    Component settings
    21 Posts 4 Posters 924 Views 4 Watching
    • E Offline
      erzane
      I would like to delete the ''in model'' components without touching to the components of the models
      purge is not the good solution for me , I already tryed it
      becuse purge deleted every other components like sketchup origin components like chair, bench, john , julie etc... but not the components I created
        The "In model" components are the components in your model. So if you delete them, you delete them from your model. I do not know how to explain this differently but you cannot delete something without "touching it".
        • E Offline
          erzane
          ok I see
          so, my next question is
          -how can I regroup components based on the same big model ?
            What do you mean b "regrouping"? These components are stored inside the model. Actually the model is their "group" (or in fact, rather a component itself) if you want to put that way.
            • E Offline
              erzane
              here I have 2 component
              if I create a bigger component I will have in my component folder
              -component 1
              -component 2
              -bigger component
              it will make 3 new components
              I dont need 3 component
              I just would like to erase components 1 & 2 and keep only the ''bigger component''
              but if I erase components 1 & 2 from the folder, even if I have the third ''bigger component''
              this operation will affect ''bigger component''
              perhaps my mistake is that :
              every time I copy a component and make 2 from it and past them
              I clic right and do ''make a component''
              this will creat every time some new components
              I would like to know how to make a big component from smaller ones without creating new ones but by gluing/past them to others
              and how to erase unuseless components from the folder without affecting new/final component
              http://img502.imageshack.us/img502/1557/capture01qv.jpg
                Holy cow! If you do what you describe I'd bet your model is a mess. I imagine the outliner is interesting. I'm not entirely sure what it is you want to do but if you want to combine the geometry of component 1 and component 2 into a component 3, you could explode those two instances and make the larger component or you could make a nested component called "component 3 which includes component 1 and component 2. Then open component 3 for editing and explode component 1 and component 2. Exploding the instances in the drawing space won't eliminate the component definitions from the In Model component library so you would still have them if you need them later.
                By the way, it looks like you have a lot of reversed faces in your model. You really should correct those as you go. It'll save you a lot of problems later. We've talked about that before. 😉
                  Reversed faces are the blue ones in your model. SketchUp is a surface modeler and so faces have an inside and an outside. The default back face color is blue and your first image shows a lot of those exposed. You should correct those by reversing them so the white side is out.
                  • E Offline
                    erzane
                    oh ok I see but I dont know how to do it
                    must I do it manualy ?
                    • E Offline
                      erzane
                      Yes I would like to combine the geometry of component 1 and component 2 into a component 3 and not having component 1 & 2 & 3 in my library, only component 3 for this example
                      but I dont know what to do after ''editing'' a component
                      there is an option, in french ''rendre unique''
                      just under ''creat a group''
                      can I use this one for make one and only one object ?
                      p.s. sorry but I dont remember about our talk concerning ''reversed faces''
                      if I understand well, ''reversed faces'' is when I copy a model and past it to the other one like a mirror ?
                      for example for making a bigger model I use same but smaller ones and I reverse them
                      but I don't see for the moment what could be the problem with that
                      pls can you reexplain me ?
                      sorry if I lost this important point
                      thanks
                        Open the component for editing, select the blue faces, right click on the m and choose Reverse Faces.
                        • E Offline
                          erzane
                          it gave me ''error 183'' and closed alone
                          I tryed again and this time ''not enough memory''
                          http://img687.imageshack.us/img687/1108/capture02uj.jpg
                          http://img268.imageshack.us/img268/4469/capture03t.jpg
                            What gave you the error?
                              Who said anything about intersecting? I just told you to explode the components.
                              • E Offline
                                erzane
                                ''intersection des faces'' > avec le model
                                means in english ''intersection of edges''>''with the model''
                                I dont know what is error 183, it didn't make it again
                                2nd time it was ''not enough memory''
                                p.s. another thing for coming back to the first subject
                                for be sure there is no missunderstanding I made another capture for explain my issue as best
                                http://img803.imageshack.us/img803/8905/capture01u.jpg
                                the ''big'' component exists in my library
                                but all other components I used for make it are registred to (1-5)
                                1.I would like to erase all smaller components from my library but I cannot
                                2.If I want to creat a 2nd ''big'' and past it to the 1st one I would like to make a ''fusion'' with the 1st one and not a new component because it will put a new component in my library,
                                I will certainly use it but I will never use the older ones again
                                so I feel it takes place in my system and make my PC slower..
                                perhaps that's the problem with my memory now (not enough memory) because I have to much unnecessary components that I would like to fusion
                                I hope this time my explanations is good 😛
                                • E Offline
                                  erzane
                                  sorry I missunderstood it
                                  now it's ok, I can make it without problem, I will show you the result tomorrow
                                  it's 01:25 morning I will go to sleep now, I am very tyred
                                  if you have a solution for the 1st subject pls lmk
                                  thanks a lot for your help again
                                    All right, I understand now. It seems that you need to turn that "component 3" into a so called "external component" (which you can collapse in the component browser and only display the top level component).
                                    Here is a short tutorial I made a while ago. The original purpose was somewhat different but you can also use it for this - although it may take a bit of time to export and re-import every top level component.
