    Problems with road with different value of high..
    6 Posts 3 Posters 374 Views 3 Watching
      ayieartwork
      im having problems to do the road with slope/diff high in sketchup..
      the red which is the road ramp up,coernering with junction. how can i build this on sketchup?
      sorry im newbie.
      attached herewith the elvation and the plan of the drawing.
      Help me please. 😒
      Intel Core i7-3930k with 16gb G.Skill Ripjaws
      • daleD Offline
        dale
        Do you by chance have access to the survey contours?
          ayieartwork
          i got the survey drawing but it was too tricky/hard to read..because every point have their value.. how?
          • daleD Offline
            dale
            In the screenshot here you can see I have made the contours into a surface in Sandbox. The contours were imported from the survey into SketchUp in dxf/dwg format. Screen shot 2012-08-11 at 7.52.24 AM.png
            I have drawn the shape of the road, which you see hovering over the contours (in Red) and in this case rather than just stamp the road, I have first intersected the surface of the contours by pushpulling the road (you can see the original still under the road in backface blue)
            The intersection I saved, which gave me this as the road.Screen shot 2012-08-11 at 8.01.33 AM.png
            This was all done in copies of the drawing, and cut and pasted in.
            Then I did the stamp in sandbox, which because of the steepness of the sight made quite deep cuts, which I worked with using intersecting surface, and some hand work to get the road placed the way I wanted it.
            I tend not to be afraid to work "longhand", and it does take some work, but the results rendered up really well.
            I hope that others jump in here as I know there are other approaches.
            Hope this helps.
              mac1
              (www.valiarchitects.com)
                ayieartwork
                thanks guys for the info..
                actually the main prob is i do not have the contour dwg, thats so hard to draw it by my own..
                i just use drape tools on sandbox and adjust it..it works..
                for the instant road, it will be more cool if i have the contour dwg.
                btw, thanks for the help! appreciate it! 😎
