    Translation and rotation vectors of copies of a component
    5 Posts 3 Posters 650 Views 3 Watching
      smicha
      HI,
      I am looking for a help how to get a list of vectors of translation and rotation of every copy of the same component. It would be great to have such a list as a txt or csv file, eg:
      copy0 tx0 ty0 tz0 rx0 ry0 rz0
      copy1 tx1 ty1 tz1 rx1 ry1 rz1
      copy2 tx2 ty2 tz2 rx2 ry2 rz2
      copyN txN tyN tzN rxN ryN rzN
      where tx ty tz denote translation, and rz ry rx rotaion.
      Users, please help. If this could be done in a form of a plugin it would be great. The intent is to use it in Octane Render and instancing.
      smicha
      • sdmitchS Offline
        sdmitch
        The transformation matrix for components and groups is a 16 element array which contains the vector definitions for the x,y,z axes and the origin point. The rotations can be derived by finding the arcsin or arccos of certain values of the array.
        If t is the transformation array and tx0,ty0,tz0 refers to the origin then tx0=t[12], ty0=t[13], and tz0=t[14]. The x_rotation=acos(t[5]), y_rotation=acos(t[0]), and z_rotation=asin(t[4]). These rotation values are not independent and can be influenced by one another.
        What do you plan to do with this info once it is written to a file?
        http://sdmitch.blogspot.com/
          smicha
          Sam,
          Otoy in Octane Render introduced instancing, which shortly speaking means you can render let's say an obj that occupies 100MB of vram and copy it thousands times and still use 100mb of vram. To do so you have to manually add every copy/placement in Octane and input scale, rotation and translation parameters for x y z. Or you can paste or upload a scv file that contains such information in a form of a matrix Nx12, where N represents number of copies of an obj. and 12 are columns. I paste some info from Octane forum:
          *The coordinates in a scatter node are given as the first three rows of the transformation matrices (the fourth is always [0, 0, 0, 1).
          For instance the matrix for a 30Β° rotation around the Z axis looks like this:
          [.87, –.50, 0, 0]
          [.50, .87, 0, 0]
          [ 0, 0, 1, 0]
          [ 0, 0, 0, 1]
          The scatter node will contain these 12 values:
          .87 –.50 0 0 .50 .87 0 0 0 0 1 0
          For a translation:
          [1, 0, 0, tx]
          [0, 1, 0, ty]
          [0, 0, 1, tz]
          [0, 0, 0, 1]
          1 0 0 tx 0 1 0 ty 0 0 1 tz]*
          So I need these values to create such Nx12 matrix.
          I am attaching a screenshot from Octane. On the top right you see such matrix. Hope it clarifies my request for help.
          smicha
            Smicha
            I've responded on the Octane forum...
            It is possible...
            However, remember the YZ swapping and inches > meters etc...
            Here are questions...
            Is there a way to make Octane import csv information - or must you do that manually ?
            It would be possible for you to do it something like this...
            You select one component-instance.
            You run the tool.
            It makes a small OBJ/MTL file - named as the Model_Component's name - in the project's folder.
            It finds all component-instances that are the same definition.
            It makes a CSV file containing the location/rotation and scaling information for each.
            One entry per line.
            We name it after the Model_Component's name.
            The OBJ and CSV are imported into the OCS and it uses the one instance multiple times...
            Can you confirm the order that the CSV file's '12' entries need to be in ?
            Also what they are - I assume 'meters' and YZ swapping as usual...
            Do you have a simple/short example??
            I'll think about the example coding and come back to you soon...
            Some are already answered. You manually link the 'Box.OBJ' and 'Scatter' files ?
            The location of an instance is given in the elements near the end.
            I think the example transformation you showed is 'rotated'?
            There are several threads explaining what each part of the array does, several interact...
            First off... we need to establish what is extracted from the SKP transformation's 16 elements and put into your 12 in what order. The YZ swapping and making inches into meters is already discussed; the other rotation/scaling elements are 'floats' and don't need tweaking - beyond getting them in the right place. πŸ€“
              smicha
              TIG,
              I'll keep answering your question on Octane forum.
