    Spaceship (Collaborative Project)
    281 Posts 14 Posters 65.4k Views 14 Watching
    • iichiversiiI Offline
      iichiversii
      I suggest having the bridge flush with the main body instead of the 1 we have, best way I can describe it would be a pimple with a small pitch, if that makes sense πŸ˜•
      Bring on the Rain...
      • MarianM Offline
        Marian
        Riiight.....you mean this
        http://1.bp.blogspot.com/-JndOXRg4MEA/Tdt4F-5CUoI/AAAAAAAAADU/pyW3cfS8gr4/s1600/Pimples_0.jpg
        with this
        http://newseason.org.uk/Small_pitch_1.jpg
        • soloS Offline
          Dude that thing is about to pop.
            iichiversii
            I just had lunch 😲
            • MarianM Offline
              Marian
              You are the guilty party....how can a bridge look like a pimple with a small pitch? πŸ˜„
                iichiversii
                Ok a hemisphere shape but not with a high pitch, does that make sense? πŸ˜†
                • MarianM Offline
                  Marian
                  Sort of...though I don't particularly like the bridge in the form. It would sort of be like the Star Trek ones.
                    iichiversii
                    It would yes, this is a hard 1 to decide, πŸ‘Š
                      iichiversii
                      Wait I have an idea, I'll make some thing later, this idea might work πŸ‘
                      • MarianM Offline
                        Marian
                        πŸ˜„
                          iichiversii
                          I diffenately have an idea, think it may work, will post tonight πŸ‘
                          • MarianM Offline
                            Marian
                            Great...I sure hope it's not another pimple. πŸ˜†
                              iichiversii
                              πŸ˜† what about a wart πŸ˜„
                              • MarianM Offline
                                Marian
                                That's better.
                                  iichiversii
                                  Heres what i got for you, didnt end up with a bridge, dont know what happened πŸ˜•
                                  LOWERPOLY_BRIDGE_CONCEPT.skp
                                  • MarianM Offline
                                    Marian
                                    It's not bad, I like it. I thought at first that you deleted the back section or modified what was there. That bridge bit is very blended it works very well.
                                      iichiversii
                                      See what you can do with it, maybe ad a bridge
                                      • H Offline
                                        Hepf
                                        I like the idea of a joint project venture, and I like spaceships. But I had a different concept. A bit crazy. Well, it goes like this, star travel takes several years (I don't believe in warp speed) centuries maybe. Zero grav, apart some living areas with artificial grav, no air friction, so you won't need sreamlined shapes. And practically unlimited resources and computing capabilities. You redesign your spaceship with SU, and zillions of maintenance and repair robots and microbots go out and rebuild it. You got constrictions, the main living area, the nuclear plant far away from it, and a very long linear engine for propulsion. But then you can design and build whatever you want, a gothic cathedral with spires irradiating in 12 directions 360 degrees round, towers and flying bridges and buttresses, gargoyles etc. The whole thing can be extremely lightweight, no significant weight or stress on the structure (acceleration and deceleration will be only fractions of a G), but will appear solid and textured. I'll try something on those lines someday ...
                                        • MarianM Offline
                                          Marian
                                          Interesting ideas you got there Hepf.
                                          I like streamlined shapes, they look good in any medium πŸ˜›
                                          Peregrinus 0.skp
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
