    [Plugin] Another Sketchup Plus update v1.5.4 Dec 29 2012
    26 Posts 6 Posters 40.1k Views 6 Watching
    • EdsonE Offline
      Edson
      james,
      you plugin seems to be very useful but it lacks a video that illustrates clearly what it can do. I have some difficulty myself to grasp all it offers. some kind of general explanation of all its features would be of benefit to all members.
      http://www.mahfuz.arq.br
      • dukejazzD Offline
        dukejazz
        I still need to make a demo movie
        I fix the box problem, no more message need.
        I move the Hints: by dukejazz in the making of Another to here
        Hints:
        Some Sketchup noted Hints: by dukejazz in the making of Another Sketchup Plus Ver. 1.2
        1 You can manually (flush a clipboard) of entities clean: By Using 3d text tool and copy a leter of text Then [cancel] out.
        2 Another Sketchup plus has a (auto clearing clipboard) useing a shortcut Cmd.link script to clear clipboard. I tried to make a ruby API script but failed. Cmd.link clean better than the manual way.
        3 (Security reasons): Flush clipboard when you leave your work area.[Clear Exit]
        4 (Never loose a documents) Make use of making copies of your document in your brower.
        5 (Smart) Open brower's copies to rework on keeps you from saving back to original.
        6 (Limits gray-out) Keep startup and console loaded plug-ins to small and few.
        7 (Keeps Skp file size small) In model, components and materials: uses (Via) Save and purge.
        8 (Watch memory flow:) Task manager: It is normal for parents overhead memory to be larger than a child.
        9 (Large doc gray-outs) Open a new parent copy of the document to paste back into it, because of larger overhead of note 8.
        10 (Max File save size) Max file size is by power of zoom extents, and by zoom in/out decreases the save size?
        11 (Polyreduce if you can) Overworking objects gives higher code counts. Keep objects hollow. Delete unused or unneed lines.
        12 (Bug splats) Keep register clean. Delete extra ToolbarsUser-Bars and ToolbarsUserCustom-Bars, If you get to 1000 it will splats on you, also it will take away loaded memory space too.(slows runway Bug splats)
        HKEY_CURRENT_USER\Software\Google\SketchUp8.
        a (Find) ToolbarsUser-Summary and ToolbarsUserCustom-Summary.
        b (via) Right-click_ permission special _ to you full control on and you read off. This (Locks) Toolbars to fix num ToolbarsUser_limits overloading your registers.
        13 (No need to load rbs at start up} By using a Sketchup::require statement, in a rb, you can loads a rbs scrip to the ruby console.
        14 Fix your start up rbs code to zero by via note 13. Another Sketchup Plus Ver. 1.2 will run as a ruby console script a
        • dukejazzD Offline
          dukejazz
          new
          5/20/12
          Another_Sketchup plus Ver. 1.3
          fix messagebox hand shake problem has been removed
          rename some features to better fitting names
          full functions context_menu
          updated extension info
          • cmeedC Offline
            cmeed
            not quite sure i understand the functionality of this plugin - a video would sure help
            is this like 'edit in place' plugin from the podium guys?
            c
            • dukejazzD Offline
              dukejazz
              by cmeed on Mon May 21, 2012 1:02 am
              'edit in place'
              EditInPlace is a Google SketchUp plugin that lets you edit (modify) components and groups in a separate Google SketchUp instance.
              Went to their web site today and copy their decription above.
              by dukejazz on May May 21, 2012 8:39 pm
              I not sure
              I would say no
              Mine has more functions and is a platform
              Mine is like a 3 function mouse to their one fuction mouse.
              Their work with auto paste in place back for the MAC and Pc
              My manual paste in place coded dosn't work on MAC
              I use the functions of API to run another Google SketchUp instance.
              Started my develpment in dec 2011 indepentantly with out referance to podium guys?
              paste in place method _____________________________________
              Reference helped by CadFather
              cd_standard.rb on Fri May 22, 2009 toolbars structure and paste in place coded
              Need a movie
              by guanjin on Mon Mar 12, 2012 12:12 am
              by Edson on Sun May 20, 2012 7:36 am
              WIP
              My outline of my movie to come and the plugin another sketchup plus functionality:
              What is this plugin about, its a
              Project platform Editor: ( with plugins management and pasting tools )
              • Auto loads another sketchup with clipboard information.... Gives easy power functionality actions, to the editing of sketchup models, objects, or entities;... The objects can be pull out to a child sketchup and return back to illustrations detail to main project when done.
              -Help the loading of ruby scripts plug-ins. With ruby repeater installer, you can load plug-in scripts from main pulgin ... when you need them, ..... This gives you more than a 1000's chose's to choose from.
              -You can also reinstall plug-ins (in and out with hide/unhide method) by the brower .... then sending all objects to another sketchup will flushes all ruby in console out when new child sketchup starts......now you can do more ..... and manage gray outs memory limits.
              • Pasting tools I provide here are these paste in place, Duplicate, repaste, cpoint axes and clipboard cleaner
              • cmeedC Offline
                cmeed
                Su podium edit in place - http://www.suplugins.com/edit.php
                where did you see your 'edit in place'? Interested to know...?
                c
                • dukejazzD Offline
                  dukejazz
                  'edit in place'
                  Went to their web site and copy their decription
                  May 23 full decription
                  Click Here to view a quick YouTube video of EditInPlace.
                  EditInPlace overcomes one of Google SketchUp's biggest limitations - the clipping plane which prevents you from effectively editing small components in large models. It is a time saver for SU Podium users who need to add properties to materials that are hard to find in large models.
                  I not and expert on their program
                  Your place is the same Place I when too (I google it.to see what you ment by 'edit in place')
                  Then I view their small quick YouTube video of EditInPlace.
                  My development came from my tips
                  http://forums.sketchucation.com/viewtopic.php?f=79&t=40254
                  Tips about running more than one Sketchup
                  by dukejazz on Thu Sep 22, 2011 1:17 am
                  5 tips about running more than one sketchup
                  Tip 1) Run and do more with sketchup
                  You can run more than one sketchup programs at the same time.
                  Just hit your shortcut key twice and find out.
                  Tip 2) Cut and paste or paste in place
                  a) You can cut and past between between same levels of sketchup programs. 8-8 7-7 6-6
                  b) There are some copy programs that can copy many levels of copys with sketchup (25 level+ or more) M8 Free Multi Clipboard: Free Clip, Spartan Trial Upgrade
                  Tip 3) Use each sketchup for different task
                  Use one for laying out and other for creating the object.
                  Tip 4) Toolbars behavior
                  a) Remembers the last program exited is how the toolbars will look when you restart.
                  b) Common view can be saved by saving view - toolbar - saving toolbar positions.
                  Tip 5) Can use more plug-ins folders
                  a) By copying sketckup 8 to another location, you can load more plugins.
                  b) Also a empty plug-in folder is a great viewer
                  c) For zone testing for new downloaded plug-ins
                  (hint)
                  a) When copy is completed, make a new shortcut (sketchup2) to new sketchup.exe.
                  b) Load new plugins with a ruby toolbar.
                  c) Clean your registers, when needed.
                  All of this will help to over come the overloading of gray outs and bug splat.
                  (6 tips) for a better sketchup 8 m2...........pg 2
                  I made a plugin to make you life easier to control another sketchup
                  my tips that I posted here as help me to write this plugin.
                  History of the plugin
                  [plugin] Another_Sketchup v1.0 Dec 28 2011
                  [plugin] Another_Sketchup v1.1 Jan 18 2012
                  [plugin] Another_Sketchup plus v1.2 Jan 31 2012
                  [plugin] Another_Sketchup plus v1.2.1 feb 2 2012
                  (14 tips ) Sketchup noted Hints: by dukejazz in the making of Another Sketchup Plus ...........pg 2
                  My latest changes are user request to fit their needs.
                  Podium guys direction is a rendering Editor: for materials properties
                  Mine is a Project Editor: for engineers (red line note pad).
                  I see you have a MAC
                  I can set up a ver that paste only if you want.
                  I here to help.
                  -dukejazz
                  Download:
                  v 1.3 MAC bata
                  Let me know, if this works for you.
                  • cmeedC Offline
                    cmeed
                    I'm off on holiday for a couple of weeks, sorry. Maybe when I return. The latest info tells me more about how your plugin works I understand a bit more. You really need to do a video to get a full understanding.
                    • dukejazzD Offline
                      dukejazz
                      new
                      6/4/12
                      Another_Sketchup plus 1.4 Bata Project Editor
                      fix timing issue w/dj_delay
                      added scale and move tool
                      updated extension info to 1.4 Bata Project Editor
                      • dukejazzD Offline
                        dukejazz
                        Update:
                        7/23/12
                        • edited Another_Sketchup Plus Ver. 1.5
                        • took out Another_Sketchup Ver. 1.5
                        • took out scaling
                          I have absolutely no idea what this does. I've read through the thread and I'm not understanding 90% of what you are writing about.
                          From what I gather it can copy or move a part of a model to a new instance of SU then bring it back. But there seems to be another set of options that are not explained clearly to me.
                          • KrisidiousK Offline
                            Krisidious
                            Rich It's not really a full other instance of SU it's like a window, a small sketchUp for working on a certain part of the model.
                            By: Kristoff Rand
                            • dukejazzD Offline
                              dukejazz
                              I sorry about the confusion;
                              Large toolbars take alot of screen space.
                              you can always download the old version Another Sketchup Plus v1.4
                              and then everything will make since here.
                              Another Sketchup Plus Ver 1.4
                              Features list:
                              • Paste in place (Paste in place or paste)
                              • Repaste select(Select, delete and paste)
                              • Duplicate select (Select sum, Copy and paste)
                              • Duplicate all (Copy all and paste)
                              • c-Point outside axes (Mark object outside edge/area with cpoint/axis
                              • scaleGroupFloat_dj (High precison and move tool)
                              • Ruby script loader (Can load hidden script plug-ins repeatly )
                              • Open's explorer (Open's explorer to hide or unhide plug-ins)
                              • Extensions (Set extensions on/off to another sketchup)
                              • Move select (Move select to another sketchup)
                              • Send select (Send select to another sketchup)
                              • Send all (Send select all to another sketchup. flushes script plugins)
                              • Non selected Move (Clipboard info is sent to another sketchup)
                              • Non selected Select (Clipboard info is sent to another sketchup)
                              • Select exit (Copy selected then exit sketchup)
                              • Select all exit (Copy all then exit sketchup)
                              • Clear exit (Clear clipboard then exit sketchup)
                              • Clear paste (Clear clipboard)
                              • Non Select exit (Keeps Clipboard then exit)
                              My history of develoment:
                              • I started download in 2007.
                              • I started to reply to forum in april 2011.
                              • I started to give tips in Nov 2011 about running more than one sketchup.
                              • I develop my first plug-in(no tool bar)in running more than one sketchup called Another Sketchup after reading the API notes. Dec 2011
                              • I enhanced it with 9 other feature, gave it a toolbar look and call it
                                Another Sketchup plus Jan 2012. ( I rewritten the code to be a rb,rbs,extension)
                              • I updated Another Sketchup to (rb,rbs,extension) May 2012
                              • I was ask to make a movie to explain how things work in Another Sketchup plus
                                But when I made an outline I realize I needed to make some changes to reach that goal. june 2012
                              • Now by June 2012, I written 5 more plug-in scaleGroupFloat_dj, repeatUndoTool_dj, ZoomWindowSelect_dj, ZoomZoom_dj and ZoomView_dj.
                                -I working on, New enhancement call ProjectEditor_dj it is in the making but I have to interface every plugin I wrote to one dj_Plugin folder (one button toolbar with inputbox drop downs actions) July 2012
                              • dukejazzD Offline
                                dukejazz
                                Update
                                Dec 29 2012 v1.5.4
                                • plugins wrap in Module DJ::pluginsName.methodDJ(name space)
                                • @variable format (name space) dj_variable
                                • plugins name are in subject and name order (easy to look up)
                                • feature toolbar
                                • add group toolbar (agroup)
                                • add explode toolbar
                                • Big new programs is safe to use, now in module format
                                • 2 / 2
