	if(x.class == Sketchup;;Group)
      		ents.add_group x
      # Create the extrusion and save the definition
      comp_path = Sketchup.find_support_file "Components", ""
      world_def.save_as comp_path + "/candle.skp"
      t1=  Geom;;Transformation.translation Geom;;Point3d.new(0,100,0)
      inst1 = Sketchup.active_model.entities.add_instance world_def, t1
      Thanks in advance
      Arun
        Are your script also generating the geometry you want to place in the component? If so, then you should just add it directly to the component definition.
        • sdmitchS Offline
          sdmitch
          This seems to work.
          mod = Sketchup.active_model
          ent = mod.entities
          sel = mod.selection
          wgrp=ent.add_group ent.to_a #create a group containing all existing entities
          wcmp=wgrp.to_component #convert the group to a component/instance.
          wcmp.definition.name="World" #give it a name
          http://sdmitch.blogspot.com/
            ArunYoganandan
            Hi Tom,
            The geometries are generated by the users as they go along. I'm trying to make this a tool so as and when the user switches to the tool, all of the currently existing models (except certain objects) become part of the miniature view
              ArunYoganandan
              @sdmitch said:
              This seems to work.
              > ent = mod.entities
              > sel = mod.selection
              Ahhh! group to component! Thank you so much 😍
                ArunYoganandan
                Another question on a related note.
                Is there a way to set the Level Of Detail on the miniature component instance alone?
                It seems to be affecting performance with large models like castles and for the size at which I'm rendering the miniature, I couldn't care if its quality went down
                • sdmitchS Offline
                  sdmitch
                  There is always a way but at what cost. The code would no doubt expand from 3 lines to 3000.
                  • TIGT Online
                    Beware... if ents is model.entities and that's not the current 'active_entities' context then ents.add_group(ents.to_a) or ents.add_group(model.selection.to_a) etc will Bugsplat!
                    So... always ensure that the ents=model.**active_**entities and the objects you are trying to add to the new group are in the same context - hence the recommendation for 'selection' because the user can't manually select things that are not in the current active context...
                      ArunYoganandan
                      TIG thanks. Will keep that in mind
                      • Dan RathbunD Offline
                        Dan Rathbun
                        You might play with the Fog settings. Adjust the near and far clipping planes. (But this is really not LOD.)
                        I'm not here much anymore.
                          ArunYoganandan
                          Thanks Dan. Will give that a try
                            ArunYoganandan
                            I'm on a framerate sensitive medium, so anything I can do to improve frame rate would be useful. It would be great if you have any tips on how to set the LOD for the miniature.
