    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    New Developer Export to PDF can it be done?
    11 Posts 6 Posters 505 Views 6 Watching
    • U Offline
      umen
      Hello all
      im new to SketchUp pro , and in my job i need to develop some plugins to it .
      first question is , can i export scene to PDF via code ? c++ or rubi.
      if someone can send me link to reference or tutorial this will be great
      Thanks allot for your help.
      • Dan RathbunD Offline
        Dan Rathbun
        either Model#export()
        or View#write_image()
        You need to learn the basics of standard Ruby to use the SketchUp API.
        (see link below)
        I'm not here much anymore.
        • U Offline
          umen
          Thanks , but i didn't found any option to export to pdf .
          maybe i missing something ?
            None of them let you export to PDF.
              You can write a .jar file that in turn uses Java code that makes a PDF [there are several libraries that do this - iText jar?] - perhaps from the data gleaned from an exported 'image file' [?]... then you can use API's UI.openURL(path2jar) on that file...
              Not sure how easy it is to do... πŸ˜•
                driven
                I assume you mean 3D PDF, if so, you can buy a plugin that already does that.
                http://www.simlab-soft.com/3d-plugins/3D-PDF-from-sketchup-main.aspx
                  Dan Rathbun
                  Sorry, I assumed since it was on the menu that the export method would honor the ".pdf" file extension (at least for Pro editions.)
                  Just a thought.. if one has a PDF "Virtual" Printer installed (like a Fax Printer, or the MS XPS Printer,) perhaps a "print to file" scenario might work. (My Dad uses one of these fake PDF printers to create PDF files on his office desktop.)
                  • bomastudioB Offline
                    bomastudio
                    Hi Dan, I'm reading now this old post.
                    How I can access to printer from APIs?
                      Dan Rathbun
                      @bomastudio said:
                      Your cannot directly access the printer itself... But you can access the model's print settings.
                      The "PrintOptions" provider keys (with MY default settings):
                      PrintWidth ................: 8.5 PrintHeight ...............: 11.0 ComputeSizeFromScale ......: false SizeInPrint ...............: 1.0 SizeInModel ...............: 1.0 VectorMode ................: false FitToPage .................: true NumberOfPages .............: 1 LineWeight ................: 0.5 PixelsPerInch .............: 150.0 SectionSlice ..............: false ModelExtents ..............: true PrintQuality ..............: 0 ScaleAdjustment ...........: 1.0 QualityAdjustment .........: 1.0
                      • YOUR default settings may vary depending upon the model template used.
                      Change or read printing options:
                        opts = Sketchup.active_model.options
                        printing = opts["PrintOptions"]
                        # Example; change fit to page option;
                        printing["FitToPage"]= false
                      Click the menu item by doing this:
                      Sketchup.send_action("printDocument:")
                      πŸ’­
                        bomastudio
                        Thank you Dan, as usual you are very quick and accurate!! πŸ‘ πŸ‘
                        Sketchup.send_action("printDocument;")
                        ❓ Where you find it?? ❓
                          Dan Rathbun
                          In the Code Snippet post:
                          Re: [Code] Sketchup.send_action() : Arguments to
                          Lots of snippets indexed here: [Code Snippets]
                          πŸ’­
