    Spaceship (Collaborative Project)
    281 Posts 14 Posters 43.5k Views 14 Watching
    • iichiversiiI Offline
      iichiversii
      Yeah that was the impression I got from that, will we just make it non detachable?
      Bring on the Rain...
      • MarianM Offline
        Marian
        That would probably be better since the ship already has 3 dettachble parts. Lets not go overboard with that πŸ˜›
        We can make the smaller ship later. So any ideas for the bridge?
          iichiversii
          I suggest having the bridge flush with the main body instead of the 1 we have, best way I can describe it would be a pimple with a small pitch, if that makes sense πŸ˜•
          • MarianM Offline
            Marian
            Riiight.....you mean this
            http://1.bp.blogspot.com/-JndOXRg4MEA/Tdt4F-5CUoI/AAAAAAAAADU/pyW3cfS8gr4/s1600/Pimples_0.jpg
            with this
            http://newseason.org.uk/Small_pitch_1.jpg
            • soloS Offline
              Dude that thing is about to pop.
                iichiversii
                I just had lunch 😲
                • MarianM Offline
                  Marian
                  You are the guilty party....how can a bridge look like a pimple with a small pitch? πŸ˜„
                    iichiversii
                    Ok a hemisphere shape but not with a high pitch, does that make sense? πŸ˜†
                    • MarianM Offline
                      Marian
                      Sort of...though I don't particularly like the bridge in the form. It would sort of be like the Star Trek ones.
                        iichiversii
                        It would yes, this is a hard 1 to decide, πŸ‘Š
                          iichiversii
                          Wait I have an idea, I'll make some thing later, this idea might work πŸ‘
                          • MarianM Offline
                            Marian
                            πŸ˜„
                              iichiversii
                              I diffenately have an idea, think it may work, will post tonight πŸ‘
                              • MarianM Offline
                                Marian
                                Great...I sure hope it's not another pimple. πŸ˜†
                                  iichiversii
                                  πŸ˜† what about a wart πŸ˜„
                                  • MarianM Offline
                                    Marian
                                    That's better.
                                      iichiversii
                                      Heres what i got for you, didnt end up with a bridge, dont know what happened πŸ˜•
                                      LOWERPOLY_BRIDGE_CONCEPT.skp
                                      • MarianM Offline
                                        Marian
                                        It's not bad, I like it. I thought at first that you deleted the back section or modified what was there. That bridge bit is very blended it works very well.
                                          iichiversii
                                          See what you can do with it, maybe ad a bridge
                                          • H Offline
                                            Hepf
                                            I like the idea of a joint project venture, and I like spaceships. But I had a different concept. A bit crazy. Well, it goes like this, star travel takes several years (I don't believe in warp speed) centuries maybe. Zero grav, apart some living areas with artificial grav, no air friction, so you won't need sreamlined shapes. And practically unlimited resources and computing capabilities. You redesign your spaceship with SU, and zillions of maintenance and repair robots and microbots go out and rebuild it. You got constrictions, the main living area, the nuclear plant far away from it, and a very long linear engine for propulsion. But then you can design and build whatever you want, a gothic cathedral with spires irradiating in 12 directions 360 degrees round, towers and flying bridges and buttresses, gargoyles etc. The whole thing can be extremely lightweight, no significant weight or stress on the structure (acceleration and deceleration will be only fractions of a G), but will appear solid and textured. I'll try something on those lines someday ...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
