    Follow-me with a line instead of a face?
    5 Posts 5 Posters 437 Views 5 Watching
    • brodieB Offline
      brodie
      Is there a plugin out there where I can do a follow-me sort of action but instead of a face, i'd like to do with with a series of lines and curves? (More like a 'sweep') So if I were building a column I'd draw the profile, draw the circle of the column, select the profile and sweep it around the circle.
      -Brodie
      • mitcorbM Offline
        mitcorb
        Yes........wanna know?........Extrude lines(ancient) TIGs Extrude Edges by Edges
        EDIT: wait a minute. He does have a Lathe function in his Extrude Tools set. Maybe I misunderstood.
          Extrude Edges by Lathe
          CurviLoft
          Off the top of my head
          • ToboboT Offline
            Tobobo
            I use the copy along a path plugin and make the line a component.
            Toby
            Philippians 4:13
            • sdmitchS Offline
              sdmitch
              You might take a look at the Edge Follow Me plugin on my blog. Details at
              404 Not Found
              (forums.sketchucation.com)
              http://sdmitch.blogspot.com/
