    Good Sample Scene to test materials
    renderpluginsextensions
    7 Posts 3 Posters 2.4k Views 3 Watching
      penumbra
      Anybody has a good sample scene to test materials? Willing to share?
      • stefanqS Offline
        stefanq
        http://www.sketchupvraymaterials.blogspot.ro/p/download-vray-material-model.html
          penumbra
          many thanks stefan. i saw that. seemed to me the sample model is a bit too complicated.
          Thanks.
          • V Offline
            valerostudio
            The intention when I created the model was to be able to see a material in a variety of situations you would encounter in architecture (flat horizontal and veritcal, curved, radii, etc.) You can take the scene and replace with any object you like. FormFonts has a good material tester ball if you have an account with them.
            http://www.formfonts.com/viewModel.php?view=1&id=16039
              penumbra
              thanks valero,
              Would you look at that! hadn't run across that one at FormFonts. I ended up making my own based on the vray tuts video.
              Thanks.
              • V Offline
                valerostudio
                Any chance you would like to share that model with the class?
                  penumbra
                  @ valero
                  took your suggestion and replaced the object in the scene. Since you authored the scene is ok with you? I had to lower the emitters on the sides slightly to suit my need.
                  Material Test Studio.skp
