    Why so difficult to install plugins?
    16 Posts 5 Posters 1.9k Views 5 Watching
    • K
      keyon
      Just curious...are "extensions" and "plugins' the same thing?
      • T
        troypiggo
        You don't need that installer, it just makes it easier.
        Just to be clear, what OS are you using and what folder are you placing them in?
        This is not my signature. I type it at the end of every message for quality control.
        • KrisidiousK
          Krisidious
          no they are not exactly the same thing. However I have never used the built in sketchup extension installer. I don't think I'm having any issues. Plugins are installed in a variety of locations within SketchUp. some will be on the right click context menu, some will be in the drop down plugins menu, some will be found under tools and even some will be found under the draw menu. and plugins will sometimes need to be check-marked under the toolbar menu. and even some will be located under sub-menus of their creators like ThomThom's full menu under the plugins menu. with each you'll have to figure out where it is. and look closely to see if it is an extension or a plugin. extensions will need to be turned on in the extension menu under preferences.
          By: Kristoff Rand
          • K
            keyon
            Thanks, Krisidious...
            I understand what you mean now. Guess it depends on the author of that particular plugin, and how he/she put it together.
            • BoxB
              I'm guessing you're on a Mac, usual problem, find the correct plug in folder.
              Or I'm not certain of the file or plug in you are using, I don't feel the need to look too hard, but one thread relating to it has some rather big names in plugins saying it sort of doesn't work, and then nothing more. I might just be that the plug in you want has been developed under a different name or the paranoid police have moved it to a different menu section.
              Many new tools/ plug ins appear where you least expect them, until you think about it.
              Check the various menus, not just plugins.
              Also, only read this if your alcohol level is well over old age.
              Edit: as pointed out below and many many times on this forum, read the first post in a plug in thread properly.
              And always check the reality of the situation, be it plug ins or women.
              • K
                keyon
                Anybody have their favorite "align" tool plugin? I was just looking for something to quickly line up corners & edges of components.
                This is what I installed: http://forums.sketchucation.com/viewtopic.php?p=76774#p76774
                Still have to figure out how to use it, though πŸ˜„
                • KrisidiousK
                  Krisidious
                  That's the one I use. although I had uninstalled it a while back because of SketchUp's greying out menus after so many plugins are installed. but now that issue has been fixed so I'll reinstall it.
                  By: Kristoff Rand
                  • K
                    keyon
                    Know of any online tutorials for this thing? It's kind of stumping me.
                    • KrisidiousK
                      Krisidious
                      there is this lil tut I'm sure you saw it. for the align tool you already have. http://forums.sketchucation.com/viewtopic.php?p=76774#p248980
                      actually this is not the one I used. here is the one that I used.
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=20233 it has a toolbar.
                      By: Kristoff Rand
                        If you had read the script's instructions carefully [first page in its thread] you might have seen that align_2d appears in the Tools menu not the Plugins menu as you 'assumed'... and it is in fact designed to be used with the right-click context-menu when you have suitable objects selected...
                        1. Make a selection (other objects than groups or components are ignored)
                        2. Select " Align 2D" in the context menu or in the Tools menu
                        3. Click 2 points that define a line for the alignment.
                        4. A construction line is temporarily drawn and a dialog box is displayed
                        5. Choose your options:
                        • horizontally align all groups/components along X axis at the intersection with the cline
                        • vertically align all groups/components along Y axis at the intersection with the cline
                        • perpendicularly align all groups/components along a perpendicular virtual line at the intersection with the cline.
                        1. Other options self-explanatory
